I have no changed anything in my settings but with the last
complilation that I did the Contents nav pane is suddenly
minimized. I have re-compiled and also opened the compiled file and
enlarged the contents nav pane again but as soon as I close the
file the pane is minimized again. This is a problem because people
think I have removed it. What happened and how to I fix it?
The only thing I can think of that could cause such a problem
is if you are using RH across a network. If so, don't. RH is
essentially an Access database which doesn't operate well across a
network. Did Rick's advice work?
