3 Replies Latest reply: Nov 7, 2012 12:53 AM by Nitin_Bansal RSS
    Dreamweaver Installation Failing
    fhk02127
      I have downloaded without issue Photoshop and Indeisgn however when I go to install dreamweaver, installation makes it to 95% and then fails with the message I have pasted below, please advise...
      Exit Code: 7
      Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF043, DW063 ...
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 4 error(s), 0 warning(s)
      ----------- Payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 -----------
      ERROR: DF043: Failed in GetNamedSecurityInfo(Seq 39)
      ERROR: DW063: Command ARKSetPermissionCommand failed.(Seq 39)
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
      ERROR: DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
        • 1. Re: Dreamweaver Installation Failing
          Nitin_Bansal Adobe Employee
          Hi @fhk02127,  Looks like there is some permission issue on existing folders on the machine which is causing the issue while setting permission of file(s) installed by Dreamweaver. This causes the installaiton failure.
          The installer log file can help to find the actual file/folder path causing the issue. Adobe Installer logs are found at 'Program Files (x86)/Common Files/Adobe/Installers'. Dreamweaver log file would be in compressed format with the filename containing 'Adobe Dreamwever CS6...'. Open it with any unzip utility and copy the contents in a post here.
          • 2. Re: Dreamweaver Installation Failing
            fhk02127 Community Member
            [   16724] Mon Nov 05 22:15:50 2012  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 6.2.10.0
            Win OS version: 6.1.1.0  Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            CHECK : Another Native OS installer already running
            Create Required Folders
            Assuming install mode
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 2922.99 milliseconds (2.92299 seconds) DTR = 338.01 KBPS (0.330088 MBPS)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Updating media info for: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Dreamweaver CS6
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Updating media info for: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Updating media info for: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Updating media info for: {8E8021FF-7AA0-11E1-BF04-E98EE5274486}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12ja_JPLanguagePack\Install.db
            Updating media info for: {8FDB26FC-7AA0-11E1-BF04-E25246635842}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12en_USLanguagePack\Install.db
            Updating media info for: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9E0AF030-AC6B-11E0-8837-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Updating media info for: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Updating media info for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Updating media info for: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            Updating media info for: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Updating media info for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Updating media info for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Updating media info for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,6.2.10.0]
            ----------------- CreatePayloadSession: machine is x86 ---------------
            ______ Verify Dependency Subscribers ______
            BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: 1 (0,3)
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: 2 (0,5)
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: 3 (0,4)
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: 3 (0,4)
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: 4 (1,1)
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: 5 (0,1)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: 5 (0,1)
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: 5 (0,1)
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: 5 (0,1)
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: 6 (3,1)
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: 7 (4,1)
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: 7 (4,1)
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: 8 (12,0)
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: 9 (0,0)
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: 9 (0,0)
            END Operation order for all session payloads: mediaGroup (requires,satisfies)
            Setting property "installLanguage" to: en_US
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Overwrite property "DEVersion" to: 6.0
            Overwrite property "selfDelete" to: false
            Overwrite property "skipSync" to: 1
            Overwrite property "userASUPath" to:
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is: true
            Action string for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0  is none
            Value returned on lookup of payload: {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is: true
            Action string for {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1  is none
            Value returned on lookup of payload: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is: true
            Action string for {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180  is none
            Value returned on lookup of payload: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is: true
            Action string for {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148  is none
            Value returned on lookup of payload: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is: true
            Action string for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is: true
            Action string for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0  is none
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: false
            Action string for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0  is none
            Value returned on lookup of payload: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is: true
            Action string for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0  is none
            Value returned on lookup of payload: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is: true
            Action string for {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0  is none
            Value returned on lookup of payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is: true
            Action string for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is: true
            Action string for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0  is none
            Value returned on lookup of payload: {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is: true
            Action string for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0  is none
            Value returned on lookup of payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is: false
            Action string for {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0  is install
            Value returned on lookup of payload: {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is: false
            Action string for {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0  is none
            Payload {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Value returned on lookup of payload: {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is: false
            Action string for {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0  is none
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
            [   16724] Mon Nov 05 22:16:16 2012  INFO
            ::START TIMER:: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In ReinstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5.26335 milliseconds (0.00526335 seconds)
            ::START TIMER:: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 218.46 milliseconds (0.21846 seconds)
            BEGIN InstallOperationsQueue Unordered operations
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation repair
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation repair
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation repair
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0:  with operation none
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation install
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation repair
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation repair
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation repair
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation install
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation repair
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation install
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation repair
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation repair
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation repair
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation repair
            END InstallOperationsQueue Unordered operations
            BEGIN InstallOperationsQueue Ordered operations
            END InstallOperationsQueue Ordered operations
            [   16724] Mon Nov 05 22:16:17 2012  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            ::START TIMER:: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}]
            [   20712] Mon Nov 05 22:16:17 2012  INFO
            Installer Operation: PayloadUninstaller
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Effective AdobeCode for: {354D20E6-A25F-4728-9DA6-C9003D8F2928} is {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Session includes local copy of payload for repair source
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   20712] Mon Nov 05 22:16:18 2012  INFO
            Extracting assets...
            Extracting assets complete. Number assets: 1
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            [   20712] Mon Nov 05 22:16:19 2012  INFO
            Setting permission for: C:\Program Files\Common Files\Adobe\APE\3.3 Group/User:Everyone Access:GENERIC_READ(Seq 3)
            [   20712] Mon Nov 05 22:16:20 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{354D20E6-A25F-4728-9DA6-C9003D8F2928}.db
            Physical payload repair result:0
            [   16724] Mon Nov 05 22:16:20 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 2750.98 milliseconds (2.75098 seconds) DTR = 187.57 KBPS (0.183174 MBPS)
            Updating driver data - Action: Add driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 0KB
            User specified overrideFile:
            Successfully updated the csu inventory for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            Calling the custom action code for pre-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            ::START TIMER:: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}]
            [   18640] Mon Nov 05 22:16:20 2012  INFO
            Installer Operation: ModifyThirdPartyPayloadOperation
            Modify Thirdparty payload
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            CommandLine: /q /norestart
            [   18640] Mon Nov 05 22:16:34 2012  INFO
            Third party payload completed.  Testing return code: 0
            [   16724] Mon Nov 05 22:16:34 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 13308.3 milliseconds (13.3083 seconds) DTR = 7.81466 KBPS (0.0076315 MBPS)
            The csu inventory was not updated for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1, value of local var is -1
            Calling the custom action code for post-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            ::START TIMER:: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}]
            [   20604] Mon Nov 05 22:16:34 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            CommandLine: /q:a /c:"msiexec /i vcredist.msi /qn /norestart"
            [   20604] Mon Nov 05 22:16:43 2012  INFO
            [   16724] Mon Nov 05 22:16:43 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 9054.58 milliseconds (9.05458 seconds) DTR = 27.8312 KBPS (0.0271789 MBPS)
            The csu inventory was not updated for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180, value of local var is -1
            Calling the custom action code for post-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            ::START TIMER:: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}]
            [   20600] Mon Nov 05 22:16:43 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            [   20600] Mon Nov 05 22:16:49 2012  INFO
            [   16724] Mon Nov 05 22:16:49 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 6017.04 milliseconds (6.01704 seconds) DTR = 68.4722 KBPS (0.0668674 MBPS)
            The csu inventory was not updated for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148, value of local var is -1
            Calling the custom action code for post-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            [   16724] Mon Nov 05 22:16:50 2012  INFO
            Calling the custom action code for pre-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            ::START TIMER:: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}]
            [   20468] Mon Nov 05 22:16:50 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Effective AdobeCode for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} is {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Evaluating condition# 1(Seq 31)
            Condition failed(Seq 31)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}.db
            [   20468] Mon Nov 05 22:16:51 2012  INFO
            [   16724] Mon Nov 05 22:16:51 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 1119.14 milliseconds (1.11914 seconds) DTR = 78.6319 KBPS (0.076789 MBPS)
            [   16724] Mon Nov 05 22:16:52 2012  INFO
            Successfully updated the csu inventory for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PrePayloadReinstallProc
            [   16724] Mon Nov 05 22:16:57 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5031.5 milliseconds (5.0315 seconds) DTR = 44.5195 KBPS (0.0434761 MBPS)
            ::START TIMER:: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            [   21208] Mon Nov 05 22:16:57 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Effective AdobeCode for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} is {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            [   21208] Mon Nov 05 22:16:58 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}.db
            [   16724] Mon Nov 05 22:16:58 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 718.166 milliseconds (0.718166 seconds) DTR = 44.5579 KBPS (0.0435136 MBPS)
            Successfully updated the csu inventory for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PostPayloadReinstallProc
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.60513 milliseconds (0.00260513 seconds)
            Calling the custom action code for pre-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            ::START TIMER:: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}]
            [   10784] Mon Nov 05 22:16:58 2012  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            CommandLine: -silent -eulaAccepted -programMenu WidgetBrowser.air
            [   10784] Mon Nov 05 22:17:09 2012  INFO
            [   16724] Mon Nov 05 22:17:09 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 10980.7 milliseconds (10.9807 seconds) DTR = 619.268 KBPS (0.604754 MBPS)
            [   16724] Mon Nov 05 22:17:10 2012  INFO
            Successfully updated the csu inventory for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 return values 0:0
            Calling the custom action code for post-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            Calling the custom action code for pre-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}]
            [   19120] Mon Nov 05 22:17:10 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Effective AdobeCode for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} is {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   19120] Mon Nov 05 22:17:13 2012  INFO
            Extracting assets complete. Number assets: 2
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [   19120] Mon Nov 05 22:17:18 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}.db
            [   19120] Mon Nov 05 22:17:19 2012  INFO
            [   16724] Mon Nov 05 22:17:19 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 8935.08 milliseconds (8.93508 seconds) DTR = 265.918 KBPS (0.259686 MBPS)
            Successfully updated the csu inventory for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            ::START TIMER:: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}]
            [   21056] Mon Nov 05 22:17:19 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            [   21056] Mon Nov 05 22:17:20 2012  INFO
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            CommandLine: appVersion=4.0.244 appId=chc pubId=4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 installerArg1=-silent installerArg2=-eulaAccepted installerArg3=-programMenu installerArg4=AdobeHelp.air
            [   16724] Mon Nov 05 22:17:20 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 418.164 milliseconds (0.418164 seconds) DTR = 57.3938 KBPS (0.0560486 MBPS)
            The csu inventory was not updated for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0, value of local var is -1
            Calling the custom action code for post-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [   16724] Mon Nov 05 22:17:25 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5010.3 milliseconds (5.0103 seconds) DTR = 448.676 KBPS (0.43816 MBPS)
            ::START TIMER:: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [    8832] Mon Nov 05 22:17:25 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Effective AdobeCode for: {36682D68-3834-487E-BA49-DFA4AB0A2E32} is {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    8832] Mon Nov 05 22:17:26 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [    8832] Mon Nov 05 22:17:27 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{36682D68-3834-487E-BA49-DFA4AB0A2E32}.db
            [   16724] Mon Nov 05 22:17:28 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2623 milliseconds (2.623 seconds) DTR = 1796.42 KBPS (1.75432 MBPS)
            Successfully updated the csu inventory for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.44014 milliseconds (0.00144014 seconds)
            Calling the custom action code for pre-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            ::START TIMER:: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}]
            [   21844] Mon Nov 05 22:17:28 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Effective AdobeCode for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} is {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            Payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   21844] Mon Nov 05 22:17:30 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [   21844] Mon Nov 05 22:17:33 2012  INFO
            Evaluating condition# 1(Seq 98)
            Condition failed(Seq 98)
            [   21844] Mon Nov 05 22:17:36 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}.db
            [   16724] Mon Nov 05 22:17:36 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 8435.43 milliseconds (8.43543 seconds) DTR = 24.6579 KBPS (0.02408 MBPS)
            Successfully updated the csu inventory for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}]
            [   13544] Mon Nov 05 22:17:36 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Effective AdobeCode for: {83463106-DD1C-4FE5-A61C-DF6715472AD4} is {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   13544] Mon Nov 05 22:17:39 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [   13544] Mon Nov 05 22:17:44 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{83463106-DD1C-4FE5-A61C-DF6715472AD4}.db
            [   16724] Mon Nov 05 22:17:44 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 7367.94 milliseconds (7.36794 seconds) DTR = 44.5172 KBPS (0.0434738 MBPS)
            Successfully updated the csu inventory for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            ::START TIMER:: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}]
            [   20696] Mon Nov 05 22:17:44 2012  INFO
            Installer Operation: PayloadInstaller
            Request to install payload
            Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   20696] Mon Nov 05 22:18:39 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Everyone Access:GENERIC_ALL(Seq 29)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Administrators Access:GENERIC_ALL(Seq 30)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 31)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 32)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Everyone Access:GENERIC_ALL(Seq 34)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Administrators Access:GENERIC_ALL(Seq 35)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 36)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 37)
            Setting permission for: \\lefh-sfps-fs\fs-userrf$\fknippenberg\Application Data\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 39)
            [   20696] Mon Nov 05 22:18:39 2012 ERROR
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [   16724] Mon Nov 05 22:18:44 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 60238.2 milliseconds (60.2382 seconds) DTR = 3881.46 KBPS (3.79048 MBPS)
            The csu inventory was not updated for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 cannot be installed due to dependent operation failure.
            Skipping payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 106223KB
            [   16724] Mon Nov 05 22:18:46 2012  INFO
            Successfully installed 1 component:
            - Adobe Dreamweaver Widget Browser
            Successfully repaired 11 components:
            - Adobe Player for Embedding 3.3
            - Adobe CSXS Infrastructure CS6
            - Adobe Extension Manager CS6
            - Microsoft Visual C++ 2005 Redistributable Package (x86)
            - Microsoft Visual C++ 2008 Redistributable Package (x86)
            - Microsoft Visual C++ 2010 Redistributable Package (x86)
            - Suite Shared Configuration CS6
            - AdobeHelp
            - Adobe Linguistics CS6
            - Adobe CSXS Extensions CS6
            - Adobe ExtendScript Toolkit CS6
            Total components removed: 0
            [   16724] Mon Nov 05 22:18:46 2012 ERROR
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 179973 milliseconds (179.973 seconds) DTR = 1324.09 KBPS (1.29306 MBPS)
            Please search the above error/warning string(s) to find when the error occurred.
            These errors resulted in installer Exit Code mentioned below.
            [   16724] Mon Nov 05 22:18:47 2012  INFO
            Exit Code: 7 - Unable to complete Silent workflow.
            Please see specific errors and warnings for troubleshooting. For example, ERROR: DF043, DW063 ...
