im using an access database...and presumed that you have a
limit towards
how many words you can have in a field. Am I wrong then?
When i say formatting i meant, where the line breaks are etc
etc
Yes, there is a limit. IIRC the 'memo' field type can hold up
to 2GB of
text, that would be a very long song I think. Now there are
limitations
on using the memo field. One can not use it like a normal
char or
varchar field in where clauses. So you should read up on it
to
understand how to use it properly.
As for formating, do you mean ASCII formating or HTML
formating. HTML
formating is just text, your store it in the field with the
content.
ASCII formating as well, but with ASCII formating you will
have to do
something for it to display properly in a browser, either
convert to to
HTML on the fly or display inside of <pre></pre>
OR <code></code> tags.
