For the past couple of weeks I have had messages re updating to the latest Flash version when browsing various web videos - but I have downloaded the latest version (that my Intel Mac on 10.5.8 will run) about a dozen times now, and each time the installation completes succesfully - but when browsing I am still getting messages that I need to update Flash Player..Strangely enough when following the Adobe uninstall procedure guidelines, the box that should show the version you are running is completetly blank, but the plug in 10.3 does appear in library/internet plug-ins. This is a slightly different problem to what most people seem to be having on this thread - any ideas folks,, Thanks ,
Hi Jeff,
Try going into Safari's preferences panel, click the Security tab, then make sure that "Enable plug-ins" is checked. It sounds like Safari isn't able to load any plugins if this page is blank.
Chris
I'm assuming you are using Safari, if so could you go to Safari's Help -> Installed Plugins menu item then check to see if Shockwave Flash is listed there, and if so what version is reported?
Chris
Yes Chris I'm using Safari, just checked Installed plugins as you suggested and there are no plugins listed
Jeff
Hi Jeff,
Chris
That's fixed it Chris - no idea how that box got unchecked and as
most videos were still working I assumed it was an Adobe update problem
Thanks a lot
Jeff
