hello!
when i try to remove password security from my pdf file , i get this message
anyone knows why?
it doesn't happen on acrobat 9
The message is self-explanatory. A file with a digital signature isn't editable.
there is no digital signature on this file
maybe an (invisible) author certification ?
how can i check this?
Hi shay_df,
With the file open you need to open (aka expand) the Signature Navigation panel on the left side of Acrobat. Clcik on this pen icon:
If there is no writing in the panel at all (just one big blank white slate) then the next thing to look for is to see if the file was Reader Enabled (what Dave mentioned below). To check if the file has been Reader Enabled:
"This document restricts some Acrobat features to allow for extended features in Adobe Reader. To create a copy of the document that is not restricted (and has no extended features in Adobe Reader), choose File > Save a Copy."
If the test is there then the file has been Reader Enabled. If not then it has not.
If none of these procedures point to an existing digital signature then let me know and we can probe deeper.
Steve
i've checked this. the file has reader enabled, but that's the problem. i can't remove these rights enabled, i've saved a copy - it didnt help.
You say you've saved a copy but you haven't confirmed that you opened the copy.
It must go like this:
open file A with reader enabling
save a copy as file B
close file A (which was not changed, and is still reader enabled)
open file B
this is what i do:
1. i'm opening the file (the extended one)
2.i'm saving a copy (with a different name)
3.i get this note:
4. i click ok
5.i close the extended file
6. i try to open the new file - it always says that:
"the file is in use. enter a new name or close the file thats open in another program"
7.i completely close the Acrobat Pro
8. i open the new file again
9. it asks me for the password
10. i type the password
11.the new file is opened
But...it still a reader extended file ( i see that on file/properties/security - the messages at the bottom of the dialog, as written up on Steven Madwin note
Are you using the File > Save a Copy menu item? You must use that item and you will be shown a message about removing the extended rights. Just using Save As won't do a thing.
i know that. thats what i'm doing. it doesn't help. i suggest u try it on acrobat 11, and let me know
Are you sure you are doing that? You included a screen shot, but nothing of the message that is about removing the extended rights...
It's probably been asked already, but can you share this file?
how can i attach a file?
Ok, thanks for the file. You still didn't confirm whether you get the message about removing extended rights, and I guess you didn't.
I can reproduce this. The procedure described works fine in Acrobat X. But in Acrobat XI there is the additional message in your post #11.
What I suspect is happening is that the file is first saved identically, then it tries to take off the Reader enabling. This fails, and it gives up. But the copy is already saved; however, it is not modified. (Also, on my system, the file is still considered by Acrobat XI to be open, and cannot be re-opened without quitting).
I do not know whether this is a general failure in Acrobat XI or something specific to your file.
So at this point I'd give the advice: recreate the file if you don't have access to Acrobat X. (Perhaps you can copy/paste chunks of it to save time). I always advise keeping the ORIGINAL files (without password, signature, enabling or certification), because it has always been the case that some combinations of these can't be removed.
I'd also like to add a note pointing out apparent similarities to this post: http://forums.adobe.com/message/4823798#4823798
thanks for the advice.
did u try to create a new file on acrobatXI with a password, and remove the pass after creating it? like on my case?
It wasn't clear from your previous posts that the file had a Document Open password as opposed to a Permissions password (restricting editing etc.).
The combination of Reader extensions and a DocOpen password is a one-way street in Acrobat XI.
Hi shay_df,
Yes, the file is Reader enabled, and yes you have to create an unsigned copy of the file before you can remove the Password Security.
Steve
That workflow was possible in AX, but changes to the RE signing module in AXI have blocked it at step 6.
Hi Dave & shay_df,
Yes, it is a bug in version 11. And, no I don't have a date as to when it will be fixed.
Steve
Hi! I'd love to find out how you remove the passwords at all... My paystubs come passworded but the company changes the password every month (so I have to remember or note which pw goes with which stub, because the ones that already came I cannot change!) It's unbelievably frustrating.
@WeyrCat - if you know the password, in Acrobat you can use Tools > Protection > Encrypt > Remove Security.
@shay_df - I assume you previously Reader-extended the document, in which case Acrobat has signed the file. You cannot remove the underlying password security until you de-extend the rights using File > Save a Copy.
i did that. i've saved a copy. and still got these messages , can it be a bug on this version(11)?. try this and please let me know
Did you open the copy?
