Hello
Here I have a little problem as a result of the transition to the latest version
It is impossible for me to start adobe flashplayer update services from services.msc in fact I get an error message
On my first netbook asus under seven starter manual, but it is impossible to start, I did not even console adobe in the Control Panel
Here is the error message http://www.hostingpics.net/viewer.php?id=631022Sanstitre2.png
On my second netbook xp sp3 I managed to start and set automatic except that here but now it is stopped and can not restart
Hoping to have a solution on your side because I have a utility called update checker
Thanks for your help
Adobe Flash Player Update Service is not started by you, but by the scheduled updater. It must be set to Manual.
Thanks!!
So it is normal because there is no update to currently
I continue to do it manually
Thanks for you answer
Usually the automated background update will run withing 7 days of its release. A Windows restart is required to initiate it, otherwise it can take up to 30 days.
Thank you so much !!!!!
It's resolved
