21 Replies Latest reply: Nov 4, 2012 3:13 AM by Cocovanna RSS
    Need Help choosing components for new build.
    El_Plates Community Member
      My current PC is holding up workflow and not supporting all the features in CS6 Production premium, so it's time for new hardware.
      Current System
      CPU- i7 2600 (locked version).
      Motherboard- H67.
      RAM- 16GB DDR3 1333.
      Video card- AMD HD 6770- 1GB.
      Disk Drives- 1x 2Tb Seagate, 1x 1TB WD Caviar Black, 1x Samsung External drive for backups.
      SSD- 60GB Intel 520 series.
      Shortfalls in Current System's performance.
      - Previewing the timeline in Premiere Pro works fine until the current time indicator reaches a clip of Uncompressed .avi footage. Then it bogs down, and frame rates plummet. I suspect it's the disc drives failing to move the high bit rate data fast enough, so I'll probably need a raid-0 set up.
      - Slow previews in After Effects. Upping the RAM from 8GB to 16GB improved previews significantly, but it could be better.
      - Current GPU doesn't support 3D Ray tracing.
      Budget for new build
      -  $2800 (Australian dollars).
      Components I'm considering for new build
      Case- Corsair 600T (already owned).
      Motherboard- Z77. (Not sure which particular Z77 is best suited).
      CPU- i7 3770k
      CPU Cooling- Suggestions please.
      RAM- 32GB DDR3 1600 MHz. Any suggestions ?
      C: drive- SSD : 240GB intel 520 series.
      Media/assets disc- 1x 2TB Seagate drive.
      After Effects Exports (Uncompressed .avi) - 2x 2TB Seagate drives in Raid-0.
      Premiere Pro Exports- 1x 1TB WD Caviar Black (already owned).
      After Effects RAM Cache- SSD 60GB intel 520 series (already owned).
      Internal drive for backups- 3TB WD Red.
      GPU- GTX 580 - 3GB. Why not a 600 series GTX ? Because I plan to use Blender. Apparently 600 series cards don't work well with Blender.
      PSU- Modular. Wattage requirements not yet calculated.
      OS- Windows 7 Professional? or Ultimate?
      Suggested changes to the list, please.
