SpreadsheetGetCellValue error
Contributor ,
Oct 26, 2012 Oct 26, 2012
With the following code under CF9,
<cfset c_dir=#GetDirectoryFromPath(GetCurrentTemplatePath())#>
<cfset ex_file=c_dir & "eshopping.xlsx">
#ex_file#<br>
<!--- 80 rows --->
<!--- 454 colomns --->
<cfset val=SpreadsheetGetCellValue(ex_file, "6", "454")>
<hr>
value : #val#
I have the following error : Internal server error : Error casting an object of type java.lang.String to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed. java.lang.String
(Excel 2007, extension xlsx)
I think I neeed to know how to define dthe "spreadsheetobject" ?
is this the Excel file adress ? or something ?
Thanks for HELP,  I thought It will be easy of use ?
Advanced techniques
1.3K
Contributor ,
So now, I used this code :
<cfspreadsheet
    action="read"
format = "CSV"
    src = "#ex_file#"
    columns = "247"
    name = "val"
    rows = "8" >
<cfdump var="#val#">
Simpler and it does work.
But colums are limited at 256, and my Sheet has 484 columns.
Thanks for any suggetsion.
Pierre.
If it's a csv file you can open it with either cffile or cfhttp.
Oct 29, 2012 Oct 29, 2012
That's converting it to CSV, not reading it from CSV.
256 columns is an undocumented limitation of spreadsheet operations in CF, I'm afraid.  It might be worth voting for the ticket I just raised to get this sorted out (the limit should not be there).
https://bugbase.adobe.com/index.cfm?event=bug&id=3355173
The only thing I can think of is to use POI directly (which is all <cfspreadsheet> uses; it just doesn't use it very cleverly, it seems).  You should be able to read the whole thing in.
Adam
Oct 31, 2012 Oct 31, 2012
#ex_file#<br>
<!--- 80 rows --->
<hr>
value : #val#
You have guessed correctly what the problem is. The variable ex_file is a string representing a URL, not a spreadsheet object. You may define the spreadsheet object like this:
<cfset spreadSheetObj  = spreadSheetRead(ex_file)>
Documentation