            END - Installer Session
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 2381.34 milliseconds (2.38134 seconds)
            [   12820] Mon Nov 05 22:20:21 2012  INFO
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: true
            [   12820] Mon Nov 05 22:20:24 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 31.8127 milliseconds (0.0318127 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 30.3219 milliseconds (0.0303219 seconds)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation repair
            [   12820] Mon Nov 05 22:20:25 2012  INFO
            [   22208] Mon Nov 05 22:20:25 2012  INFO
            [   22208] Mon Nov 05 22:20:26 2012  INFO
            [   12820] Mon Nov 05 22:20:26 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1009.02 milliseconds (1.00902 seconds)
            [   20076] Mon Nov 05 22:20:26 2012  INFO
            [   20076] Mon Nov 05 22:20:30 2012  INFO
            [   12820] Mon Nov 05 22:20:30 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 4019.28 milliseconds (4.01928 seconds) DTR = 100.516 KBPS (0.0981598 MBPS)
            [   21492] Mon Nov 05 22:20:30 2012  INFO
            [   21492] Mon Nov 05 22:20:34 2012  INFO
            [   12820] Mon Nov 05 22:20:35 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4330 milliseconds (4.33 seconds) DTR = 6.46651 KBPS (0.00631495 MBPS)
            [   12980] Mon Nov 05 22:20:35 2012  INFO
            [   12980] Mon Nov 05 22:20:38 2012  INFO
            [   12820] Mon Nov 05 22:20:38 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3037.45 milliseconds (3.03745 seconds) DTR = 165.929 KBPS (0.16204 MBPS)
            [   18668] Mon Nov 05 22:20:38 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 518.16 milliseconds (0.51816 seconds) DTR = 995.832 KBPS (0.972492 MBPS)
            [   12820] Mon Nov 05 22:20:39 2012  INFO
            [   12820] Mon Nov 05 22:20:44 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5010.26 milliseconds (5.01026 seconds) DTR = 0.798362 KBPS (0.000779651 MBPS)
            [   19240] Mon Nov 05 22:20:44 2012  INFO
            [   19240] Mon Nov 05 22:20:45 2012  INFO
            [   12820] Mon Nov 05 22:20:45 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 720.467 milliseconds (0.720467 seconds) DTR = 44.4156 KBPS (0.0433747 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.68577 milliseconds (0.00268577 seconds)
            Calling the custom action code for pre-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [   21476] Mon Nov 05 22:20:45 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            [   21476] Mon Nov 05 22:20:49 2012  INFO
            Third party payload completed.  Testing return code: 9
            [   12820] Mon Nov 05 22:20:49 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4540.07 milliseconds (4.54007 seconds) DTR = 3.52418 KBPS (0.00344158 MBPS)
            Calling the custom action code for post-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [   12820] Mon Nov 05 22:20:50 2012  INFO
            [   21064] Mon Nov 05 22:20:50 2012  INFO
            [   21064] Mon Nov 05 22:20:52 2012  INFO
            [   21064] Mon Nov 05 22:20:55 2012  INFO
            [   12820] Mon Nov 05 22:20:55 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5354.51 milliseconds (5.35451 seconds) DTR = 95.6204 KBPS (0.0933793 MBPS)
            [   20660] Mon Nov 05 22:20:55 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 310.059 milliseconds (0.310059 seconds)
            [   12820] Mon Nov 05 22:20:56 2012  INFO
            [   12820] Mon Nov 05 22:21:01 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5010.54 milliseconds (5.01054 seconds) DTR = 0.798317 KBPS (0.000779606 MBPS)
            [   19964] Mon Nov 05 22:21:01 2012  INFO
            [   19964] Mon Nov 05 22:21:02 2012  INFO
            [   12820] Mon Nov 05 22:21:02 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1425.41 milliseconds (1.42541 seconds)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.3676 milliseconds (0.0013676 seconds)
            [   20324] Mon Nov 05 22:21:02 2012  INFO
            [   20324] Mon Nov 05 22:21:04 2012  INFO
            [   20324] Mon Nov 05 22:21:07 2012  INFO
            [   20324] Mon Nov 05 22:21:09 2012  INFO
            [   12820] Mon Nov 05 22:21:09 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 6936.82 milliseconds (6.93682 seconds) DTR = 83.0352 KBPS (0.0810891 MBPS)
            [   12820] Mon Nov 05 22:21:10 2012  INFO
            [   14060] Mon Nov 05 22:21:10 2012  INFO
            [   14060] Mon Nov 05 22:21:11 2012  INFO
            [   14060] Mon Nov 05 22:21:13 2012  INFO
            [   12820] Mon Nov 05 22:21:13 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3409.81 milliseconds (3.40981 seconds)
            [   12820] Mon Nov 05 22:21:14 2012  INFO
            [    9828] Mon Nov 05 22:21:14 2012  INFO
            [    9828] Mon Nov 05 22:21:56 2012  INFO
            [    9828] Mon Nov 05 22:21:57 2012  INFO
            [    9828] Mon Nov 05 22:21:57 2012 ERROR
            [   12820] Mon Nov 05 22:22:03 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 49156.8 milliseconds (49.1568 seconds) DTR = 10.2529 KBPS (0.0100126 MBPS)
            [   12820] Mon Nov 05 22:22:05 2012  INFO
            Total components installed: 0
            Successfully repaired 12 components:
            - AdobeHelp
            [   12820] Mon Nov 05 22:22:05 2012 ERROR
            :: END TIMER :: [Total Timer] took 107138 milliseconds (107.138 seconds) DTR = 33.4894 KBPS (0.0327045 MBPS)
            [   12820] Mon Nov 05 22:22:06 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 1339.45 milliseconds (1.33945 seconds)
            [   19252] Mon Nov 05 22:22:56 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 4.60609 milliseconds (0.00460609 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 3.89331 milliseconds (0.00389331 seconds)
            [   19392] Mon Nov 05 22:22:56 2012  INFO
            [   19392] Mon Nov 05 22:22:57 2012  INFO
            [   19252] Mon Nov 05 22:22:57 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1009.62 milliseconds (1.00962 seconds)
            [   19252] Mon Nov 05 22:22:58 2012  INFO
            [   18936] Mon Nov 05 22:22:58 2012  INFO
            [   18936] Mon Nov 05 22:23:04 2012  INFO
            [   19252] Mon Nov 05 22:23:04 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6419 milliseconds (6.419 seconds) DTR = 42.9973 KBPS (0.0419896 MBPS)
            [   20528] Mon Nov 05 22:23:04 2012  INFO
            [   20528] Mon Nov 05 22:23:08 2012  INFO
            [   19252] Mon Nov 05 22:23:08 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4408.33 milliseconds (4.40833 seconds) DTR = 2.72212 KBPS (0.00265832 MBPS)
            [    3608] Mon Nov 05 22:23:08 2012  INFO
            [    3608] Mon Nov 05 22:23:12 2012  INFO
            [   19252] Mon Nov 05 22:23:12 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3217.09 milliseconds (3.21709 seconds) DTR = 123.093 KBPS (0.120208 MBPS)
            [   20768] Mon Nov 05 22:23:12 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 518.204 milliseconds (0.518204 seconds) DTR = 7.71896 KBPS (0.00753805 MBPS)
            [   19252] Mon Nov 05 22:23:13 2012  INFO
            [   19252] Mon Nov 05 22:23:18 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5010.24 milliseconds (5.01024 seconds) DTR = 0.798365 KBPS (0.000779653 MBPS)
            [   18208] Mon Nov 05 22:23:18 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 518.62 milliseconds (0.51862 seconds) DTR = 61.7022 KBPS (0.0602561 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.66875 milliseconds (0.00266875 seconds)
            [   18796] Mon Nov 05 22:23:18 2012  INFO
            [   18796] Mon Nov 05 22:23:24 2012  INFO
            [   19252] Mon Nov 05 22:23:24 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 5666.84 milliseconds (5.66684 seconds) DTR = 0.70586 KBPS (0.000689317 MBPS)
            [   12816] Mon Nov 05 22:23:24 2012  INFO
            [   12816] Mon Nov 05 22:23:25 2012  INFO
            [   12816] Mon Nov 05 22:23:27 2012  INFO
            [   12816] Mon Nov 05 22:23:29 2012  INFO
            [   19252] Mon Nov 05 22:23:29 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 4917.07 milliseconds (4.91707 seconds) DTR = 208.254 KBPS (0.203373 MBPS)
            [   21944] Mon Nov 05 22:23:29 2012  INFO
            [   21944] Mon Nov 05 22:23:30 2012  INFO
            [   19252] Mon Nov 05 22:23:30 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 308.585 milliseconds (0.308585 seconds) DTR = 12.9624 KBPS (0.0126586 MBPS)
            [   19252] Mon Nov 05 22:23:35 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5009.74 milliseconds (5.00974 seconds) DTR = 13.5735 KBPS (0.0132554 MBPS)
            [   15548] Mon Nov 05 22:23:35 2012  INFO
            [   15548] Mon Nov 05 22:23:36 2012  INFO
            [   15548] Mon Nov 05 22:23:37 2012  INFO
            [   19252] Mon Nov 05 22:23:37 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1813.77 milliseconds (1.81377 seconds) DTR = 176.428 KBPS (0.172293 MBPS)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.4086 milliseconds (0.0024086 seconds)
            [    8672] Mon Nov 05 22:23:37 2012  INFO
            [    8672] Mon Nov 05 22:23:39 2012  INFO
            [    8672] Mon Nov 05 22:23:40 2012  INFO
            [    8672] Mon Nov 05 22:23:43 2012  INFO
            [   19252] Mon Nov 05 22:23:43 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 6159.78 milliseconds (6.15978 seconds) DTR = 581.839 KBPS (0.568202 MBPS)
            [   19252] Mon Nov 05 22:23:44 2012  INFO
            [    9196] Mon Nov 05 22:23:44 2012  INFO
            [    9196] Mon Nov 05 22:23:45 2012  INFO
            [    9196] Mon Nov 05 22:23:47 2012  INFO
            [   19252] Mon Nov 05 22:23:47 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3523.17 milliseconds (3.52317 seconds) DTR = 9.08273 KBPS (0.00886986 MBPS)
            [   19252] Mon Nov 05 22:23:48 2012  INFO
            [   16424] Mon Nov 05 22:23:48 2012  INFO
            [   16424] Mon Nov 05 22:24:28 2012  INFO
            [   16424] Mon Nov 05 22:24:29 2012  INFO
            [   16424] Mon Nov 05 22:24:29 2012 ERROR
            [   19252] Mon Nov 05 22:24:37 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 49583.3 milliseconds (49.5833 seconds) DTR = 72.2823 KBPS (0.0705882 MBPS)
            [   19252] Mon Nov 05 22:24:39 2012  INFO
            - AdobeHelp
            [   19252] Mon Nov 05 22:24:39 2012 ERROR
            :: END TIMER :: [Total Timer] took 108956 milliseconds (108.956 seconds) DTR = 52.0947 KBPS (0.0508737 MBPS)
            [   19252] Mon Nov 05 22:24:40 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 970.55 milliseconds (0.97055 seconds) DTR = 4.12138 KBPS (0.00402478 MBPS)
            [   11332] Mon Nov 05 22:25:14 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.39003 milliseconds (0.00339003 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.81091 milliseconds (0.00181091 seconds)
            [   14244] Mon Nov 05 22:25:14 2012  INFO
            [   14244] Mon Nov 05 22:25:15 2012  INFO
            [   11332] Mon Nov 05 22:25:15 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1011.7 milliseconds (1.0117 seconds)
            [   11332] Mon Nov 05 22:25:16 2012  INFO
            [    9828] Mon Nov 05 22:25:16 2012  INFO
            [    9828] Mon Nov 05 22:25:23 2012  INFO
            [   11332] Mon Nov 05 22:25:23 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6838.94 milliseconds (6.83894 seconds) DTR = 59.0735 KBPS (0.057689 MBPS)
            [   20196] Mon Nov 05 22:25:23 2012  INFO
            [   20196] Mon Nov 05 22:25:27 2012  INFO
            [   11332] Mon Nov 05 22:25:27 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 3820.8 milliseconds (3.8208 seconds) DTR = 20.938 KBPS (0.0204473 MBPS)
            [   17724] Mon Nov 05 22:25:27 2012  INFO
            [   17724] Mon Nov 05 22:25:30 2012  INFO
            [   11332] Mon Nov 05 22:25:30 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3412 milliseconds (3.412 seconds) DTR = 123.095 KBPS (0.12021 MBPS)
            [   11332] Mon Nov 05 22:25:31 2012  INFO
            [   21980] Mon Nov 05 22:25:31 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 717.191 milliseconds (0.717191 seconds) DTR = 44.6185 KBPS (0.0435728 MBPS)
            [   11332] Mon Nov 05 22:25:32 2012  INFO
            [   11332] Mon Nov 05 22:25:37 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5016.32 milliseconds (5.01632 seconds) DTR = 33.4907 KBPS (0.0327057 MBPS)
            [   20452] Mon Nov 05 22:25:37 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 678.942 milliseconds (0.678942 seconds) DTR = 854.27 KBPS (0.834248 MBPS)
            [   11332] Mon Nov 05 22:25:38 2012  INFO
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 1.63586 milliseconds (0.00163586 seconds)
            [   20148] Mon Nov 05 22:25:38 2012  INFO
            [   20148] Mon Nov 05 22:25:43 2012  INFO
            [   11332] Mon Nov 05 22:25:43 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 5165.32 milliseconds (5.16532 seconds) DTR = 157.202 KBPS (0.153518 MBPS)
            [   21828] Mon Nov 05 22:25:43 2012  INFO
            [   21828] Mon Nov 05 22:25:45 2012  INFO
            [   21828] Mon Nov 05 22:25:48 2012  INFO
            [   21828] Mon Nov 05 22:25:49 2012  INFO
            [   11332] Mon Nov 05 22:25:49 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5818.39 milliseconds (5.81839 seconds) DTR = 177.369 KBPS (0.173212 MBPS)
            [   18108] Mon Nov 05 22:25:49 2012  INFO
            [   18108] Mon Nov 05 22:25:50 2012  INFO
            [   11332] Mon Nov 05 22:25:50 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 719.767 milliseconds (0.719767 seconds) DTR = 144.491 KBPS (0.141105 MBPS)
            [   11332] Mon Nov 05 22:25:55 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5011.18 milliseconds (5.01118 seconds) DTR = 993.777 KBPS (0.970486 MBPS)
            [   22460] Mon Nov 05 22:25:55 2012  INFO
            [   22460] Mon Nov 05 22:25:56 2012  INFO
            [   22460] Mon Nov 05 22:25:57 2012  INFO
            [   11332] Mon Nov 05 22:25:57 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1824.7 milliseconds (1.8247 seconds) DTR = 52.6113 KBPS (0.0513782 MBPS)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.41947 milliseconds (0.00141947 seconds)
            [   17608] Mon Nov 05 22:25:57 2012  INFO
            [   17608] Mon Nov 05 22:25:59 2012  INFO
            [   17608] Mon Nov 05 22:26:01 2012  INFO
            [   17608] Mon Nov 05 22:26:02 2012  INFO
            [   11332] Mon Nov 05 22:26:02 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5333.3 milliseconds (5.3333 seconds) DTR = 900.006 KBPS (0.878913 MBPS)
            [   11332] Mon Nov 05 22:26:03 2012  INFO
            [   18624] Mon Nov 05 22:26:03 2012  INFO
            [   18624] Mon Nov 05 22:26:05 2012  INFO
            [   18624] Mon Nov 05 22:26:07 2012  INFO
            [   11332] Mon Nov 05 22:26:07 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 4637.99 milliseconds (4.63799 seconds) DTR = 767.573 KBPS (0.749583 MBPS)
            [   20584] Mon Nov 05 22:26:07 2012  INFO
            [   20584] Mon Nov 05 22:26:46 2012  INFO
            [   20584] Mon Nov 05 22:26:46 2012 ERROR
            [   11332] Mon Nov 05 22:26:51 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 43520.1 milliseconds (43.5201 seconds) DTR = 11.9485 KBPS (0.0116685 MBPS)
            [   11332] Mon Nov 05 22:26:53 2012  INFO
            - AdobeHelp
            [   11332] Mon Nov 05 22:26:53 2012 ERROR
            :: END TIMER :: [Total Timer] took 104585 milliseconds (104.585 seconds) DTR = 61.3092 KBPS (0.0598722 MBPS)
            [   11332] Mon Nov 05 22:26:54 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 931.178 milliseconds (0.931178 seconds)
            [   22248] Mon Nov 05 22:35:55 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.40462 milliseconds (0.00340462 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 3.80741 milliseconds (0.00380741 seconds)
            [   10348] Mon Nov 05 22:35:55 2012  INFO
            [   10348] Mon Nov 05 22:35:56 2012  INFO
            [   22248] Mon Nov 05 22:35:56 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1020.98 milliseconds (1.02098 seconds)
            [   19548] Mon Nov 05 22:35:56 2012  INFO
            [   19548] Mon Nov 05 22:36:03 2012  INFO
            [   22248] Mon Nov 05 22:36:03 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6526.81 milliseconds (6.52681 seconds) DTR = 41.6743 KBPS (0.0406975 MBPS)
            [   14272] Mon Nov 05 22:36:03 2012  INFO
            [   14272] Mon Nov 05 22:36:08 2012  INFO
            [   22248] Mon Nov 05 22:36:08 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4509.23 milliseconds (4.50923 seconds) DTR = 111.771 KBPS (0.109151 MBPS)
            [   20540] Mon Nov 05 22:36:08 2012  INFO
            [   20540] Mon Nov 05 22:36:11 2012  INFO
            [   22248] Mon Nov 05 22:36:11 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 2921.25 milliseconds (2.92125 seconds) DTR = 134.189 KBPS (0.131044 MBPS)
            [   19060] Mon Nov 05 22:36:11 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 518.169 milliseconds (0.518169 seconds) DTR = 7.71949 KBPS (0.00753857 MBPS)
            [   22248] Mon Nov 05 22:36:12 2012  INFO
            [   22248] Mon Nov 05 22:36:17 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5011.4 milliseconds (5.0114 seconds) DTR = 4.78908 KBPS (0.00467683 MBPS)
            [   20324] Mon Nov 05 22:36:17 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 419.444 milliseconds (0.419444 seconds) DTR = 76.2915 KBPS (0.0745034 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.37254 milliseconds (0.00237254 seconds)
            [   20972] Mon Nov 05 22:36:17 2012  INFO
            [   20972] Mon Nov 05 22:36:22 2012  INFO
            [   22248] Mon Nov 05 22:36:22 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4727.24 milliseconds (4.72724 seconds) DTR = 48537.4 KBPS (47.3998 MBPS)
            [   11604] Mon Nov 05 22:36:22 2012  INFO
            [   11604] Mon Nov 05 22:36:25 2012  INFO
            [   11604] Mon Nov 05 22:36:27 2012  INFO
            [   22248] Mon Nov 05 22:36:27 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5327.56 milliseconds (5.32756 seconds) DTR = 96.8549 KBPS (0.0945848 MBPS)
            [   22248] Mon Nov 05 22:36:28 2012  INFO
            [   21692] Mon Nov 05 22:36:28 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 319.333 milliseconds (0.319333 seconds)
            [   22248] Mon Nov 05 22:36:33 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5007.98 milliseconds (5.00798 seconds) DTR = 10.3834 KBPS (0.0101401 MBPS)
            [   12060] Mon Nov 05 22:36:33 2012  INFO
            [   12060] Mon Nov 05 22:36:34 2012  INFO
            [   12060] Mon Nov 05 22:36:35 2012  INFO
            [   22248] Mon Nov 05 22:36:35 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2228.09 milliseconds (2.22809 seconds) DTR = 385.981 KBPS (0.376935 MBPS)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.47782 milliseconds (0.00147782 seconds)
            [   16204] Mon Nov 05 22:36:35 2012  INFO
            [   16204] Mon Nov 05 22:36:38 2012  INFO
            [   16204] Mon Nov 05 22:36:39 2012  INFO
            [   16204] Mon Nov 05 22:36:41 2012  INFO
            [   22248] Mon Nov 05 22:36:41 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5950.54 milliseconds (5.95054 seconds) DTR = 441.64 KBPS (0.43129 MBPS)
            [   12920] Mon Nov 05 22:36:41 2012  INFO
            [   12920] Mon Nov 05 22:36:43 2012  INFO
            [   12920] Mon Nov 05 22:36:45 2012  INFO
            [   22248] Mon Nov 05 22:36:45 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3924.5 milliseconds (3.9245 seconds)
            [   22248] Mon Nov 05 22:36:46 2012  INFO
            [   22240] Mon Nov 05 22:36:46 2012  INFO
            [   22240] Mon Nov 05 22:37:21 2012  INFO
            [   22240] Mon Nov 05 22:37:21 2012 ERROR
            DF043: Failed in GetNamedSecurityInfo(Seq 39)
            DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            [   22248] Mon Nov 05 22:37:26 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 39997.4 milliseconds (39.9974 seconds) DTR = 182.712 KBPS (0.17843 MBPS)
            [   22248] Mon Nov 05 22:37:28 2012  INFO
