1. Re: How do I get PE9 to recognise an Epson V600 Scanner in WIA Support Panel
ukgaurav Nov 20, 2012 2:18 AM (in response to Bob Dix Photographer)You can move the Twain plug-in from Optional plugins to directory as mentioned in this KB doc to make sure your scanner is detected by PSE 9.
http://helpx.adobe.com/photoshop-elements/kb/twain-installed-photoshop-elements-9.html
You need to install scanner drivers prior to this. If already installed then this should help you get it worked.
-Garry
2. Re: How do I get PE9 to recognise an Epson V600 Scanner in WIA Support Panel
Bob Dix Photographer Nov 25, 2012 12:07 AM (in response to ukgaurav)Yes, but , Search coiuld not find the twain plug -in / >
Header 2 .
http://http://helpx.adobe.com/photoshop-elements/kb/twain-installed-photoshop-elements-9.h tml -
3. Re: How do I get PE9 to recognise an Epson V600 Scanner in WIA Support Panel
ukgaurav Nov 25, 2012 9:02 PM (in response to Bob Dix Photographer)What do you see here C:\Program Files (x86)\Adobe\Photoshop Elements 9\Optional Plug-Ins\Import-Export? There must be Twain_32.8BA file of Twain installed by default. If you have already moved it to C:\Program Files (x86)\Adobe\Photoshop Elements 9\Locales\en_US\Plug-Ins\Import-Export..
Then download the latest drivers from http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=139863&inf oType=Downloads.
4. Re: How do I get PE9 to recognise an Epson V600 Scanner in WIA Support Panel
Bob Dix Photographer Nov 26, 2012 3:41 PM (in response to ukgaurav)Well it is there , but, the recommendation is to use the WIA Support which works Ok in Premiere Elements 9. Moving it does not totally solve the V600 showing up on the Import panel , but, it does in Photoshop 6.
The latest drivers from Epson do work the scanner.
Thanks for your suggestions ,the V600 works very well and images can be opened in 9 or 6.
Also, the quality of the scan can be adjusted for prints and I take it for negatives and transparencies when the scanner is set correctly.
5. Re: How do I get PE9 to recognise an Epson V600 Scanner in WIA Support Panel
ukgaurav Nov 26, 2012 8:28 PM (in response to Bob Dix Photographer)Glad you got it worked!!
