7 Replies Latest reply: Feb 6, 2013 12:42 AM by sparklyfirefly RSS
    Flare or Robohelp
    IsleofGough Community Member
      I have been using structured and non structured Framemaker since version 5.5 (now using v11), and I purchased Madcap Flare for non print delivery systems. Other than my issues with the learning curve, I have found it to moderately buggy. However, Madcaps tech support is excellent. Robohelp is fairly expensive. Has anyone who uses Framemaker regularly done any cost benefit analysis and looked at stability and support issues between Flare and Robohelp? For the foreseeable future, I will be continuing to use Framemaker, which for me is very stable. I have fm-ePub converter and mif2go. Thanks.
        • 1. Re: Flare or Robohelp
          bowen192 Community Member
          4 pages, several arguments, 4 bans and at least 2 people's weekends ruined.
          I'm in the same position as you, but I have recently chosen TCS 4, so the choice has been made for me.
          I to have been attracted by the level of customer service.  If it wasn't for certain contributors on here, I would be struggling a lot more than I am.  Did you know that Madcap actually produce help documentation for their products?!
          • 2. Re: Flare or Robohelp
            It is a pity there is so much emotion over this. On one side, there are people who have issues with Adobe's tech support or direction but who deny Flare has some pretty significant bugs. On the other side there are Adobe supporters who don't like Flare's aggressive marketing and minimize issues with Adobe's support. And of course there are Help and Manual, AuthorIt, or e-Publisher or various XML editors (or even LaTeX users) who are quick to say that the solutions lie elsewhere. Meanwhile, the business people may try to promote Microsoft Word as plenty adequate. It would be good to have some objective comparison other than a web site that has tables of what is or is not available (but doesn't address what actually works). I'm still pretty happy with Framemaker, and have not experienced some of the stability issues with latter releases that others have had.
            • 3. Re: Flare or Robohelp
              Follow up for anyone who may be dealing with the same issues: Flare creates pretty good HTML output but is no replacement for Framemaker for pdf output. The issues I have found so far are these: number styles do not come over accurately if they are used to reset outlines (like "O:"), thought they can be corrected after import in Flare. Table styles do not import correctly but can be corrected after import by changing a parameter and then changing the parameter back to the original value. Pdf linked images import with black boxes to the right. PNG files may not generate in pdf output. Pdf output file size is about twice that of FM for same documents. SVG linked images get corrupted (with text) with Flare output. Rotated cells in tables unrotate on import in Flare. I have been dealing almost daily with Flare tech support on these issues, and at least for me, Flare is no replacement for Framemaker if one is creating print output.
              I haven't tested all these in Robohelp, but I know it does a better job with linked pdf images in Framemaker, but like Flare, unrotates table cells. Has anyone used Epublisher Pro as another alternative?
              • 4. Re: Flare or Robohelp
                ksoltys Community Member
                I've been using ePublisher for more than 10 years. It does a great job of converting to HTML and once you get your template set up, conversion is basically one-click. I still use FM to create my PDFs, when I need them (I use them only for reviews now), but from what I've seen, the PDFs that ePublisher creates are just fine.
                Quadralay's support is excellent, much better than Adobe's and at least equal to MadCap's. I also like the fact that they expose a lot more of the program's internals to you than either Flare or RoboHelp - it's pretty much infinitely twealable assuming you have a technical bent. You'll need to know a bit of XSLT or JavaScript to really get into the advanced stuff, but run-of-the-mill customizations like look and feel and branding are straightforward. And they fix bugs - promptly.
                Regards
                Keith
                • 5. Re: Flare or Robohelp
                  Thank you, Keith. That was helpful. I see there will be an update to Epublisher Pro the end of this month that specifically improves support for Framemaker 11 documents.
                  • 6. Re: Flare or Robohelp
                    mattrsullivan CommunityMVP
                    Yes, *providing* support is a specific improvement in ePP FM 11 support <grin>
                    • 7. Re: Flare or Robohelp
                      sparklyfirefly
                      I experienced Adobe technical support yesterday and honestly cannot fault it in any way. We too had heard that it was poor compared to MadCap but our first experience of Adobe TS was great.