            - AdobeHelp
            [   22248] Mon Nov 05 22:37:28 2012 ERROR
            DW050: The following payload errors were found during install:
            DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            :: END TIMER :: [Total Timer] took 97603.1 milliseconds (97.6031 seconds) DTR = 2400.95 KBPS (2.34467 MBPS)
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 4 error(s), 0 warning(s)
            ----------- Payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 -----------
            ERROR: DF043: Failed in GetNamedSecurityInfo(Seq 39)
            ERROR: DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            ERROR: DW050: The following payload errors were found during install:
            ERROR: DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            ERROR: DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            [   22248] Mon Nov 05 22:37:29 2012  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 6.2.10.0
            Win OS version: 6.1.1.0  Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            CHECK : Another Native OS installer already running
            Create Required Folders
            Assuming install mode
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 1520.11 milliseconds (1.52011 seconds) DTR = 2.63138 KBPS (0.00256971 MBPS)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Updating media info for: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Dreamweaver CS6
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Updating media info for: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Updating media info for: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Updating media info for: {8E8021FF-7AA0-11E1-BF04-E98EE5274486}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12ja_JPLanguagePack\Install.db
            Updating media info for: {8FDB26FC-7AA0-11E1-BF04-E25246635842}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12en_USLanguagePack\Install.db
            Updating media info for: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9E0AF030-AC6B-11E0-8837-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Updating media info for: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Updating media info for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Updating media info for: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            Updating media info for: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Updating media info for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Updating media info for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Updating media info for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,6.2.10.0]
            ----------------- CreatePayloadSession: machine is x86 ---------------
            ______ Verify Dependency Subscribers ______
            BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: 1 (0,3)
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: 2 (0,5)
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: 3 (0,4)
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: 3 (0,4)
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: 4 (1,1)
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: 5 (0,1)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: 5 (0,1)
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: 5 (0,1)
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: 5 (0,1)
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: 6 (3,1)
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: 7 (4,1)
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: 7 (4,1)
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: 8 (12,0)
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: 9 (0,0)
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: 9 (0,0)
            END Operation order for all session payloads: mediaGroup (requires,satisfies)
            Setting property "installLanguage" to: en_US
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Overwrite property "DEVersion" to: 6.0
            Overwrite property "selfDelete" to: false
            Overwrite property "skipSync" to: 1
            Overwrite property "userASUPath" to:
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is: true
            Action string for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0  is none
            Value returned on lookup of payload: {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is: true
            Action string for {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1  is none
            Value returned on lookup of payload: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is: true
            Action string for {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180  is none
            Value returned on lookup of payload: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is: true
            Action string for {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148  is none
            Value returned on lookup of payload: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is: true
            Action string for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is: true
            Action string for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0  is none
            Action string for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0  is none
            Value returned on lookup of payload: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is: true
            Action string for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0  is none
            Value returned on lookup of payload: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is: true
            Action string for {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0  is none
            Value returned on lookup of payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is: true
            Action string for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is: true
            Action string for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0  is none
            Value returned on lookup of payload: {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is: true
            Action string for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0  is none
            Value returned on lookup of payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is: false
            Action string for {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0  is install
            Value returned on lookup of payload: {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is: false
            Action string for {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0  is none
            Payload {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Value returned on lookup of payload: {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is: false
            Action string for {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0  is none
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
            [   21012] Mon Nov 05 22:41:53 2012  INFO
            ::START TIMER:: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In ReinstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.3949 milliseconds (0.0033949 seconds)
            ::START TIMER:: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 4.16278 milliseconds (0.00416278 seconds)
            BEGIN InstallOperationsQueue Unordered operations
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation repair
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation repair
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation repair
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0:  with operation none
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation install
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation repair
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation repair
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation repair
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation install
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation repair
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation repair
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation repair
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation repair
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation repair
            END InstallOperationsQueue Unordered operations
            BEGIN InstallOperationsQueue Ordered operations
            END InstallOperationsQueue Ordered operations
            [   21012] Mon Nov 05 22:41:54 2012  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            ::START TIMER:: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}]
            [   20456] Mon Nov 05 22:41:54 2012  INFO
            Installer Operation: PayloadUninstaller
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Effective AdobeCode for: {354D20E6-A25F-4728-9DA6-C9003D8F2928} is {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Session includes local copy of payload for repair source
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Extracting assets...
            Extracting assets complete. Number assets: 1
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            [   20456] Mon Nov 05 22:41:55 2012  INFO
            Setting permission for: C:\Program Files\Common Files\Adobe\APE\3.3 Group/User:Everyone Access:GENERIC_READ(Seq 3)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{354D20E6-A25F-4728-9DA6-C9003D8F2928}.db
            Physical payload repair result:0
            [   21012] Mon Nov 05 22:41:55 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1009.31 milliseconds (1.00931 seconds)
            Updating driver data - Action: Add driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 0KB
            User specified overrideFile:
            Successfully updated the csu inventory for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            Calling the custom action code for pre-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            ::START TIMER:: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}]
            [   11496] Mon Nov 05 22:41:55 2012  INFO
            Installer Operation: ModifyThirdPartyPayloadOperation
            Modify Thirdparty payload
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            CommandLine: /q /norestart
            [   11496] Mon Nov 05 22:41:59 2012  INFO
            Third party payload completed.  Testing return code: 0
            [   21012] Mon Nov 05 22:41:59 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 3620.7 milliseconds (3.6207 seconds) DTR = 74.0188 KBPS (0.072284 MBPS)
            The csu inventory was not updated for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1, value of local var is -1
            Calling the custom action code for post-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            ::START TIMER:: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}]
            [   19280] Mon Nov 05 22:41:59 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            CommandLine: /q:a /c:"msiexec /i vcredist.msi /qn /norestart"
            [   19280] Mon Nov 05 22:42:03 2012  INFO
            [   21012] Mon Nov 05 22:42:03 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4211.32 milliseconds (4.21132 seconds) DTR = 1.89964 KBPS (0.00185512 MBPS)
            The csu inventory was not updated for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180, value of local var is -1
            Calling the custom action code for post-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            ::START TIMER:: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}]
            [   20584] Mon Nov 05 22:42:03 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            [   20584] Mon Nov 05 22:42:06 2012  INFO
            [   21012] Mon Nov 05 22:42:06 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 2746.76 milliseconds (2.74676 seconds) DTR = 144.17 KBPS (0.140791 MBPS)
            The csu inventory was not updated for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148, value of local var is -1
            Calling the custom action code for post-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            Calling the custom action code for pre-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            ::START TIMER:: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}]
            [   21900] Mon Nov 05 22:42:06 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Effective AdobeCode for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} is {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Evaluating condition# 1(Seq 31)
            Condition failed(Seq 31)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}.db
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 617.259 milliseconds (0.617259 seconds) DTR = 835.953 KBPS (0.816361 MBPS)
            [   21012] Mon Nov 05 22:42:07 2012  INFO
            Successfully updated the csu inventory for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PrePayloadReinstallProc
            [   21012] Mon Nov 05 22:42:12 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5009.52 milliseconds (5.00952 seconds)
            ::START TIMER:: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            [   20612] Mon Nov 05 22:42:12 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Effective AdobeCode for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} is {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}.db
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 522.536 milliseconds (0.522536 seconds) DTR = 61.2398 KBPS (0.0598045 MBPS)
            Successfully updated the csu inventory for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PostPayloadReinstallProc
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.51274 milliseconds (0.00251274 seconds)
            [   21012] Mon Nov 05 22:42:13 2012  INFO
            ::START TIMER:: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}]
            [    9588] Mon Nov 05 22:42:13 2012  INFO
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            CommandLine: -silent -eulaAccepted -programMenu WidgetBrowser.air
            [    9588] Mon Nov 05 22:42:17 2012  INFO
            [   21012] Mon Nov 05 22:42:17 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4630.54 milliseconds (4.63054 seconds)
            Successfully updated the csu inventory for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 return values 0:0
            Calling the custom action code for pre-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}]
            [   20536] Mon Nov 05 22:42:17 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Effective AdobeCode for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} is {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   20536] Mon Nov 05 22:42:20 2012  INFO
            Extracting assets complete. Number assets: 2
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [   20536] Mon Nov 05 22:42:22 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}.db
            [   21012] Mon Nov 05 22:42:22 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5021.74 milliseconds (5.02174 seconds) DTR = 101.957 KBPS (0.0995671 MBPS)
            Successfully updated the csu inventory for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            ::START TIMER:: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}]
            [    4924] Mon Nov 05 22:42:22 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            [    4924] Mon Nov 05 22:42:23 2012  INFO
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            CommandLine: appVersion=4.0.244 appId=chc pubId=4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 installerArg1=-silent installerArg2=-eulaAccepted installerArg3=-programMenu installerArg4=AdobeHelp.air
            [   21012] Mon Nov 05 22:42:23 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 317.344 milliseconds (0.317344 seconds)
            The csu inventory was not updated for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0, value of local var is -1
            Calling the custom action code for post-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [   21012] Mon Nov 05 22:42:28 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5009.51 milliseconds (5.00951 seconds) DTR = 0.798482 KBPS (0.000779767 MBPS)
            ::START TIMER:: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [   21676] Mon Nov 05 22:42:28 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Effective AdobeCode for: {36682D68-3834-487E-BA49-DFA4AB0A2E32} is {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   21676] Mon Nov 05 22:42:29 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [   21676] Mon Nov 05 22:42:30 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{36682D68-3834-487E-BA49-DFA4AB0A2E32}.db
            [   21012] Mon Nov 05 22:42:30 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1830.77 milliseconds (1.83077 seconds) DTR = 2342.19 KBPS (2.28729 MBPS)
            Successfully updated the csu inventory for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.53017 milliseconds (0.00253017 seconds)
            Calling the custom action code for pre-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            ::START TIMER:: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}]
            [   16500] Mon Nov 05 22:42:30 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Effective AdobeCode for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} is {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            Payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   16500] Mon Nov 05 22:42:32 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [   16500] Mon Nov 05 22:42:34 2012  INFO
            Evaluating condition# 1(Seq 98)
            Condition failed(Seq 98)
            [   16500] Mon Nov 05 22:42:37 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}.db
            [   21012] Mon Nov 05 22:42:37 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 6937.26 milliseconds (6.93726 seconds) DTR = 472.809 KBPS (0.461728 MBPS)
            Successfully updated the csu inventory for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}]
            [   14940] Mon Nov 05 22:42:37 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Effective AdobeCode for: {83463106-DD1C-4FE5-A61C-DF6715472AD4} is {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   14940] Mon Nov 05 22:42:39 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [   14940] Mon Nov 05 22:42:41 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{83463106-DD1C-4FE5-A61C-DF6715472AD4}.db
            [   21012] Mon Nov 05 22:42:41 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3924.07 milliseconds (3.92407 seconds) DTR = 215.083 KBPS (0.210042 MBPS)
            [   21012] Mon Nov 05 22:42:42 2012  INFO
            Successfully updated the csu inventory for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            ::START TIMER:: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}]
            [   15948] Mon Nov 05 22:42:42 2012  INFO
            Installer Operation: PayloadInstaller
            Request to install payload
            Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   15948] Mon Nov 05 22:43:21 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [   15948] Mon Nov 05 22:43:22 2012  INFO
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Everyone Access:GENERIC_ALL(Seq 29)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Administrators Access:GENERIC_ALL(Seq 30)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 31)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 32)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Everyone Access:GENERIC_ALL(Seq 34)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Administrators Access:GENERIC_ALL(Seq 35)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 36)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 37)
            Setting permission for: \\lefh-sfps-fs\fs-userrf$\fknippenberg\Application Data\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 39)
            [   15948] Mon Nov 05 22:43:22 2012 ERROR
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [   21012] Mon Nov 05 22:43:26 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 44328.6 milliseconds (44.3286 seconds) DTR = 121.005 KBPS (0.118169 MBPS)
            The csu inventory was not updated for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 cannot be installed due to dependent operation failure.
