Show 4 replies
1. Re: How to make a straight line of points in a curve in CS6
R_Kelly Nov 2, 2012 12:33 AM (in response to Matthew A Kraus) -
2. Re: How to make a straight line of points in a curve in CS6
Matthew A Kraus Nov 3, 2012 7:18 AM (in response to R_Kelly)Thanks. I did, and now I again tried to do the technique so was reminded
of the question. I was just hoping there was an easy solution in CS6
because it worked so well in CS5 that I thought I'd ask ask again.
Matthew Kraus
3. Re: How to make a straight line of points in a curve in CS6
conroy Nov 3, 2012 7:25 AM (in response to Matthew A Kraus)I gave an easy solution the last time you asked. Make a preset with the required nine points. Then it'll be as easy to pick a preset from the little menu as it is to draw a line.
4. Re: How to make a straight line of points in a curve in CS6
Matthew A Kraus Nov 5, 2012 12:00 PM (in response to conroy)I did it as you suggested and it worked well. Very simple to use just like
you said.
Matthew Kraus
