Robohelp is ignoring my Framemaker numberlist formatting and does not provide any kind of message mentioning an unsupported style.
My numbered list appears as the screen shot below in the FrameMaker file
1. View vCenter Server, ESX host, and virtual machine versions in the inventory.
When i bring the FM file into Robohelp the numbered list looks like this
1.View vCenter Server, ESX host, and virtual machine versions in the inventory.
is there a way to maintain the style at the time of conversion?
First - you should post in the FM Integration area.
Second - you can't attach screenshots using e-mail - use the camera icon in the Web version of the Forum
Third - how are you setting your FM conversion Settings? Are you importing or linking? What version of FM & RH are you using?
Jeff, I am importing using FM 11 to Robohelp 9
New to these forums
No problem - so how are you setting that all-important setting concerning numbered lists? Text, HTML defined list, etc.?
I have been using the default settings, so its converting to text
In that case you have to tweak the css to format the resulting content in RH. You could also play with trying out the other settings to see what results you get or create a numbered list style in RH that looks the way you want and use the Conversion Settings to map your FM paragraph format to the RH style.
