20 Replies Latest reply: Feb 10, 2014 1:45 AM by fgregor RSS
    Can't log in to Adobe Exchange Plugin
    brian.piltin Community Member
      I installed the new Adobe Exchange plugin but I can't login. It stays cycling on the Logging in... screen on the panel. Anyone else having issues with this?
      (Windows 7 64 bit, Photoshop CS6 64 bit)
      It's been stuck for the last 20 min now. I've already restarted PS and tried logging in again.10-23-2012 6-11-02 PM.jpg
        • 1. Re: Can't log in to Adobe Exchange Plugin
          Jonathan Ferman Adobe Employee
          Hi there,
          Sorry to hear about this issue. We just did another panel update. Have you downloaded it? Are you still unable to log in? If so just reply and I will get in touch wth you to resolve this.
          Jonathan Ferman | Product Manager
          • 2. Re: Can't log in to Adobe Exchange Plugin
            Honestly, I don't know if it updated but I didn't update on my own. Does it update automatically? Anyhow, a few days later I decided to check if it would login and it was already working, already logged in and good to go. I have no idea what happened or what fixed it. It may have been an update?
            • 3. Re: Can't log in to Adobe Exchange Plugin
              Well I'm glad that it is now working. We recently added some great products, take a look around the panel in the CS6 apps you have.
              • 4. Re: Can't log in to Adobe Exchange Plugin
                Kimo52
                I am having the same problem.  I did update the extension manager and everything else.  It just keeps asking over and over.  I know the id and pw are correct because I'm logged in right now with them.
                • 5. Re: Can't log in to Adobe Exchange Plugin
                  Sushmar Community Member
                  A few things have helped others resolve their problem
                  1. Making sure you have the latest panel - it should be 0.9.3 (you can check this from Extension Manager)
                  2. reinstalling the point product (eg. Photoshop or InDesign)
                  3. If you have recently upgrades your OS, there might be some file permissions issue that need to be restored.Try the following:
                  Please close all applications and Repair Disk Permissions on OSX:
                  1. Open Disk Utility, located at /Applications/Utilities/Disk Utility
                  2. Select your startup disk on the left of the Disk Utility window
                  3. Select First Aid from the tabs
                  4. Click the "Repair Disk Permissions" button
                  It is always a good idea to run Repair Disk Permissions on OSX after an update, say from 10.8 to 10.8.x.
                  On Windows you can Run sfc /scannow In the command prompt.
                  1. Type sfc /scannow and hit Enter.
                  You could also try and disable any 3rd party firewall, antivirus programs.
                  Hope one of these suggestions work for you.If not, please let us know and we can see how we can help.
                  Adobe Exchange team
                  • 6. Re: Can't log in to Adobe Exchange Plugin
                    Kimo52 Community Member
                    I have done all 3 things you listed. Updated everything and verified the versions are all the latest, reinstalled Photoshop and ran sfc /scannow.
                    It did not help.  I can login on the web just fine.  I also had to login with my id and password when I reinstalled. The ID and password and my internet connection are not the problem.  I also turned off my firewall and antivirus program (MSE) but that did not help.
                    The Adobe Exchange extension continues to ask for the ID and password over and over.
                    I am on Windows 7 64-bit.  Photoshop is 64-bit too. Everything is current with all updates applied.
                    What now?
                    • 7. Re: Can't log in to Adobe Exchange Plugin
                      I spent a lot of time doing the things you suggested to fix Adobe's bug.  I think this deserves action on Adobe's part.   Hello?
                      • 8. Re: Can't log in to Adobe Exchange Plugin
                        Kimo52, firstly I'd like to apologise for the problems you have been experiencing. I realise it is very frustrating. We are investigating your issue and it does require us to test a lot of variables so please bear with us. Feel free to private message me and we can set up a direct support meeting as soon as we believe we have diagnosed the problem.
