Hi.
For the last 2 versions of adobe flash, we have been having some problems in Internet explorer. If a user upgrades from an earlier version, 2 out 3 will have problems in IE9, that its just stuck/hangs/not Responding, if there is any flash on the site. If i disable flash active x, it works fine.
So if i uninstall flash and install again, i works fine. But if a user do an upgrade, it gives us problems. The problem is on manuelt upgrade and Remote upgrade installation.
Can anyone share some light on this problem, maybe?
Regards
Jesper
Could you please try the latest Flash Player version? http://get.adobe.com/flashplayer/
Sunil
the problem is reacuring when users get ask by adobe update from the adobe auto update. to the newest version.
We have come a bit further with the case on out own.
it seem to be because the system32/macromed/flash/FlashUtil64_11_5_502_110_ActiveX.dll file is missing.
the log file says it is copied, but its not located in the folder. As soon as iexplorer process is running the dll file will not be copied to the location and flash fails when vissiting websites.
but if a disable UAC, and start the IE9 and go to a site with flash i will work.
Could you please share some light on this case please.
Could somebody please come with som kind of help or response?
What is your current Flash Player version that gives you problems?
You write that you don't have problems when you do a clean install, but when you do an upgrade.
How about after an automated background update?
Also can you post the contents the FlashInstall.log file from C:\Windows\system32\Macromed\Flash
The problem is when a user do an upgrade by hand or we do it from our cms system.
as soon as the iexplorer is running in the process, the dll file is not created in the macromed/flash folder.
Automated Update is disabled do to we had this problem, så now I only installed the updates by CMS where i make sure that iexplorer is not running before upgrade or install. This is only on win7 machines. Xp no problem.
here is the logfile.
=O====== M/11.5.502.110 2012-12-20+10-38-45.545 ========
0000
0001 00000010 "C:\Windows\TEMP\{846CC481-8DC8-492E-83C5-6389DEAFE5AC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0002
0003
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_110.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_110_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_110_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000012
=X====== M/11.5.502.110 2012-12-20+10-38-49.897 ========
=O====== M/11.5.502.110 2013-01-30+11-09-22.643 ========
0000 00000010 "C:\Windows\TEMP\{E659C295-9DF1-4380-9FB9-1D1A9D52A9FA}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
=X====== M/11.5.502.110 2013-01-30+11-09-23.283 ========
=O====== M/11.5.502.146 2013-01-30+11-09-24.156 ========
0000 00000010 "C:\Windows\TEMP\{75835422-6D3E-4D53-9703-25FDE5C1D0A0}\InstallFlashPlayer.exe" -force -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0017
0018
0019
0020
0021
0022
=X====== M/11.5.502.146 2013-01-30+11-09-24.546 ========
=O====== M/11.5.502.146 2013-01-30+11-09-43.064 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.5.502.146 2013-01-30+11-09-44.811 ========
=O====== M/11.5.502.146 2013-01-30+11-09-39.663 ========
0000 00000010 "C:\Windows\TEMP\{709AF767-0C46-4E76-8D2D-451E4FAF8FF0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_146.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.dll
0011 00000012
=X====== M/11.5.502.146 2013-01-30+11-09-47.229 ========
seeams that the problem is solved ind the new version "11.6.602.168". installed on 60 machines with no insidents so far.