            Skipping payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 106223KB
            [   21012] Mon Nov 05 22:43:29 2012  INFO
            - Adobe Player for Embedding 3.3
            - Adobe CSXS Infrastructure CS6
            - Adobe Extension Manager CS6
            - Microsoft Visual C++ 2005 Redistributable Package (x86)
            - Microsoft Visual C++ 2008 Redistributable Package (x86)
            - Microsoft Visual C++ 2010 Redistributable Package (x86)
            - Suite Shared Configuration CS6
            - Adobe Dreamweaver Widget Browser
            - AdobeHelp
            - Adobe Linguistics CS6
            - Adobe CSXS Extensions CS6
            - Adobe ExtendScript Toolkit CS6
            Total components removed: 0
            [   21012] Mon Nov 05 22:43:29 2012 ERROR
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 100578 milliseconds (100.578 seconds) DTR = 28.2765 KBPS (0.0276138 MBPS)
            Please search the above error/warning string(s) to find when the error occurred.
            These errors resulted in installer Exit Code mentioned below.
            [   21012] Mon Nov 05 22:43:30 2012  INFO
            Exit Code: 7 - Unable to complete Silent workflow.
            Please see specific errors and warnings for troubleshooting. For example, ERROR: DF043, DW063 ...
            END - Installer Session
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 889.885 milliseconds (0.889885 seconds)
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: true
            [    7648] Mon Nov 05 22:46:44 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.87062 milliseconds (0.00387062 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 3.57117 milliseconds (0.00357117 seconds)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation repair
            [   21064] Mon Nov 05 22:46:44 2012  INFO
            [   21064] Mon Nov 05 22:46:45 2012  INFO
            [    7648] Mon Nov 05 22:46:45 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1011.4 milliseconds (1.0114 seconds) DTR = 19.7745 KBPS (0.019311 MBPS)
            [    9220] Mon Nov 05 22:46:45 2012  INFO
            [    9220] Mon Nov 05 22:46:51 2012  INFO
            [    7648] Mon Nov 05 22:46:51 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 5911.71 milliseconds (5.91171 seconds) DTR = 397.854 KBPS (0.38853 MBPS)
            [    7648] Mon Nov 05 22:46:52 2012  INFO
            [   12980] Mon Nov 05 22:46:52 2012  INFO
            [   12980] Mon Nov 05 22:46:56 2012  INFO
            [    7648] Mon Nov 05 22:46:56 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4657.95 milliseconds (4.65795 seconds) DTR = 7.72873 KBPS (0.00754759 MBPS)
            [   15432] Mon Nov 05 22:46:56 2012  INFO
            [   15432] Mon Nov 05 22:47:00 2012  INFO
            [    7648] Mon Nov 05 22:47:00 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3236.63 milliseconds (3.23663 seconds) DTR = 1444.71 KBPS (1.41085 MBPS)
            [   17468] Mon Nov 05 22:47:00 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 414.389 milliseconds (0.414389 seconds) DTR = 7953.87 KBPS (7.76745 MBPS)
            [    7648] Mon Nov 05 22:47:01 2012  INFO
            [    7648] Mon Nov 05 22:47:06 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5009.4 milliseconds (5.0094 seconds)
            [   21844] Mon Nov 05 22:47:06 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 518.449 milliseconds (0.518449 seconds) DTR = 61.7226 KBPS (0.060276 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.82597 milliseconds (0.00282597 seconds)
            Calling the custom action code for pre-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [   21900] Mon Nov 05 22:47:06 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{646423C1-2DBE-4662-B437-BFDDF6D6C024}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            [   21900] Mon Nov 05 22:47:11 2012  INFO
            Third party payload completed.  Testing return code: 9
            [    7648] Mon Nov 05 22:47:11 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4944.36 milliseconds (4.94436 seconds) DTR = 1.61801 KBPS (0.00158008 MBPS)
            Calling the custom action code for post-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [   19000] Mon Nov 05 22:47:11 2012  INFO
            [   19000] Mon Nov 05 22:47:13 2012  INFO
            [   19000] Mon Nov 05 22:47:16 2012  INFO
            [   19000] Mon Nov 05 22:47:17 2012  INFO
            [    7648] Mon Nov 05 22:47:17 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5423.17 milliseconds (5.42317 seconds) DTR = 188.819 KBPS (0.184394 MBPS)
            [     416] Mon Nov 05 22:47:17 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 310.918 milliseconds (0.310918 seconds)
            [    7648] Mon Nov 05 22:47:22 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5005.6 milliseconds (5.0056 seconds) DTR = 0.799105 KBPS (0.000780376 MBPS)
            [   10644] Mon Nov 05 22:47:22 2012  INFO
            [   10644] Mon Nov 05 22:47:23 2012  INFO
            [   10644] Mon Nov 05 22:47:24 2012  INFO
            [    7648] Mon Nov 05 22:47:24 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2112.13 milliseconds (2.11213 seconds) DTR = 1.89382 KBPS (0.00184943 MBPS)
            [    7648] Mon Nov 05 22:47:25 2012  INFO
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.1055 milliseconds (0.0021055 seconds)
            [    3632] Mon Nov 05 22:47:25 2012  INFO
            [    3632] Mon Nov 05 22:47:27 2012  INFO
            [    3632] Mon Nov 05 22:47:28 2012  INFO
            [    3632] Mon Nov 05 22:47:30 2012  INFO
            [    7648] Mon Nov 05 22:47:30 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 4720.85 milliseconds (4.72085 seconds) DTR = 108.455 KBPS (0.105913 MBPS)
            [   20472] Mon Nov 05 22:47:30 2012  INFO
            [   20472] Mon Nov 05 22:47:32 2012  INFO
            [   20472] Mon Nov 05 22:47:35 2012  INFO
            [    7648] Mon Nov 05 22:47:35 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 4913.94 milliseconds (4.91394 seconds) DTR = 104.193 KBPS (0.101751 MBPS)
            [   18892] Mon Nov 05 22:47:35 2012  INFO
            [   18892] Mon Nov 05 22:48:09 2012  INFO
            [   18892] Mon Nov 05 22:48:09 2012 ERROR
            [    7648] Mon Nov 05 22:48:13 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 38348 milliseconds (38.348 seconds) DTR = 6.36278 KBPS (0.00621365 MBPS)
            [    7648] Mon Nov 05 22:48:16 2012  INFO
            Total components installed: 0
            Successfully repaired 12 components:
            - AdobeHelp
            [    7648] Mon Nov 05 22:48:16 2012 ERROR
            :: END TIMER :: [Total Timer] took 96505.8 milliseconds (96.5058 seconds) DTR = 15.9576 KBPS (0.0155836 MBPS)
            [    7648] Mon Nov 05 22:48:17 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 1603.25 milliseconds (1.60325 seconds)
            [   22132] Mon Nov 05 22:53:56 2012  INFO
            [   22132] Mon Nov 05 22:53:59 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.60642 milliseconds (0.00360642 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.93693 milliseconds (0.00193693 seconds)
            [   22132] Mon Nov 05 22:54:00 2012  INFO
            [   13540] Mon Nov 05 22:54:00 2012  INFO
            [   13540] Mon Nov 05 22:54:01 2012  INFO
            [   22132] Mon Nov 05 22:54:01 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1009.84 milliseconds (1.00984 seconds)
            [   22068] Mon Nov 05 22:54:01 2012  INFO
            [   22068] Mon Nov 05 22:54:04 2012  INFO
            [   22132] Mon Nov 05 22:54:04 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 3612.33 milliseconds (3.61233 seconds) DTR = 63.1172 KBPS (0.0616379 MBPS)
            [   22132] Mon Nov 05 22:54:05 2012  INFO
            [   21464] Mon Nov 05 22:54:05 2012  INFO
            [   21464] Mon Nov 05 22:54:08 2012  INFO
            [   22132] Mon Nov 05 22:54:08 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 3235.79 milliseconds (3.23579 seconds) DTR = 6.18086 KBPS (0.006036 MBPS)
            [    9408] Mon Nov 05 22:54:08 2012  INFO
            [    9408] Mon Nov 05 22:54:09 2012  INFO
            [    9408] Mon Nov 05 22:54:11 2012  INFO
            [   22132] Mon Nov 05 22:54:11 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 2740.57 milliseconds (2.74057 seconds) DTR = 143.036 KBPS (0.139684 MBPS)
            [   19216] Mon Nov 05 22:54:11 2012  INFO
            [   19216] Mon Nov 05 22:54:12 2012  INFO
            [   22132] Mon Nov 05 22:54:12 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 418.685 milliseconds (0.418685 seconds) DTR = 9.55371 KBPS (0.0093298 MBPS)
            [   22132] Mon Nov 05 22:54:17 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5010.26 milliseconds (5.01026 seconds)
            [    9388] Mon Nov 05 22:54:17 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 417.821 milliseconds (0.417821 seconds) DTR = 76.5877 KBPS (0.0747927 MBPS)
            [   22132] Mon Nov 05 22:54:18 2012  INFO
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 1.45229 milliseconds (0.00145229 seconds)
            [   15372] Mon Nov 05 22:54:18 2012  INFO
            [   15372] Mon Nov 05 22:54:22 2012  INFO
            [   22132] Mon Nov 05 22:54:22 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4124.03 milliseconds (4.12403 seconds) DTR = 0.969926 KBPS (0.000947193 MBPS)
            [   19400] Mon Nov 05 22:54:22 2012  INFO
            [   19400] Mon Nov 05 22:54:24 2012  INFO
            [   19400] Mon Nov 05 22:54:27 2012  INFO
            [   19400] Mon Nov 05 22:54:28 2012  INFO
            [   22132] Mon Nov 05 22:54:28 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5720.98 milliseconds (5.72098 seconds) DTR = 89.4951 KBPS (0.0873976 MBPS)
            [   18580] Mon Nov 05 22:54:28 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 218.808 milliseconds (0.218808 seconds)
            [   22132] Mon Nov 05 22:54:33 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5011.63 milliseconds (5.01163 seconds)
            [   15196] Mon Nov 05 22:54:33 2012  INFO
            [   15196] Mon Nov 05 22:54:34 2012  INFO
            [   22132] Mon Nov 05 22:54:34 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1331.61 milliseconds (1.33161 seconds)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.32668 milliseconds (0.00132668 seconds)
            [   16740] Mon Nov 05 22:54:34 2012  INFO
            [   16740] Mon Nov 05 22:54:35 2012  INFO
            [   16740] Mon Nov 05 22:54:36 2012  INFO
            [   16740] Mon Nov 05 22:54:38 2012  INFO
            [   16740] Mon Nov 05 22:54:40 2012  INFO
            [   22132] Mon Nov 05 22:54:40 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5922 milliseconds (5.922 seconds) DTR = 88.4836 KBPS (0.0864097 MBPS)
            [   22132] Mon Nov 05 22:54:41 2012  INFO
            [   17516] Mon Nov 05 22:54:41 2012  INFO
            [   17516] Mon Nov 05 22:54:42 2012  INFO
            [   17516] Mon Nov 05 22:54:44 2012  INFO
            [   22132] Mon Nov 05 22:54:44 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3736.32 milliseconds (3.73632 seconds) DTR = 137.033 KBPS (0.133821 MBPS)
            [   22132] Mon Nov 05 22:54:45 2012  INFO
            [   21560] Mon Nov 05 22:54:45 2012  INFO
            [   21560] Mon Nov 05 22:55:22 2012  INFO
            [   21560] Mon Nov 05 22:55:22 2012 ERROR
            [   22132] Mon Nov 05 22:55:27 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 42303.6 milliseconds (42.3036 seconds) DTR = 20.802 KBPS (0.0203145 MBPS)
            [   22132] Mon Nov 05 22:55:29 2012  INFO
            - AdobeHelp
            [   22132] Mon Nov 05 22:55:29 2012 ERROR
            :: END TIMER :: [Total Timer] took 95532 milliseconds (95.532 seconds) DTR = 21.061 KBPS (0.0205674 MBPS)
            [   22132] Mon Nov 05 22:55:30 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 912.334 milliseconds (0.912334 seconds)
            [   21748] Mon Nov 05 23:00:51 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.70036 milliseconds (0.00270036 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.78788 milliseconds (0.00278788 seconds)
            [   10812] Mon Nov 05 23:00:51 2012  INFO
            [   10812] Mon Nov 05 23:00:52 2012  INFO
            [   21748] Mon Nov 05 23:00:52 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1109.52 milliseconds (1.10952 seconds)
            [   19432] Mon Nov 05 23:00:52 2012  INFO
            [   19432] Mon Nov 05 23:00:53 2012  INFO
            [   19432] Mon Nov 05 23:00:59 2012  INFO
            [   21748] Mon Nov 05 23:00:59 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6923.49 milliseconds (6.92349 seconds) DTR = 38.1311 KBPS (0.0372374 MBPS)
            [   18244] Mon Nov 05 23:00:59 2012  INFO
            [   18244] Mon Nov 05 23:01:00 2012  INFO
            [   18244] Mon Nov 05 23:01:03 2012  INFO
            [   21748] Mon Nov 05 23:01:03 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 3820.97 milliseconds (3.82097 seconds) DTR = 4.18742 KBPS (0.00408928 MBPS)
            [   20112] Mon Nov 05 23:01:03 2012  INFO
            [   20112] Mon Nov 05 23:01:07 2012  INFO
            [   21748] Mon Nov 05 23:01:07 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3210.28 milliseconds (3.21028 seconds) DTR = 122.108 KBPS (0.119246 MBPS)
            [   21092] Mon Nov 05 23:01:07 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 418.839 milliseconds (0.418839 seconds) DTR = 9.5502 KBPS (0.00932637 MBPS)
            [   21748] Mon Nov 05 23:01:12 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5009.23 milliseconds (5.00923 seconds) DTR = 88.6363 KBPS (0.0865589 MBPS)
            [   17608] Mon Nov 05 23:01:12 2012  INFO
            [   17608] Mon Nov 05 23:01:13 2012  INFO
            [   21748] Mon Nov 05 23:01:13 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 418.101 milliseconds (0.418101 seconds) DTR = 76.5366 KBPS (0.0747428 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 1.33883 milliseconds (0.00133883 seconds)
            [   21376] Mon Nov 05 23:01:13 2012  INFO
            [   21376] Mon Nov 05 23:01:17 2012  INFO
            [   21748] Mon Nov 05 23:01:17 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4535.19 milliseconds (4.53519 seconds) DTR = 1.76398 KBPS (0.00172264 MBPS)
            [   21748] Mon Nov 05 23:01:18 2012  INFO
            [   16352] Mon Nov 05 23:01:18 2012  INFO
            [   16352] Mon Nov 05 23:01:20 2012  INFO
            [   16352] Mon Nov 05 23:01:23 2012  INFO
            [   21748] Mon Nov 05 23:01:23 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5424.48 milliseconds (5.42448 seconds) DTR = 188.774 KBPS (0.18435 MBPS)
            [   13456] Mon Nov 05 23:01:23 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 311.685 milliseconds (0.311685 seconds)
            [   21748] Mon Nov 05 23:01:28 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5009.16 milliseconds (5.00916 seconds)
            [    3060] Mon Nov 05 23:01:29 2012  INFO
            [    3060] Mon Nov 05 23:01:30 2012  INFO
            [   21748] Mon Nov 05 23:01:30 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1321.04 milliseconds (1.32104 seconds)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.29547 milliseconds (0.00129547 seconds)
            [   18720] Mon Nov 05 23:01:30 2012  INFO
            [   18720] Mon Nov 05 23:01:33 2012  INFO
            [   18720] Mon Nov 05 23:01:34 2012  INFO
            [   18720] Mon Nov 05 23:01:35 2012  INFO
            [   18720] Mon Nov 05 23:01:36 2012  INFO
