SOLVED
Show Text Based On CheckBox Status
Avatar
Former Community Member
I have two checkboxes: 'Yes' and 'No'. When I check the 'Yes' box I want a textstring 'Good Job!' to be visible in the textbox. And when I check the 'No' box I want a  sad emoticon to be visible in the textbox. Of course, I want to disable multiple answers too.
Help please
1 Accepted Solution
Avatar
Correct answer by
Employee
Attached sample.pdf contains requested functionality. If this fulfills your need then I can explain you the exact steps.
Avatar
Level 2
I'm not an expert but I think it is possible to have a nearby field be programmed to appear with the Yes box - having a presence - and hidden with no and visa versa.  Good luck.
Avatar
Correct answer by
Employee
Avatar
@KhushwantSingh thank you, this is very helpful
