8 Replies Latest reply: Nov 8, 2012 6:50 AM by kevin.cecil RSS
    EBookExport.InDesignPlugin error on document open
    kevin.cecil Community Member
      Adobe InCopy CS6 8.0 and 8.0.1
      Mac OS X 10.8.2, 10.7.4, and 10.6.8.
      I have a file that throws a
      "Missing plugin
      The document "xxx.indd uses one or more plug-ins which are not currently avaiable on your system. Do you want to open it anyway?"
      error on document open. This document has been opened on multiple Macs using the all three of the most recent operating systems listed above. Updating InCopy to 8.0.1 did not change anything.
      Interestingly, in Extension Manager, EBookExport.InDesignPlugin does not show up in the list as an available plugin. It is in the InCopy applications folder: Applications/Adobe\ InCopy\ CS6/Plug-Ins/Filters/EBookExport.InDesignPlugin It does show up as an InDesign plugin, and it is loaded…
      A clean install of InCopy CS6 from the Adobe disc on a new Mac generates the same error when opening the document. Opening the document in InDesign and exporting to idml, then re-opening makes no difference. Same error.
      The root issue here is obviously that the extension is not recognized. I changed permisssions on the folder to no avail. As stated earlier, a fresh install on a new iMac and the extension will not load.
      Anyone else seen anything like this?
      Kevin