            [   21748] Mon Nov 05 23:01:36 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5823.02 milliseconds (5.82302 seconds) DTR = 96.857 KBPS (0.0945869 MBPS)
            [   15576] Mon Nov 05 23:01:36 2012  INFO
            [   15576] Mon Nov 05 23:01:38 2012  INFO
            [   15576] Mon Nov 05 23:01:40 2012  INFO
            [   21748] Mon Nov 05 23:01:40 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3921.03 milliseconds (3.92103 seconds) DTR = 130.578 KBPS (0.127518 MBPS)
            [   22204] Mon Nov 05 23:01:40 2012  INFO
            [   22204] Mon Nov 05 23:02:21 2012  INFO
            [   22204] Mon Nov 05 23:02:21 2012 ERROR
            [   21748] Mon Nov 05 23:02:28 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 47750 milliseconds (47.75 seconds) DTR = 45.1519 KBPS (0.0440936 MBPS)
            [   21748] Mon Nov 05 23:02:30 2012  INFO
            - AdobeHelp
            [   21748] Mon Nov 05 23:02:30 2012 ERROR
            :: END TIMER :: [Total Timer] took 104246 milliseconds (104.246 seconds) DTR = 2.07201 KBPS (0.00202345 MBPS)
            [   21748] Mon Nov 05 23:02:31 2012  INFO
            CHECK : Credentials
            Assuming uninstall mode
            Lookup for master payload
            Setting property "driverAdobeCode" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
            Setting property "mediaSignature" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
            Setting property "removeUserPrefs" to: 1
            Overwrite property "userASUPath" to: C:\Program Files\Common Files\Adobe\OOBE\PDApp\core\..\D6
            {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 not installed
            {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 not installed
            {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 not installed
            [   19816] Mon Nov 05 23:02:54 2012  WARN
            DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
            [   19816] Mon Nov 05 23:02:54 2012  INFO
            [   19816] Mon Nov 05 23:02:59 2012  INFO
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation remove
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation remove
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation remove
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation none
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation remove
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation remove
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation remove
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation none
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation remove
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation remove
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation remove
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation remove
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation remove
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation remove
            Calling the custom action code for pre-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            [   22192] Mon Nov 05 23:02:59 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 104.407 milliseconds (0.104407 seconds)
            The csu inventory was not updated for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            [   20440] Mon Nov 05 23:02:59 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 105.198 milliseconds (0.105198 seconds)
            The csu inventory was not updated for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            [   20584] Mon Nov 05 23:02:59 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 105.572 milliseconds (0.105572 seconds)
            The csu inventory was not updated for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            [   22112] Mon Nov 05 23:02:59 2012  INFO
            Unable to remove payload.
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 110.243 milliseconds (0.110243 seconds)
            Calling the custom action code for post-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            [   21956] Mon Nov 05 23:02:59 2012  INFO
            [   21956] Mon Nov 05 23:03:00 2012  INFO
            [   19816] Mon Nov 05 23:03:00 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 105.229 milliseconds (0.105229 seconds)
            The csu inventory was not updated for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [   20612] Mon Nov 05 23:03:00 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 106.23 milliseconds (0.10623 seconds)
            Calling the custom action code for post-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            Calling the custom action code for pre-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            [   19948] Mon Nov 05 23:03:00 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 110.018 milliseconds (0.110018 seconds)
            The csu inventory was not updated for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            [   21756] Mon Nov 05 23:03:00 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 105.293 milliseconds (0.105293 seconds)
            The csu inventory was not updated for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            [   21888] Mon Nov 05 23:03:00 2012  INFO
            [   19816] Mon Nov 05 23:03:01 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 105.343 milliseconds (0.105343 seconds)
            Calling the custom action code for post-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            Calling the custom action code for pre-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            [   14616] Mon Nov 05 23:03:01 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 104.91 milliseconds (0.10491 seconds)
            Calling the custom action code for post-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            [   18236] Mon Nov 05 23:03:01 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 105.788 milliseconds (0.105788 seconds)
            Calling the custom action code for post-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            [   19268] Mon Nov 05 23:03:01 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 210.354 milliseconds (0.210354 seconds)
            The csu inventory was not updated for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            [   19816] Mon Nov 05 23:03:02 2012  INFO
            Updating driver data successful. Driver entry was removed. ARP estimated size 106223KB
            [   19816] Mon Nov 05 23:03:04 2012  INFO
            Total components repaired: 0
            Successfully removed 1 component:
            Restarting your computer is recommended:
            In order to complete the installation, please restart the computer
            Begin cleaning up local media db.
            [   19816] Mon Nov 05 23:03:08 2012  INFO
            Done cleaning up local media db.
            :: END TIMER :: [Total Timer] took 13930 milliseconds (13.93 seconds) DTR = 76.9563 KBPS (0.0751527 MBPS)
            [   19816] Mon Nov 05 23:03:09 2012  INFO
            Uninstalling AAM
            AAM Uninstall Status: 1 and 0
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 0 error(s), 1 warning(s)
            WARNING: DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
            Exit Code: 0 - No error.
            Please see specific errors and warnings for troubleshooting. For example, WARNING: DW039 ...
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 6.2.10.0
            Win OS version: 6.1.1.0  Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            CHECK : Another Native OS installer already running
            Create Required Folders
            Assuming install mode
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 1817.55 milliseconds (1.81755 seconds) DTR = 550.191 KBPS (0.537296 MBPS)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Updating media info for: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Dreamweaver CS6
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Updating media info for: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Updating media info for: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Updating media info for: {8E8021FF-7AA0-11E1-BF04-E98EE5274486}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12ja_JPLanguagePack\Install.db
            Updating media info for: {8FDB26FC-7AA0-11E1-BF04-E25246635842}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12en_USLanguagePack\Install.db
            Updating media info for: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9E0AF030-AC6B-11E0-8837-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Updating media info for: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Updating media info for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Updating media info for: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            Updating media info for: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Updating media info for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Updating media info for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Updating media info for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,6.2.10.0]
            ----------------- CreatePayloadSession: machine is x86 ---------------
            [   18256] Mon Nov 05 23:07:50 2012  INFO
            ______ Verify Dependency Subscribers ______
            BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: 1 (0,3)
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: 2 (0,5)
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: 3 (0,4)
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: 3 (0,4)
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: 4 (1,1)
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: 5 (0,1)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: 5 (0,1)
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: 5 (0,1)
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: 5 (0,1)
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: 6 (3,1)
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: 7 (4,1)
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: 7 (4,1)
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: 8 (12,0)
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: 9 (0,0)
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: 9 (0,0)
            END Operation order for all session payloads: mediaGroup (requires,satisfies)
            Setting property "installLanguage" to: en_US
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Overwrite property "DEVersion" to: 6.0
            Overwrite property "selfDelete" to: false
            Overwrite property "skipSync" to: 1
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is: true
            Action string for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0  is none
            Value returned on lookup of payload: {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is: true
            Action string for {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1  is none
            Value returned on lookup of payload: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is: true
            Action string for {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180  is none
            Value returned on lookup of payload: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is: true
            Action string for {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148  is none
            Value returned on lookup of payload: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is: true
            Action string for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is: true
            Action string for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0  is none
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: false
            Action string for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0  is none
            Value returned on lookup of payload: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is: true
            Action string for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0  is none
            Value returned on lookup of payload: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is: true
            Action string for {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0  is none
            Value returned on lookup of payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is: true
            Action string for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is: true
            Action string for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0  is none
            Value returned on lookup of payload: {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is: true
            Action string for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0  is none
            Value returned on lookup of payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is: false
            Action string for {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0  is install
            Value returned on lookup of payload: {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is: false
            Action string for {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0  is none
            Payload {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Value returned on lookup of payload: {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is: false
            Action string for {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0  is none
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
            [   18256] Mon Nov 05 23:07:53 2012  INFO
            ::START TIMER:: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In ReinstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.6518 milliseconds (0.0036518 seconds)
            [   18256] Mon Nov 05 23:07:54 2012  INFO
            ::START TIMER:: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 4.02582 milliseconds (0.00402582 seconds)
            BEGIN InstallOperationsQueue Unordered operations
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation repair
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation repair
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation repair
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0:  with operation none
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation install
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation repair
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation repair
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation repair
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation install
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation repair
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation install
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation repair
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation repair
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation repair
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation repair
            END InstallOperationsQueue Unordered operations
            BEGIN InstallOperationsQueue Ordered operations
            END InstallOperationsQueue Ordered operations
            [   18256] Mon Nov 05 23:07:55 2012  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            ::START TIMER:: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}]
            [   10572] Mon Nov 05 23:07:55 2012  INFO
            Installer Operation: PayloadUninstaller
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Effective AdobeCode for: {354D20E6-A25F-4728-9DA6-C9003D8F2928} is {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Session includes local copy of payload for repair source
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Extracting assets...
