ADOBE Software License Agreement
2.5 Portable or Home Computer Use. Subject to the important restrictions set forth in Section 2.6, the primary user of the Computer on which the Software is installed under Section 2.2 (“Primary User”) may install a second copy of the Software for his or her exclusive use on either a portable Computer or a Computer located at his or her home, provided that the Software on the portable or home Computer is not used at the same time as the Software on the primary Computer.
I just bought a new computer with Windows 7, I am currently using PSE and Premiere E on a Vista computer. According to the above I can legally install both software on a second computer, the second computer would be the new one. Am I correct?
Also in the License Agreement it states the below:
15. Peer to Peer Communications.
The Software may use your connection to a local area network, without additional notice, automatically to connect to other Adobe software and, in doing so, may indicate on the local area network that it is available for communication with other Adobe software. These connections may transmit the IP Address of your connection to the local network but no personally identifiable information is ever transmitted or received through such network connections (except to the extent that IP addresses may be considered personally identifiable in some jurisdictions). Please consult the Documentation for information about changing default settings.
Where do I find the Documentation to change the default settings?
I disabled Peer to Peer in Flash Player as I use a Costly High Speed Cellular Internet connection. Is there somewhere else in the Adobe software where I can disable Peer to Peer?
