1. Re: Can the arrangement of Video 7 Audio tracks be changed in Elements 11
Bill Hunt Nov 16, 2012 8:55 AM (in response to hal_ek)Only to a degree. In PrE, one can display either Audio Tracks, or Video Tracks, or both, grouped as they are, with Video Tracks and Audio Tracks next to each other.
Personally, I like the PrPro layout better, as I nearly always work on Video first, and then Audio later on. However, many PrPro users beg for the PrE layout. I find it occupies a lot of real estate, and really like the separation much better.
I am going to Move this thread out to the main PrE Forum, so that others can comment, as they will likely not see it here.
Good luck,
Hunt
2. Re: Can the arrangement of Video 7 Audio tracks be changed in Elements 11
hal_ek Nov 18, 2012 9:51 AM (in response to Bill Hunt)Thanks for your response, even tho it was not what I hoped for.
3. Re: Can the arrangement of Video 7 Audio tracks be changed in Elements 11
Bill Hunt Nov 18, 2012 9:59 AM (in response to hal_ek)You are most welcome.
Now, having filed Feature Requests with Adobe, what I do not know if any change has been made in PrE 11's Expert Mode. I am still awaiting my copy of PrE 11, and will pour over it - just in case.
Good luck,
Hunt
4. Re: Can the arrangement of Video 7 Audio tracks be changed in Elements 11
hal_ek Nov 18, 2012 10:23 AM (in response to Bill Hunt)Bill;
Since you also replied to my post about Crawl/Roll Controls (#4851577) i
wonder if you would reread my last post to that thread.
The responses seem to indicate that my first post did not describe my
problem well.
Thanks again!
5. Re: Can the arrangement of Video 7 Audio tracks be changed in Elements 11
nealeh Nov 18, 2012 12:06 PM (in response to hal_ek)You can always delete the empty tracks* and then add, say, seven video tracks followed by adding seven audio tracks. You could then save that empty project out to use as a starting point in new projects.
*You can't get rid of Soundtrack, Narration, Video 1, and Audio 1 though. They are fixed. You can rename them.
Cheers,
Neale
Insanity is hereditary, you get it from your children
