quote:
Originally posted by: Captiv8r
Hi again
Sorry, I really do want to help, but it seems you are simply frustrated.
If you double click each of the layouts, you see properties associated with the layout. Earlier you stated that you found no files in the !SSL!/WebHelp folder. Assuming the generation process was successful, the output files ended up somewhere. I did a quick review of some of my WebHelp output files and I do see a ProjectName_rhc.htm file among the mix. However, I found nothing inside any help topic that outlined how this file is used or comes into play. Is it possible you are looking for a file bearing a .rhc extension as opposed to your project name being part of the mix and the file ending with a .htm extension?
I'm not sure what more I can do or say. Perhaps someone else is around and will be willing to step in and try to help. There are a few different ways to display context sensitive topics with the full frameset in view. The method you or your developers are using is new to me and I'm not sure where it was recommended.
Sorry I was unable to help here. Hopefully someone else knows the answer for you, I really do. Way beyond bedtime in my part of the world.
Cheers... Rick
