10 Replies Latest reply: Nov 24, 2012 11:46 AM by Bibzie RSS
    Lightroom 4 Publishing to Facebook
    mikeobe Community Member
      When I attempt to publish to facebook I get the message: Lightroom is unable to create temporary files on the Volume named "Local Disk (C:)? OS is Win 7, 64 bit! 1 Terebyte disk with over 700 gigs free!
        • 1. Re: Lightroom 4 Publishing to Facebook
          Geoff the kiwi CommunityMVP
          Sounds like a permissions issue somewhere but I'll defer to a Windows user.
          • 2. Re: Lightroom 4 Publishing to Facebook
            That's what it sounds like to me as well! ? Def. not a computer specialist here! I need all the help I can get!:)
            • 3. Re: Lightroom 4 Publishing to Facebook
              Bibzie
              Has anyone helped you with this problem?  I get the same message when trying to publish to Flickr and haven't figure it out yet.  Any help is appreciated.
              • 4. Re: Lightroom 4 Publishing to Facebook
                Cornelia-I Community Member
                Forgive me if you have tried this basic approach already - I do not publish to Facebook, hence have not encountered the same problem:
                I would go in Explorer to the exact volume as indicated in the error message, right-click and choose properties, then the tab for permissions (sorry I lack the English terms as my Win7 is in German) and change that with advanced permission to anybody-full access.
                Just in case.
                Because it looks like LR is suggesting a volume for this Facebook publishing service which is normally locked by vanilla win7-set-up.
                Alternatively the Facebook publishing service should use a temp-volume which is normally permitted, but there is no open access within LR to specify that.
                Could be a bad choice on the definition of the publishing service - the preconfigured Flickr-pulishing service in LR  has no such problems.
                I have not yet searched if this has been reported as a bug.
                Cornelia
                • 5. Re: Lightroom 4 Publishing to Facebook
                  I finally got it to work, but, think it was mainly a Facebook thing, didn't have it set up correctly! I installed, Uninstalled, installed, etc! Even installed the jf Facebook thingy, it's much more sophisticated than the one that comes with LR!
                  Once you mess up the settings it seems the only way is to start all over again? Be very careful and pay close attention to the directions! May need to read them over a time or two, or it could just be me, I'm kinda slooow!
                  Good luck to you, hope this helps? OH, I did go thru the Windows Permission thing and that didn't help with my situation, maybe yours?
                  • 6. Re: Lightroom 4 Publishing to Facebook
                    Bibzie Community Member
                    Cornelia,
                    Thank you for the info.  My husband is better at the os set ups and
                    permissions so I'll try to get him to try this and will let you know what
                    happens.
                    Thank you again,
                    Dottie
                    • 7. Re: Lightroom 4 Publishing to Facebook
                      Cornelia,
                      I just wanted to let you know how I fixed the problem with publishing
                      directly to Flickr.com.  Instead of right clicing on Exporer, I right
                      clicked on the Lightroom icon and went to Properties.  I then changed the
                      options to Run As Administrator, which gave it permissions to write to the
                      drive.  It now works.
                      Thank you for pointing me in the right direction.
                      Dottie
                      • 8. Re: Lightroom 4 Publishing to Facebook
                        Hi...Mine is fixed by right-clicking on the Lightroom icon.  In Properties,
                        I set the program to run as "administrator", giving it permisisions to
                        write the files to the disk.  Once that was done, it uploaded to Flickr
                        with no problems.  Of course, I only tested 1 photo.  I've heard it's
                        REALLY slow.
                        • 9. Re: Lightroom 4 Publishing to Facebook
                          derekfoto
                          REALLY slow.
                          Running an application like Lightroom as Administrator is ill-advised because you are now allowing Lightroom and all of its plugins (3rd party or otherwise) to do *anything* to your system, whether you know it or not. The broken exporting and writing to temporary files just started happening recently.  It could be something to do with the latest Windows update, or a bug in Lightroom that Adobe now has to fix because of a change to the OS.
                          Changing the permissions on the folder where temp files are written is another option (as another poster suggested).
                          What I did, however, was download Jeffrey Friedl's  "JF Flickr" plugin, which does work correctly (http://regex.info/blog/lightroom-goodies/flickr). It is quite robust. It takes a little work to setup all of your Smart Collections again but he clearly puts effort into maintaining it.  It didn't have the "API error" that the built-in plugin has.
                          Also what annoys me is that Adobe hasn't caught this yet or said anything about it.  The best I could find was this thread.  Native plugins should never be broken, Adobe!
                          • 10. Re: Lightroom 4 Publishing to Facebook
                            Thanks for your response. I'm not TOO concerned about the Admin as I have
                            it set to ask me each time to give permission.  It's kind of a pain since I
                            have to click YES every time I upload so your suggestion might work
                            better.
                            Hopefully, the problem will be fixed by Adobe soon.  In the
                            meantime....I'll try the folder permissions and hope that works.
                            Thanks again,
                            Dottie
