Hello,
One of the apps I'm working on is multiplatform for Android and iOS. The app functions correctly in the Flash Pro debugger and on our devices; however, if the debugger is left sitting for a short period without any interaction from the user, the debugger will randomly terminate.
There is no error message given, simply "Debug session terminated". This does not happen on the device, only in the Flash desktop and mobile debuggers. Generally it takes 5-20 seconds for the debugger to terminate, but sometimes it will close after one or two seconds, and rarely will close as soon as a debug session is launched.
I've watched the memory usage and see no evidence of memory leaks; this problem will even happen on static menu screens where nothing is consuming new resources.
Any thoughts? Is there a way to trace or log what might be causing the early termination?
Flash Pro CS6
Flash Builder 4.7
using AIR 3.4, debugging from Pro with desktop and mobile debuggers
