2 Replies Latest reply on Nov 20, 2012 9:22 AM by Coreydwillis
    Removing ChildSymbol Instances
    Coreydwillis Level 1
      Basically what I'm doing is changing my "page" variable when a navigation button is pressed. If the "Demo" button is pushed, then "page=demo" for example.
      Demo Button Code
      page = "demo";
      After this variable is set, I call the changePage function from that button and it executes this code:
      The Function Code
      window.changePage=function() {
                if (page != "demo") {
                          var pageDisplay =sym.createChildSymbol(page,'Stage');
                          pageDisplay.getSymbolElement().css({"left": "8px", "top": "62px"});
                else {
                          var pageDisplay =sym.createChildSymbol(page+lesson,'Stage');
      What I'm doing is saying that it will load a symbol that matches the current state of the "page" variable. The problems is that once the function is called again, it places the next symbol below it. I want it to remove the first instance of "pageDisplay", then create the new instance based on whatever the variable value is right then. I tried different delete functions, but they kept just completely breaking it the function.
        • 1. Re: Removing ChildSymbol Instances
          DarioMatson Level 1
          Not sure if it's the optimal way, but this is the way i delete the created items... (Maybe someone can optimize this)...
          when adding the object, add
          And then get the childsymbols from where you created them:
          var onLocationChildSymbols = sym.getComposition().getStage().getChildSymbols();
        if (this.getVariable("type")=="createdButton"){
          • 2. Re: Removing ChildSymbol Instances
            Thanks! That totally worked! :-D
