Hi Rick, thanks for your reply (that was fast!)
I'm doubtful of the screen painting issue you brought up.
I've tested the full motion feature under different circumstances
(tried other websites, dragging files from one folder to another,
trying to scroll through a My Computer or Windows Explorer screen)
and the results are the same. It records the mouse moving to the
scroll bar and clicking, then the movie goes white, and reappears
with what I assume is the last frame of the motion capture in a new
slide. Effectively I end up with three slides: beginning, motion
capture (blank), and end.
I tried running FMC with both hardware acceleration on and
off. In recording options, I've tried it with autorecord on and
also manually. I've tried turning down the video quality from 80
(default, I think) to 70; and tried switching the color mode from
16bit to 32 bit. I changed the working folder to simpy c:\ (in case
there was an issue writing to the hard drive). I also tried running
it with the higher capture rate, with no success.
Could there be a conflict with another program? Virus
Protection maybe? I tried turning the 'Real Time File Protection'
feature off, but that didn't work either.
Again, thanks for the help...
john.
p.s. I'm not sure if this would be a contributing issue, but
I also seem to be a user that receives the rare and mysterious
"Can't Allocate DIB Handle" when I try to run Menu Builder. I don't
really have a need for Menu Builder at present, so I didn't give it
much thought. Do you think the issues are related?