            [   10572] Mon Nov 05 23:07:56 2012  INFO
            Extracting assets complete. Number assets: 1
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Setting permission for: C:\Program Files\Common Files\Adobe\APE\3.3 Group/User:Everyone Access:GENERIC_READ(Seq 3)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{354D20E6-A25F-4728-9DA6-C9003D8F2928}.db
            Physical payload repair result:0
            [   18256] Mon Nov 05 23:07:56 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1260.18 milliseconds (1.26018 seconds)
            Updating driver data - Action: Add driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 0KB
            User specified overrideFile:
            [   18256] Mon Nov 05 23:07:57 2012  INFO
            Successfully updated the csu inventory for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            Calling the custom action code for pre-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            ::START TIMER:: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}]
            [   12820] Mon Nov 05 23:07:57 2012  INFO
            Installer Operation: ModifyThirdPartyPayloadOperation
            Modify Thirdparty payload
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            CommandLine: /q /norestart
            [   12820] Mon Nov 05 23:08:03 2012  INFO
            Third party payload completed.  Testing return code: 0
            [   18256] Mon Nov 05 23:08:03 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6625.64 milliseconds (6.62564 seconds) DTR = 31.9969 KBPS (0.031247 MBPS)
            The csu inventory was not updated for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1, value of local var is -1
            Calling the custom action code for post-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            ::START TIMER:: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}]
            [   20460] Mon Nov 05 23:08:03 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            CommandLine: /q:a /c:"msiexec /i vcredist.msi /qn /norestart"
            [   20460] Mon Nov 05 23:08:08 2012  INFO
            [   18256] Mon Nov 05 23:08:08 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 4444.13 milliseconds (4.44413 seconds) DTR = 28.802 KBPS (0.028127 MBPS)
            The csu inventory was not updated for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180, value of local var is -1
            Calling the custom action code for post-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            ::START TIMER:: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}]
            [   11216] Mon Nov 05 23:08:08 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            [   11216] Mon Nov 05 23:08:11 2012  INFO
            [   18256] Mon Nov 05 23:08:11 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3009.73 milliseconds (3.00973 seconds) DTR = 130.244 KBPS (0.127191 MBPS)
            The csu inventory was not updated for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148, value of local var is -1
            Calling the custom action code for post-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            Calling the custom action code for pre-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            ::START TIMER:: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}]
            [   14012] Mon Nov 05 23:08:11 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Effective AdobeCode for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} is {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Evaluating condition# 1(Seq 31)
            Condition failed(Seq 31)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}.db
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 409.463 milliseconds (0.409463 seconds) DTR = 9.76889 KBPS (0.00953993 MBPS)
            [   18256] Mon Nov 05 23:08:12 2012  INFO
            Successfully updated the csu inventory for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PrePayloadReinstallProc
            [   18256] Mon Nov 05 23:08:17 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5009.4 milliseconds (5.0094 seconds) DTR = 29.5444 KBPS (0.028852 MBPS)
            ::START TIMER:: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            [   22332] Mon Nov 05 23:08:17 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Effective AdobeCode for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} is {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}.db
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 422.494 milliseconds (0.422494 seconds) DTR = 75.7406 KBPS (0.0739655 MBPS)
            Successfully updated the csu inventory for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PostPayloadReinstallProc
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.86123 milliseconds (0.00286123 seconds)
            Calling the custom action code for pre-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            ::START TIMER:: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}]
            [   18800] Mon Nov 05 23:08:17 2012  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            CommandLine: -silent -eulaAccepted -programMenu WidgetBrowser.air
            [   18800] Mon Nov 05 23:08:22 2012  INFO
            [   18256] Mon Nov 05 23:08:22 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 5151.14 milliseconds (5.15114 seconds)
            Successfully updated the csu inventory for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 return values 0:0
            Calling the custom action code for post-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            Calling the custom action code for pre-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}]
            [   10236] Mon Nov 05 23:08:22 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Effective AdobeCode for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} is {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   10236] Mon Nov 05 23:08:24 2012  INFO
            Extracting assets complete. Number assets: 2
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [   10236] Mon Nov 05 23:08:28 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}.db
            [   10236] Mon Nov 05 23:08:29 2012  INFO
            [   18256] Mon Nov 05 23:08:29 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 6227.53 milliseconds (6.22753 seconds) DTR = 165.074 KBPS (0.161205 MBPS)
            Successfully updated the csu inventory for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            ::START TIMER:: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}]
            [   19168] Mon Nov 05 23:08:29 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            CommandLine: appVersion=4.0.244 appId=chc pubId=4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 installerArg1=-silent installerArg2=-eulaAccepted installerArg3=-programMenu installerArg4=AdobeHelp.air
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 218.848 milliseconds (0.218848 seconds)
            The csu inventory was not updated for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0, value of local var is -1
            Calling the custom action code for post-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [   18256] Mon Nov 05 23:08:34 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5008.94 milliseconds (5.00894 seconds)
            ::START TIMER:: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [   17928] Mon Nov 05 23:08:34 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Effective AdobeCode for: {36682D68-3834-487E-BA49-DFA4AB0A2E32} is {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   17928] Mon Nov 05 23:08:35 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{36682D68-3834-487E-BA49-DFA4AB0A2E32}.db
            [   17928] Mon Nov 05 23:08:36 2012  INFO
            [   18256] Mon Nov 05 23:08:36 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1620.06 milliseconds (1.62006 seconds)
            Successfully updated the csu inventory for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.5309 milliseconds (0.0015309 seconds)
            Calling the custom action code for pre-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            ::START TIMER:: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}]
            [   20648] Mon Nov 05 23:08:36 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            [   20648] Mon Nov 05 23:08:37 2012  INFO
            Effective AdobeCode for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} is {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            Payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   20648] Mon Nov 05 23:08:39 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [   20648] Mon Nov 05 23:08:40 2012  INFO
            Evaluating condition# 1(Seq 98)
            Condition failed(Seq 98)
            [   20648] Mon Nov 05 23:08:42 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}.db
            [   18256] Mon Nov 05 23:08:42 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5504.04 milliseconds (5.50404 seconds) DTR = 92.2959 KBPS (0.0901327 MBPS)
            [   18256] Mon Nov 05 23:08:43 2012  INFO
            Successfully updated the csu inventory for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}]
            [   14932] Mon Nov 05 23:08:43 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Effective AdobeCode for: {83463106-DD1C-4FE5-A61C-DF6715472AD4} is {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   14932] Mon Nov 05 23:08:45 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [   14932] Mon Nov 05 23:08:46 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{83463106-DD1C-4FE5-A61C-DF6715472AD4}.db
            [   14932] Mon Nov 05 23:08:47 2012  INFO
            [   18256] Mon Nov 05 23:08:47 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 4222.39 milliseconds (4.22239 seconds) DTR = 0.94733 KBPS (0.000925127 MBPS)
            [   18256] Mon Nov 05 23:08:48 2012  INFO
            Successfully updated the csu inventory for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            ::START TIMER:: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}]
            [   18524] Mon Nov 05 23:08:48 2012  INFO
            Installer Operation: PayloadInstaller
            Request to install payload
            Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [   18524] Mon Nov 05 23:09:31 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Everyone Access:GENERIC_ALL(Seq 29)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Administrators Access:GENERIC_ALL(Seq 30)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 31)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 32)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Everyone Access:GENERIC_ALL(Seq 34)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Administrators Access:GENERIC_ALL(Seq 35)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 36)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 37)
            Setting permission for: \\lefh-sfps-fs\fs-userrf$\fknippenberg\Application Data\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 39)
            [   18524] Mon Nov 05 23:09:31 2012 ERROR
            DF043: Failed in GetNamedSecurityInfo(Seq 39)
            DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{9ED43782-7D6E-4428-8FF9-EC78C4EF28E2}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [   18256] Mon Nov 05 23:09:36 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 48334.8 milliseconds (48.3348 seconds) DTR = 11.1721 KBPS (0.0109102 MBPS)
            The csu inventory was not updated for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 cannot be installed due to dependent operation failure.
            Skipping payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 106223KB
            [   18256] Mon Nov 05 23:09:38 2012  INFO
            Successfully installed 1 component:
            - Adobe Dreamweaver Widget Browser
            Successfully repaired 11 components:
            - Adobe Player for Embedding 3.3
            - Adobe CSXS Infrastructure CS6
            - Adobe Extension Manager CS6
            - Microsoft Visual C++ 2005 Redistributable Package (x86)
            - Microsoft Visual C++ 2008 Redistributable Package (x86)
            - Microsoft Visual C++ 2010 Redistributable Package (x86)
            - Suite Shared Configuration CS6
            - AdobeHelp
            - Adobe Linguistics CS6
            - Adobe CSXS Extensions CS6
            - Adobe ExtendScript Toolkit CS6
            Total components removed: 0
            [   18256] Mon Nov 05 23:09:38 2012 ERROR
            DW050: The following payload errors were found during install:
            DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 110627 milliseconds (110.627 seconds) DTR = 39.6288 KBPS (0.0387 MBPS)
            - 0 fatal error(s), 4 error(s), 0 warning(s)
            ----------- Payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 -----------
            ERROR: DF043: Failed in GetNamedSecurityInfo(Seq 39)
            ERROR: DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            ERROR: DW050: The following payload errors were found during install:
            ERROR: DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            ERROR: DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            Please search the above error/warning string(s) to find when the error occurred.
            These errors resulted in installer Exit Code mentioned below.
            [   18256] Mon Nov 05 23:09:39 2012  INFO
            Exit Code: 7 - Unable to complete Silent workflow.
            Please see specific errors and warnings for troubleshooting. For example, ERROR: DF043, DW063 ...
            END - Installer Session
            CHECK : Credentials
            [   18808] Mon Nov 05 23:13:27 2012  WARN
            [   18808] Mon Nov 05 23:13:27 2012  INFO
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: true
            [   18808] Mon Nov 05 23:13:31 2012  INFO
            [   19524] Mon Nov 05 23:13:31 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 104.826 milliseconds (0.104826 seconds)
            [   22276] Mon Nov 05 23:13:31 2012  INFO
            [   18808] Mon Nov 05 23:13:32 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 104.992 milliseconds (0.104992 seconds)
            [   17052] Mon Nov 05 23:13:32 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 105.016 milliseconds (0.105016 seconds)
            [   21632] Mon Nov 05 23:13:32 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 104.83 milliseconds (0.10483 seconds)
            [   20376] Mon Nov 05 23:13:32 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 105.102 milliseconds (0.105102 seconds)
            [   21724] Mon Nov 05 23:13:32 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 105.251 milliseconds (0.105251 seconds)
            [   18808] Mon Nov 05 23:13:33 2012  INFO
            [    5832] Mon Nov 05 23:13:33 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 105.247 milliseconds (0.105247 seconds)
            [   18732] Mon Nov 05 23:13:33 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 105.222 milliseconds (0.105222 seconds)
            [   21056] Mon Nov 05 23:13:33 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 104.986 milliseconds (0.104986 seconds)
            [   19212] Mon Nov 05 23:13:33 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 105.096 milliseconds (0.105096 seconds)
            [   20324] Mon Nov 05 23:13:33 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 104.741 milliseconds (0.104741 seconds)
            [   18808] Mon Nov 05 23:13:34 2012  INFO
            [   10260] Mon Nov 05 23:13:34 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 104.516 milliseconds (0.104516 seconds)
            [   18808] Mon Nov 05 23:13:36 2012  INFO
            Total components installed: 0
            [   18808] Mon Nov 05 23:13:39 2012  INFO
            :: END TIMER :: [Total Timer] took 12347.7 milliseconds (12.3477 seconds) DTR = 77.7474 KBPS (0.0759252 MBPS)
            [   18808] Mon Nov 05 23:13:40 2012  INFO
            Uninstalling AAM
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 2389.66 milliseconds (2.38966 seconds) DTR = 10048.3 KBPS (9.81279 MBPS)
            Updated source path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12ja_JPLanguagePack\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12en_USLanguagePack\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            Setting property "installSourcePath" to: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            [    7836] Mon Nov 05 23:27:16 2012  INFO
            [    7836] Mon Nov 05 23:27:18 2012  INFO
            [    7836] Mon Nov 05 23:27:19 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 311.796 milliseconds (0.311796 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 3.74098 milliseconds (0.00374098 seconds)
            [     916] Mon Nov 05 23:27:19 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            [     916] Mon Nov 05 23:27:20 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            [     916] Mon Nov 05 23:27:21 2012  INFO
            [     916] Mon Nov 05 23:27:22 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            [    7836] Mon Nov 05 23:27:22 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 2311.15 milliseconds (2.31115 seconds) DTR = 100.383 KBPS (0.09803 MBPS)
            [    5704] Mon Nov 05 23:27:23 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            [    5704] Mon Nov 05 23:27:29 2012  INFO
            [    7836] Mon Nov 05 23:27:30 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 7021.23 milliseconds (7.02123 seconds) DTR = 41.5881 KBPS (0.0406134 MBPS)
            [    6996] Mon Nov 05 23:27:30 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            [    6996] Mon Nov 05 23:27:35 2012  INFO
            [    7836] Mon Nov 05 23:27:35 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 5114.38 milliseconds (5.11438 seconds) DTR = 62.5687 KBPS (0.0611022 MBPS)
            [    6220] Mon Nov 05 23:27:35 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            [    6220] Mon Nov 05 23:27:40 2012  INFO
            [    7836] Mon Nov 05 23:27:40 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 5142.89 milliseconds (5.14289 seconds) DTR = 167.999 KBPS (0.164061 MBPS)
            [    7000] Mon Nov 05 23:27:40 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            [    7000] Mon Nov 05 23:27:41 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            [    7836] Mon Nov 05 23:27:41 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 913.915 milliseconds (0.913915 seconds) DTR = 17.5071 KBPS (0.0170968 MBPS)
            [    7836] Mon Nov 05 23:27:42 2012  INFO
            [    7836] Mon Nov 05 23:27:47 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5004.27 milliseconds (5.00427 seconds) DTR = 194.234 KBPS (0.189682 MBPS)
            [    6884] Mon Nov 05 23:27:47 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 715.394 milliseconds (0.715394 seconds) DTR = 44.7306 KBPS (0.0436822 MBPS)
            [    7836] Mon Nov 05 23:27:48 2012  INFO
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 1.3822 milliseconds (0.0013822 seconds)
            [    4084] Mon Nov 05 23:27:48 2012  INFO
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            [    4084] Mon Nov 05 23:27:55 2012  INFO
            Third party payload completed.  Testing return code: 9
            [    7836] Mon Nov 05 23:27:55 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 7255.69 milliseconds (7.25569 seconds) DTR = 2.20517 KBPS (0.00215348 MBPS)
            [    3388] Mon Nov 05 23:27:55 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [    3388] Mon Nov 05 23:27:58 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [    3388] Mon Nov 05 23:28:03 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [    3388] Mon Nov 05 23:28:04 2012  INFO
            [    7836] Mon Nov 05 23:28:04 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 8828.16 milliseconds (8.82816 seconds) DTR = 57.9962 KBPS (0.0566369 MBPS)
            [    1884] Mon Nov 05 23:28:04 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 209.778 milliseconds (0.209778 seconds)
            [    7836] Mon Nov 05 23:28:09 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5004.76 milliseconds (5.00476 seconds) DTR = 25.5756 KBPS (0.0249762 MBPS)
            [    2488] Mon Nov 05 23:28:10 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [    2488] Mon Nov 05 23:28:11 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [    2488] Mon Nov 05 23:28:12 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [    7836] Mon Nov 05 23:28:12 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2918.83 milliseconds (2.91883 seconds) DTR = 176.783 KBPS (0.17264 MBPS)
            [    7836] Mon Nov 05 23:28:13 2012  INFO
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.39882 milliseconds (0.00139882 seconds)
            [    3364] Mon Nov 05 23:28:13 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [    3364] Mon Nov 05 23:28:15 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [    3364] Mon Nov 05 23:28:18 2012  INFO
            [    3364] Mon Nov 05 23:28:20 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [    3364] Mon Nov 05 23:28:21 2012  INFO
            [    3364] Mon Nov 05 23:28:23 2012  INFO
            [    7836] Mon Nov 05 23:28:23 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 10712.9 milliseconds (10.7129 seconds) DTR = 49.2863 KBPS (0.0481311 MBPS)
            [    7836] Mon Nov 05 23:28:25 2012  INFO
            [    4796] Mon Nov 05 23:28:25 2012  INFO
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [    4796] Mon Nov 05 23:28:27 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [    4796] Mon Nov 05 23:28:32 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [    7836] Mon Nov 05 23:28:32 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 6516.91 milliseconds (6.51691 seconds) DTR = 386.686 KBPS (0.377623 MBPS)
            [     988] Mon Nov 05 23:28:32 2012  INFO
            [     988] Mon Nov 05 23:29:32 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [     988] Mon Nov 05 23:29:33 2012  INFO
            [     988] Mon Nov 05 23:29:33 2012 ERROR
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [    7836] Mon Nov 05 23:29:37 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 65354.8 milliseconds (65.3548 seconds) DTR = 15.1175 KBPS (0.0147632 MBPS)
            [    7836] Mon Nov 05 23:29:39 2012  INFO
            - AdobeHelp
            [    7836] Mon Nov 05 23:29:39 2012 ERROR
            :: END TIMER :: [Total Timer] took 146752 milliseconds (146.752 seconds) DTR = 141.164 KBPS (0.137855 MBPS)
            [    7836] Mon Nov 05 23:29:40 2012  INFO
            CHECK : Credentials
            Sync Media DB ...
