Anyone know the Regex to find if a variable contains a word eg this var has "Surplus Percentage Total in the Amount of $2000.00"
So I need to know it contains the word 'Percentage'?
Here is my code
cfset xyz='Surplus Percentage Total in the Amount of $2000.00'
cfset foundword= REFind('Percentage',
xyz)
The above is not working
<cfset xyz='Surplus Percentage Total in the Amount of $2000.00'>
<cfset foundword = REFindNoCase('Percentage',xyz)>
<cfif foundword GT 0>
Word found at position <cfoutput>#foundword#</cfoutput>
<else>
Word not found
</cfif>
The code you displayed might not be the actual code. Where did those white things come from?
According to the docs, it will not return the subexpression unless you set the returnsubexpression flag to true. If the flag is false (default), it retuns an array of length and position of the subexpression.
^_^
<else>
Word not found
</cfif>
Thanks.... implemented already with the RefindNocase. The values were coming in either lower/Upper case realized I have to use RefindNocase
