How to delete files with backslash in name
Guest
Nov 09, 2012 Nov 09, 2012
I had some code that was developed for a windows server to create some image files. The destination parameter had backslashes in the path. When run on a Coldfusion 9  linux server, the files ended up in the top directory with long filenames consisting of ' directory\directory\filename'.  Now I need to delete them. I've tried cffile action="delete" file="directory\\directory\\filename">.
889
Nov 10, 2012 Nov 10, 2012
Execute cfdirectory on the directory in question.  Loop through the query object and use whatever field refers to the name of the file.  I'd have to look that up, but you can do that.
Nov 11, 2012 Nov 11, 2012
Did just deleting them exactly as-is (ie: without escaping the backslashes) not work?
Adam
The syntax is <cffile action="delete" file="absolute_path_to_the_file">. So what you need to do is figure out how to get the absolute path, on the basis of the current page.
Sep 19, 2016 Sep 19, 2016
ExpandPath() should work.
V/r,
^_^
Aug 02, 2019 Aug 02, 2019
The Longpathtool is the very best program for error, unlock solution. Try it and solved your problem. I used the long path tool and I solved my error, unlocks problem solution.
Documentation
