Scripting Error for Calculating Columns
Avatar
Level 2
Hello,
I have created a table in which I need to sum the rows and columns.  The script is working for each row, but it is not for each column.  I've looked through this forum and found several examples that should work for me but I'm still receiving an error; accessor ... is unknown (where... is the path).  I would appreciate any assistance. ScriptError-1.jpg
Avatar
Level 2
Help?  Do I need to provide more information or the file?
Avatar
Level 10
I think you have a typo in your script.
The uses sum(form.page1...) but the name of your page is Page1 (first letter in upper case).
Avatar
Level 2
I just made the change as you suggested but it did not clear the error.  Would you have any other suggestions?
Avatar
Level 10
without seeing the form, it not possible to say whats wrong.
Fact is, the path you use in the sum() function does not exist.
Upload your form somewhere and post a link here, so we can check it.
Avatar
Level 2
Thanks radzmar.  I hope I have given you access to the document.
http://https://docs.google.com/open?id=0BzzfBikvcraQeERNYnQydzQ4c3c
Message was edited by: AngelaC - to change link
Avatar
Level 10
Well,
as I said, the reference is wrong.
In your form, there is no row named "Row", but 4 rows named individually "Row1", "Row2" etc.
The script you use looks for all instances of a object named "Row"m this means Row[0], Row[1], Row[2] and so on..
So just rename all the 4 rows into "Row" and your script will work.
Avatar
Level 2
THANK YOU!!  From the example that I found to use for this, I did not realize the naming of the rows as they were.  Such a simple thing that has held me up for days.
Again, thank you!!