            :: END TIMER :: [Sync Media DB] took 2312.92 milliseconds (2.31292 seconds) DTR = 1.72942 KBPS (0.00168888 MBPS)
            Overwrite property "userASUPath" to:
            [    3932] Mon Nov 05 23:35:22 2012  INFO
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.92698 milliseconds (0.00392698 seconds)
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.76602 milliseconds (0.00276602 seconds)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation repair
            [    3932] Mon Nov 05 23:35:23 2012  INFO
            [    7372] Mon Nov 05 23:35:23 2012  INFO
            [    7372] Mon Nov 05 23:35:24 2012  INFO
            [    3932] Mon Nov 05 23:35:24 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1010.35 milliseconds (1.01035 seconds) DTR = 3.95903 KBPS (0.00386624 MBPS)
            [    5492] Mon Nov 05 23:35:24 2012  INFO
            [    5492] Mon Nov 05 23:35:30 2012  INFO
            [    3932] Mon Nov 05 23:35:30 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 5919.38 milliseconds (5.91938 seconds) DTR = 45.9507 KBPS (0.0448738 MBPS)
            [    7036] Mon Nov 05 23:35:30 2012  INFO
            [    7036] Mon Nov 05 23:35:33 2012  INFO
            [    3932] Mon Nov 05 23:35:33 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 3509.6 milliseconds (3.5096 seconds) DTR = 5.69866 KBPS (0.00556509 MBPS)
            [    7356] Mon Nov 05 23:35:33 2012  INFO
            [    7356] Mon Nov 05 23:35:36 2012  INFO
            [    3932] Mon Nov 05 23:35:36 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 3072.51 milliseconds (3.07251 seconds) DTR = 123.678 KBPS (0.120779 MBPS)
            [    3932] Mon Nov 05 23:35:37 2012  INFO
            [    5604] Mon Nov 05 23:35:37 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 511.065 milliseconds (0.511065 seconds) DTR = 7.8268 KBPS (0.00764336 MBPS)
            [    3932] Mon Nov 05 23:35:42 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5006.01 milliseconds (5.00601 seconds) DTR = 0.79904 KBPS (0.000780312 MBPS)
            [    5912] Mon Nov 05 23:35:42 2012  INFO
            [    5912] Mon Nov 05 23:35:43 2012  INFO
            [    3932] Mon Nov 05 23:35:43 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 423.028 milliseconds (0.423028 seconds) DTR = 1285.97 KBPS (1.25583 MBPS)
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.66958 milliseconds (0.00266958 seconds)
            Calling the custom action code for pre-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [    5348] Mon Nov 05 23:35:43 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{1EE9D42F-10F6-44BF-90E4-85DB30C27BE7}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            [    5348] Mon Nov 05 23:35:47 2012  INFO
            [    3932] Mon Nov 05 23:35:48 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4563.82 milliseconds (4.56382 seconds) DTR = 0.876459 KBPS (0.000855917 MBPS)
            Calling the custom action code for post-repair for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [    1308] Mon Nov 05 23:35:48 2012  INFO
            [    1308] Mon Nov 05 23:35:50 2012  INFO
            [    1308] Mon Nov 05 23:35:52 2012  INFO
            [    1308] Mon Nov 05 23:35:53 2012  INFO
            [    3932] Mon Nov 05 23:35:53 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5017.13 milliseconds (5.01713 seconds) DTR = 102.848 KBPS (0.100437 MBPS)
            [    5076] Mon Nov 05 23:35:53 2012  INFO
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 210.246 milliseconds (0.210246 seconds)
            [    3932] Mon Nov 05 23:35:58 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5005.5 milliseconds (5.0055 seconds) DTR = 0.799121 KBPS (0.000780392 MBPS)
            [    4076] Mon Nov 05 23:35:58 2012  INFO
            [    4076] Mon Nov 05 23:35:59 2012  INFO
            [    4076] Mon Nov 05 23:36:00 2012  INFO
            [    3932] Mon Nov 05 23:36:00 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1527.32 milliseconds (1.52732 seconds)
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1.23754 milliseconds (0.00123754 seconds)
            [    5720] Mon Nov 05 23:36:00 2012  INFO
            [    5720] Mon Nov 05 23:36:01 2012  INFO
            [    5720] Mon Nov 05 23:36:03 2012  INFO
            [    5720] Mon Nov 05 23:36:05 2012  INFO
            [    3932] Mon Nov 05 23:36:05 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5329.81 milliseconds (5.32981 seconds) DTR = 96.814 KBPS (0.094545 MBPS)
            [    5244] Mon Nov 05 23:36:05 2012  INFO
            [    5244] Mon Nov 05 23:36:08 2012  INFO
            [    5244] Mon Nov 05 23:36:09 2012  INFO
            [    5244] Mon Nov 05 23:36:10 2012  INFO
            [    3932] Mon Nov 05 23:36:10 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 4318.86 milliseconds (4.31886 seconds) DTR = 177.825 KBPS (0.173657 MBPS)
            [    2764] Mon Nov 05 23:36:10 2012  INFO
            [    2764] Mon Nov 05 23:36:52 2012  INFO
            [    2764] Mon Nov 05 23:36:52 2012 ERROR
            [    3932] Mon Nov 05 23:36:57 2012  INFO
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 47613.9 milliseconds (47.6139 seconds) DTR = 97.7026 KBPS (0.0954127 MBPS)
            [    3932] Mon Nov 05 23:36:59 2012  INFO
            Successfully repaired 12 components:
            - AdobeHelp
            [    3932] Mon Nov 05 23:36:59 2012 ERROR
            :: END TIMER :: [Total Timer] took 102135 milliseconds (102.135 seconds) DTR = 80.6774 KBPS (0.0787865 MBPS)
            -------------------------------------- Summary --------------------------------------
            [    3932] Mon Nov 05 23:37:00 2012  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 6.2.10.0
            Win OS version: 6.1.1.0  Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            CHECK : Another Native OS installer already running
            Create Required Folders
            Assuming uninstall mode
            Lookup for master payload
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            Setting property "driverAdobeCode" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
            Setting property "mediaSignature" to: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
            Overwrite property "userASUPath" to: C:\Program Files\Common Files\Adobe\OOBE\PDApp\core\..\D6
            {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 not installed
            {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 not installed
            {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 not installed
            [     936] Mon Nov 05 23:38:07 2012  WARN
            DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
            [     936] Mon Nov 05 23:38:07 2012  INFO
            [     936] Mon Nov 05 23:38:10 2012  INFO
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation remove
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation remove
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation remove
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation none
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation remove
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation remove
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation remove
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation none
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation remove
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation remove
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation remove
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation remove
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation remove
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation remove
            Calling the custom action code for pre-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            [    6868] Mon Nov 05 23:38:10 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 105.53 milliseconds (0.10553 seconds)
            The csu inventory was not updated for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            [    6304] Mon Nov 05 23:38:10 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 105.846 milliseconds (0.105846 seconds)
            [     936] Mon Nov 05 23:38:11 2012  INFO
            The csu inventory was not updated for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            [    5004] Mon Nov 05 23:38:11 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 105.704 milliseconds (0.105704 seconds)
            The csu inventory was not updated for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            [    3396] Mon Nov 05 23:38:11 2012  INFO
            Unable to remove payload.
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 112.026 milliseconds (0.112026 seconds)
            Calling the custom action code for post-remove for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            [    6288] Mon Nov 05 23:38:11 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 111.125 milliseconds (0.111125 seconds) DTR = 4607.42 KBPS (4.49943 MBPS)
            The csu inventory was not updated for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            [    7524] Mon Nov 05 23:38:11 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 105.243 milliseconds (0.105243 seconds)
            [     936] Mon Nov 05 23:38:12 2012  INFO
            Calling the custom action code for post-remove for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            Calling the custom action code for pre-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            [    5652] Mon Nov 05 23:38:12 2012  INFO
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 105.332 milliseconds (0.105332 seconds)
            The csu inventory was not updated for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            [     656] Mon Nov 05 23:38:12 2012  INFO
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 104.843 milliseconds (0.104843 seconds)
            The csu inventory was not updated for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            [    7128] Mon Nov 05 23:38:12 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 106.019 milliseconds (0.106019 seconds)
            Calling the custom action code for post-remove for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            Calling the custom action code for pre-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            [    6384] Mon Nov 05 23:38:12 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 105.137 milliseconds (0.105137 seconds)
            Calling the custom action code for post-remove for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            [    8052] Mon Nov 05 23:38:12 2012  INFO
            [     936] Mon Nov 05 23:38:13 2012  INFO
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 104.945 milliseconds (0.104945 seconds)
            Calling the custom action code for post-remove for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            [    6216] Mon Nov 05 23:38:13 2012  INFO
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 111.053 milliseconds (0.111053 seconds)
            The csu inventory was not updated for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0, value of local var is -1
            Calling the custom action code for post-remove for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            Updating driver data successful. Driver entry was removed. ARP estimated size 106223KB
            [     936] Mon Nov 05 23:38:15 2012  INFO
            Total components repaired: 0
            Successfully removed 1 component:
            Begin cleaning up local media db.
            [     936] Mon Nov 05 23:38:19 2012  INFO
            Done cleaning up local media db.
            :: END TIMER :: [Total Timer] took 11710.7 milliseconds (11.7107 seconds) DTR = 38.9388 KBPS (0.0380262 MBPS)
            [     936] Mon Nov 05 23:38:20 2012  INFO
            Uninstalling AAM
            [     936] Mon Nov 05 23:38:21 2012  INFO
            AAM Uninstall Status: 1 and 0
            - 0 fatal error(s), 0 error(s), 1 warning(s)
            WARNING: DW039: Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is not installed so should not be there in the deployment file
            Exit Code: 0 - No error.
            Please see specific errors and warnings for troubleshooting. For example, WARNING: DW039 ...
            CHECK : Credentials
            Assuming install mode
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 1443.34 milliseconds (1.44334 seconds) DTR = 690.068 KBPS (0.673894 MBPS)
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Updating media info for: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Dreamweaver CS6
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Updating media info for: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Updating media info for: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Updating media info for: {8E8021FF-7AA0-11E1-BF04-E98EE5274486}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12ja_JPLanguagePack\Install.db
            Updating media info for: {8FDB26FC-7AA0-11E1-BF04-E25246635842}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12en_USLanguagePack\Install.db
            Updating media info for: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Updating media info for: {9E0AF030-AC6B-11E0-8837-00215AEA26C9}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Updating media info for: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            Updating media info for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Updating media info for: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            Updating media info for: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Updating media info for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Updating media info for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Updating media info for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
              Path: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            [    9784] Mon Nov 05 23:45:15 2012  INFO
            Supported RIBS version range: [0.0.66.0,6.2.10.0]
            ----------------- CreatePayloadSession: machine is x86 ---------------
            ______ Verify Dependency Subscribers ______
            BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: 1 (0,3)
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1: 2 (0,5)
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180: 3 (0,4)
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148: 3 (0,4)
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: 4 (1,1)
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: 5 (0,1)
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0: 5 (0,1)
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: 5 (0,1)
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0: 5 (0,1)
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: 6 (3,1)
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: 7 (4,1)
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: 7 (4,1)
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: 8 (12,0)
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0: 9 (0,0)
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0: 9 (0,0)
            END Operation order for all session payloads: mediaGroup (requires,satisfies)
            Setting property "installLanguage" to: en_US
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6
            Overwrite property "DEVersion" to: 6.0
            Overwrite property "selfDelete" to: false
            Overwrite property "skipSync" to: 1
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 is: true
            Action string for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0  is none
            Value returned on lookup of payload: {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1 is: true
            Action string for {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1  is none
            Value returned on lookup of payload: {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180 is: true
            Action string for {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180  is none
            Value returned on lookup of payload: {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148 is: true
            Action string for {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148  is none
            Value returned on lookup of payload: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 is: true
            Action string for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 is: true
            Action string for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0  is none
            Value returned on lookup of payload: {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 is: false
            Action string for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0  is none
            Value returned on lookup of payload: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 is: true
            Action string for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0  is none
            Value returned on lookup of payload: {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 is: true
            Action string for {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0  is none
            Value returned on lookup of payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 is: true
            Action string for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0  is none
            Value returned on lookup of payload: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 is: true
            Action string for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0  is none
            Value returned on lookup of payload: {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 is: true
            Action string for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0  is none
            Value returned on lookup of payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 is: false
            Action string for {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0  is install
            Value returned on lookup of payload: {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is: false
            Action string for {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0  is none
            Payload {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Value returned on lookup of payload: {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is: false
            Action string for {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0  is none
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 is extension payload. Aligning its action according to parent {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
            [    9784] Mon Nov 05 23:45:17 2012  INFO
            ::START TIMER:: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In ReinstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 3.4399 milliseconds (0.0034399 seconds)
            ::START TIMER:: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [System check :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 3.28389 milliseconds (0.00328389 seconds)
            BEGIN InstallOperationsQueue Unordered operations
              {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0:  with operation repair
              {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0:  with operation repair
              {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0:  with operation repair
              {8E8021FF-7AA0-11E1-BF04-E98EE5274486} Adobe Dreamweaver CS6_AdobeDreamweaver12ja_JPLanguagePack 12.0.0.0:  with operation none
              {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0:  with operation install
              {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180:  with operation repair
              {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148:  with operation repair
              {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1:  with operation repair
              {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0:  with operation install
              {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0:  with operation repair
              {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0:  with operation install
              {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0:  with operation repair
              {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0:  with operation repair
              {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0:  with operation repair
              {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0:  with operation repair
            END InstallOperationsQueue Unordered operations
            BEGIN InstallOperationsQueue Ordered operations
            END InstallOperationsQueue Ordered operations
            [    9784] Mon Nov 05 23:45:18 2012  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            ::START TIMER:: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}]
            [   10092] Mon Nov 05 23:45:18 2012  INFO
            Installer Operation: PayloadUninstaller
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Effective AdobeCode for: {354D20E6-A25F-4728-9DA6-C9003D8F2928} is {354D20E6-A25F-4728-9DA6-C9003D8F2928}
            Session includes local copy of payload for repair source
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Extracting assets...
