4 Replies Latest reply: Nov 5, 2012 1:55 AM by adit600 RSS
    why "Assigning actions to events" doesn't work?
    adit600 Community Member
      Dear,
              In my authorization plug-in, I set a method which I hope it can be called by SSAS when connect event occurs.
      void FmsAuthAdaptor::notify(IFmsAuthEvent* pAev)
        processStats(pAev);
        MyFmsNotifyEvent(pAev, m_pFmsAuthServerContext).notify();
      void FmsAuthAdaptor::processStats(IFmsAuthEvent* pAev)
            if (pAev->getType() == IFmsAuthEvent::E_CONNECT)
        FmsVariant field;
        if (pAev->getField(IFmsAuthEvent::F_CLIENT_ID, field) == IFmsAuthEvent::S_SUCCESS)
             m_pFmsAuthServerContext->log("before ssas method", IFmsServerContext::kInformation, false);
             I64 clientId = field.i64;
             IFmsNotifyAction* pAction = pAev->addNotifyAction("Notified by adaptor");
             pAction->setClientId(field);
             const char mtd[] = "my_test";
             field.setString(reinterpret_cast<I8*>(const_cast<char*>(mtd)));
             pAction->setMethodName(field);
      // create and insert a U16 "12345" as the first parameter
      field.setU16(12345);
      pAction->addParam(field);
      // create and insert clientId as a double as the second parameter
      field.setDouble((double)clientId);
      m_pFmsAuthServerContext->log("after ssas method", IFmsServerContext::kInformation, false);
      In my application directory, I create a script named as main.asc. I have the following codes:
      application.onConnect = function(client)
        application.acceptConnection( client );
        trace("MJF:application.onConnect" );
        client.my_test = function(userParam, clientId)
          trace("MJF:in my_test ");
        trace("MJF: after my_test");
      but, I don't know why:
      when a client connected in, I can see the traces "MJF:application.onConnect", and "MJF: after my_test", but I can not see "MJF:in my_test". seems my_test method is not called by SSAS. Assigning actions to events doesn't work? why?
      is there anyone who can tell me why? Thanks in advance!