            [   10092] Mon Nov 05 23:45:19 2012  INFO
            Extracting assets complete. Number assets: 1
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            Setting permission for: C:\Program Files\Common Files\Adobe\APE\3.3 Group/User:Everyone Access:GENERIC_READ(Seq 3)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeAPE3.3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{354D20E6-A25F-4728-9DA6-C9003D8F2928}.db
            Physical payload repair result:0
            [    9784] Mon Nov 05 23:45:19 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{354D20E6-A25F-4728-9DA6-C9003D8F2928}] took 1012.44 milliseconds (1.01244 seconds)
            Updating driver data - Action: Add driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 0KB
            User specified overrideFile:
            Successfully updated the csu inventory for {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {354D20E6-A25F-4728-9DA6-C9003D8F2928} Adobe Player for Embedding 3.3 3.3.0.0
            Calling the custom action code for pre-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            ::START TIMER:: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}]
            [   10176] Mon Nov 05 23:45:19 2012  INFO
            Installer Operation: ModifyThirdPartyPayloadOperation
            Modify Thirdparty payload
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
            CommandLine: /q /norestart
            [   10176] Mon Nov 05 23:45:26 2012  INFO
            Third party payload completed.  Testing return code: 0
            [    9784] Mon Nov 05 23:45:26 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{9E0AF030-AC6B-11E0-8837-00215AEA26C9}] took 6940.47 milliseconds (6.94047 seconds) DTR = 47.8353 KBPS (0.0467142 MBPS)
            The csu inventory was not updated for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1, value of local var is -1
            Calling the custom action code for post-repair for payload {9E0AF030-AC6B-11E0-8837-00215AEA26C9} Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.1
            Calling the custom action code for pre-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            ::START TIMER:: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}]
            [    4728] Mon Nov 05 23:45:26 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2005 Redist (x86)\vcredist_x86.exe
            CommandLine: /q:a /c:"msiexec /i vcredist.msi /qn /norestart"
            [    4728] Mon Nov 05 23:45:30 2012  INFO
            [    9784] Mon Nov 05 23:45:30 2012  INFO
            :: END TIMER :: [Payload Operation :{9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9}] took 3818.53 milliseconds (3.81853 seconds) DTR = 2.09505 KBPS (0.00204595 MBPS)
            The csu inventory was not updated for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180, value of local var is -1
            Calling the custom action code for post-repair for payload {9AB0EFC0-AC6B-11E0-9E61-00215AEA26C9} Microsoft Visual C++ 2005 Redistributable Package (x86) 6.0.2900.2180
            Calling the custom action code for pre-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            ::START TIMER:: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}]
            [    8436] Mon Nov 05 23:45:30 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe
            [    8436] Mon Nov 05 23:45:32 2012  INFO
            [    9784] Mon Nov 05 23:45:32 2012  INFO
            :: END TIMER :: [Payload Operation :{9C4AA28F-AC6B-11E0-8997-00215AEA26C9}] took 2619.81 milliseconds (2.61981 seconds) DTR = 832.122 KBPS (0.812619 MBPS)
            [    9784] Mon Nov 05 23:45:33 2012  INFO
            The csu inventory was not updated for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148, value of local var is -1
            Calling the custom action code for post-repair for payload {9C4AA28F-AC6B-11E0-8997-00215AEA26C9} Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.4148
            Calling the custom action code for pre-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            ::START TIMER:: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}]
            [    8996] Mon Nov 05 23:45:33 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Effective AdobeCode for: {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} is {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            Evaluating condition# 1(Seq 31)
            Condition failed(Seq 31)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeSuiteSharedConfiguration3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}.db
            :: END TIMER :: [Payload Operation :{B8ADDCBD-30D9-4366-AE25-089CEF76C8E1}] took 809.447 milliseconds (0.809447 seconds) DTR = 4.94164 KBPS (0.00482582 MBPS)
            [    9784] Mon Nov 05 23:45:34 2012  INFO
            Successfully updated the csu inventory for {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0
            Calling the custom action code for pre-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PrePayloadReinstallProc
            [    9784] Mon Nov 05 23:45:39 2012  INFO
            :: END TIMER :: [Pre payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 5006.55 milliseconds (5.00655 seconds) DTR = 0.798954 KBPS (0.000780228 MBPS)
            ::START TIMER:: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            [   10056] Mon Nov 05 23:45:39 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Effective AdobeCode for: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} is {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSExtensions3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}.db
            :: END TIMER :: [Payload Operation :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 719.52 milliseconds (0.71952 seconds) DTR = 44.4741 KBPS (0.0434317 MBPS)
            [    9784] Mon Nov 05 23:45:40 2012  INFO
            Successfully updated the csu inventory for {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0
            ::START TIMER:: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}]
            In PostPayloadReinstallProc
            :: END TIMER :: [Post payload :{EB2A8CD4-B247-4810-A294-E3DB8EDC6060}] took 2.38958 milliseconds (0.00238958 seconds)
            Calling the custom action code for pre-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            ::START TIMER:: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}]
            [    6208] Mon Nov 05 23:45:40 2012  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaverWidgetsBrowser1.0-mul\AdobeAIRInstaller.exe
            CommandLine: -silent -eulaAccepted -programMenu WidgetBrowser.air
            [    6208] Mon Nov 05 23:45:44 2012  INFO
            [    9784] Mon Nov 05 23:45:44 2012  INFO
            :: END TIMER :: [Payload Operation :{C0C7DC90-C8DF-46DA-BA21-848889DAFD11}] took 4521.31 milliseconds (4.52131 seconds) DTR = 114.126 KBPS (0.111451 MBPS)
            Successfully updated the csu inventory for {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0 return values 0:0
            Calling the custom action code for post-install for payload {C0C7DC90-C8DF-46DA-BA21-848889DAFD11} Adobe Dreamweaver Widget Browser 1.0.0.0
            Calling the custom action code for pre-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}]
            [    8272] Mon Nov 05 23:45:44 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Effective AdobeCode for: {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} is {DC00A3E1-9C61-4B11-8070-B592E68D2B3C}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            Payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    8272] Mon Nov 05 23:45:46 2012  INFO
            Extracting assets complete. Number assets: 2
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            [    8272] Mon Nov 05 23:45:50 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeLinguistics_4_0_All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}.db
            [    9784] Mon Nov 05 23:45:50 2012  INFO
            :: END TIMER :: [Payload Operation :{DC00A3E1-9C61-4B11-8070-B592E68D2B3C}] took 5609.95 milliseconds (5.60995 seconds) DTR = 91.2665 KBPS (0.0891274 MBPS)
            Successfully updated the csu inventory for {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {DC00A3E1-9C61-4B11-8070-B592E68D2B3C} Adobe Linguistics CS6 6.0.0.0
            Calling the custom action code for pre-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            ::START TIMER:: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}]
            [    3252] Mon Nov 05 23:45:50 2012  INFO
            Repairing third party payload with source: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            Third party application path:C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamwea ver_12_LS16\Adobe Dreamweaver CS6\payloads\AdobeHelp\InstallAdobeHelp.exe
            CommandLine: appVersion=4.0.244 appId=chc pubId=4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 installerArg1=-silent installerArg2=-eulaAccepted installerArg3=-programMenu installerArg4=AdobeHelp.air
            :: END TIMER :: [Payload Operation :{D38116C8-C472-4BB0-AD6F-0C1DD1320D1D}] took 217.82 milliseconds (0.21782 seconds)
            The csu inventory was not updated for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0, value of local var is -1
            Calling the custom action code for post-repair for payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0
            Calling the custom action code for pre-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [    9784] Mon Nov 05 23:45:55 2012  INFO
            :: END TIMER :: [Pre payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 5007.16 milliseconds (5.00716 seconds) DTR = 0.798856 KBPS (0.000780132 MBPS)
            ::START TIMER:: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            [    9016] Mon Nov 05 23:45:55 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Effective AdobeCode for: {36682D68-3834-487E-BA49-DFA4AB0A2E32} is {36682D68-3834-487E-BA49-DFA4AB0A2E32}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            Payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    9016] Mon Nov 05 23:45:56 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            [    9016] Mon Nov 05 23:45:57 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeCSXSInfrastructure3-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{36682D68-3834-487E-BA49-DFA4AB0A2E32}.db
            [    9784] Mon Nov 05 23:45:57 2012  INFO
            :: END TIMER :: [Payload Operation :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 1435.79 milliseconds (1.43579 seconds)
            Successfully updated the csu inventory for {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0
            ::START TIMER:: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}]
            :: END TIMER :: [Post payload :{36682D68-3834-487E-BA49-DFA4AB0A2E32}] took 2.29719 milliseconds (0.00229719 seconds)
            Calling the custom action code for pre-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            ::START TIMER:: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}]
            [    9008] Mon Nov 05 23:45:57 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Effective AdobeCode for: {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} is {EFBC1075-F890-4293-A0D1-04BE66EE2AB3}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            Payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    9008] Mon Nov 05 23:45:59 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            [    9008] Mon Nov 05 23:46:00 2012  INFO
            Evaluating condition# 1(Seq 98)
            Condition failed(Seq 98)
            [    9008] Mon Nov 05 23:46:02 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtendScriptToolkit3.8.0-mul\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}.db
            [    9008] Mon Nov 05 23:46:03 2012  INFO
            [    9784] Mon Nov 05 23:46:03 2012  INFO
            :: END TIMER :: [Payload Operation :{EFBC1075-F890-4293-A0D1-04BE66EE2AB3}] took 5912.56 milliseconds (5.91256 seconds) DTR = 86.5954 KBPS (0.0845658 MBPS)
            Successfully updated the csu inventory for {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {EFBC1075-F890-4293-A0D1-04BE66EE2AB3} Adobe ExtendScript Toolkit CS6 3.8.0.0
            Calling the custom action code for pre-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            ::START TIMER:: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}]
            [    6024] Mon Nov 05 23:46:03 2012  INFO
            Session {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} modify request for AdobeCode: {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Effective AdobeCode for: {83463106-DD1C-4FE5-A61C-DF6715472AD4} is {83463106-DD1C-4FE5-A61C-DF6715472AD4}
            Repair payload source package: C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            Payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    6024] Mon Nov 05 23:46:05 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            [    6024] Mon Nov 05 23:46:07 2012  INFO
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeExtensionManager6.0All\Install.db
            UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{83463106-DD1C-4FE5-A61C-DF6715472AD4}.db
            [    9784] Mon Nov 05 23:46:07 2012  INFO
            :: END TIMER :: [Payload Operation :{83463106-DD1C-4FE5-A61C-DF6715472AD4}] took 3736.59 milliseconds (3.73659 seconds) DTR = 137.023 KBPS (0.133812 MBPS)
            Successfully updated the csu inventory for {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0 return values 0:0
            Calling the custom action code for post-repair for payload {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
            Calling the custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            ::START TIMER:: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}]
            [    9364] Mon Nov 05 23:46:07 2012  INFO
            Installer Operation: PayloadInstaller
            Request to install payload
            Payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0: Calling ARKEngine from path C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
            [    9364] Mon Nov 05 23:46:43 2012  INFO
            Beginning installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [    9364] Mon Nov 05 23:46:44 2012  INFO
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Everyone Access:GENERIC_ALL(Seq 29)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:Administrators Access:GENERIC_ALL(Seq 30)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 31)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 32)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Everyone Access:GENERIC_ALL(Seq 34)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:Administrators Access:GENERIC_ALL(Seq 35)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 36)
            Setting permission for: C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 37)
            Setting permission for: \\lefh-sfps-fs\fs-userrf$\fknippenberg\Application Data\Adobe\Extension Manager CS6\Mxi Flag\Dreamweaver CS6 Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 39)
            [    9364] Mon Nov 05 23:46:44 2012 ERROR
            DF043: Failed in GetNamedSecurityInfo(Seq 39)
            DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            Completing installation for payload at C:\Users\FKNIPP~1\AppData\Local\Temp\{247A35A3-FA59-4634-B744-379804DF708E}\Dreamweaver_1 2_LS16\Adobe Dreamweaver CS6\payloads\AdobeDreamweaver12-mul\Install.db
            [    9784] Mon Nov 05 23:46:49 2012  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E}] took 42143.7 milliseconds (42.1437 seconds) DTR = 104.025 KBPS (0.101587 MBPS)
            The csu inventory was not updated for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0, value of local var is -1
            Calling the ROLLBACK custom action code for pre-install for payload {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0
            Payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 cannot be installed due to dependent operation failure.
            Skipping payload {8FDB26FC-7AA0-11E1-BF04-E25246635842} Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack 12.0.0.0 as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was added. ARP estimated size 106223KB
            [    9784] Mon Nov 05 23:46:51 2012  INFO
            Successfully installed 1 component:
            - Adobe Dreamweaver Widget Browser
            Successfully repaired 11 components:
            - Adobe Player for Embedding 3.3
            - Adobe CSXS Infrastructure CS6
            - Adobe Extension Manager CS6
            - Microsoft Visual C++ 2005 Redistributable Package (x86)
            - Microsoft Visual C++ 2008 Redistributable Package (x86)
            - Microsoft Visual C++ 2010 Redistributable Package (x86)
            - Suite Shared Configuration CS6
            - AdobeHelp
            - Adobe Linguistics CS6
            - Adobe CSXS Extensions CS6
            - Adobe ExtendScript Toolkit CS6
            Total components removed: 0
            [    9784] Mon Nov 05 23:46:51 2012 ERROR
            DW050: The following payload errors were found during install:
            DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 98107.3 milliseconds (98.1073 seconds) DTR = 4.8926 KBPS (0.00477793 MBPS)
            - 0 fatal error(s), 4 error(s), 0 warning(s)
            ----------- Payload: {A4ED5E53-7AA0-11E1-BF04-B2D4D4A5360E} Adobe Dreamweaver CS6 12.0.0.0 -----------
            ERROR: DF043: Failed in GetNamedSecurityInfo(Seq 39)
            ERROR: DW063: Command ARKSetPermissionCommand failed.(Seq 39)
            ERROR: DW050: The following payload errors were found during install:
            ERROR: DW050:  - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
            ERROR: DW050:  - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
            Please search the above error/warning string(s) to find when the error occurred.
            These errors resulted in installer Exit Code mentioned below.
            [    9784] Mon Nov 05 23:46:52 2012  INFO
            Exit Code: 7 - Unable to complete Silent workflow.
            Please see specific errors and warnings for troubleshooting. For example, ERROR: DF043, DW063 ...
            END - Installer Session
            • 3. Re: Dreamweaver Installation Failing
              Nitin_Bansal Adobe Employee
              Hi @fhk02127, the failure is happening as the user account you are logged in has it's Roaming profile data location mapped to a network drive. When installers tries to set permissions to installed files in roaming profile data, it fails. There are two options to resolve this:
              1.) Temporarily remove the network mapping of the current user roaming profile data folder location (C:\Users\FKNIPP~1\AppData\Roaming). Map it to default location on the machine. Once the application is installed, you can restore the network mapping.
              2.) Create a new user on machine with admin rights. Install Dreamweaver from that user login and then switch back to your regular user login for app use.
              Do let us know when you get it working.