                        Many thanks,
                        • 9. Re: Can't log in to Adobe Exchange Plugin
                          asankara Community Member
                          Hi Kimo52,
                          Please delete opm.db file in your machine:
                          It will be in C:\Documents and Settings\<username>\Local Settings\Application Data\Adobe\OOBE in Win and
                          ~/Library/Application Support/Adobe/OOBE for Mac.
                          If you are on Mac, make sure you can view hidden files in Finder or delete it from your terminal using rm ~/Library/Application Support/Adobe/OOBE/opm.db
                          Let me know if this fixes your problem.
                          • 10. Re: Can't log in to Adobe Exchange Plugin
                            Deleting this opm.db file will cause you to log in again. And once you do, it should all work fine.
                            • 11. Re: Can't log in to Adobe Exchange Plugin
                              beLi83
                              Hi
                              I have the same problem using Windows 7 64 bit, Photoshop CS6 64 bit. I also deleted the opm.db file but still cannot log in. I am connected to the Internet.
                              Would really appricate it if you could help me with this. What else can I can do to make this work?
                              • 12. Re: Can't log in to Adobe Exchange Plugin
                                lesavage Adobe Employee
                                Hi BeLi83,
                                Could you share the following log file?
                                C:\Documents and Settings\<user>\AppData\Adobe\Exchange
                                Lea
                                • 13. Re: Can't log in to Adobe Exchange Plugin
                                  beLi83 Community Member
                                  Hi Lea
                                  Thanks for your quick reply. There are 3 listed in the directory:
                                  adobeexchange
                                  adobeexchange_1
                                  adobeexchange_2
                                  I uploaded the latest file if that's of any help or what you meant.
                                  • 14. Re: Can't log in to Adobe Exchange Plugin
                                    Hi beLi83,
                                    Could you also share the following log files:
                                    C:\Users\<username>\AppData\Local\Temp\PDApp.log
                                    C:\Users\<username>\AppData\Local\Temp\amt3.log
                                    This PDApp.log file is usually quite large so I recommend deleting the log file and repeating the steps required to reach the issue shown in your original screenshot.
                                    Lea
                                    • 16. Re: Can't log in to Adobe Exchange Plugin
                                      Hi BeLi83,
                                      I am seeing a timeout error when attempting to connect to our identity management servers. So:
                                      1) Are you sure you are connected to the internet? The fact that you are responding to this forum makes me assume yes but just wanted to double check
                                      2) Do you have a firewall that could potentially be blocking our HTTP requests?
                                      Kind regards,
                                      Lea
                                      • 17. Re: Can't log in to Adobe Exchange Plugin
                                        Hi Lea
                                        Yes I'm 100% sure I'm connected to the internet. I tried it by switching the Firewall off and also adding the software to bypass it.
                                        I also did a reinstallation and nothing's changed. Our IT guy had had a look and thinks it has something to do with proxy. He asked if there's a specific address or port for this?
                                        Thanks so much for your help
                                        Mel
                                        • 18. Re: Can't log in to Adobe Exchange Plugin
                                          Hi Mel,
                                          I have forwarded on your logs to the appropriate team so they are investigating the issue. It may be something to do with being behind a proxy, do you know if any of the Adobe servers are added to your server's whitelist?
                                          If it is easier, please don't hesiate to take this issue offline from the forum and email me directly at lesavage at adobe dot com.
                                          Kind regards,
                                          Lea
                                          • 19. Re: Can't log in to Adobe Exchange Plugin
                                            Glen Charles Rowell Community Member
                                            I just installed Windows 7 Ultimate (64-bit) on a freshly formatted SSD then the CS6 Master Collection. After that I installed AdobeExchange 1.2.0 and now I have the exact same problem... What can I do? The login just hangs like in the first post here.
                                            • 20. Re: Can't log in to Adobe Exchange Plugin
                                              fgregor Adobe Employee
                                              Hi Glen,
                                              Can you please make sure you've installed any available updates through Adobe Application Manager, reboot and then try again?
                                              Fingers crossed that should do the trick, but if that does not work, then please turn on logging, retry and then send the generated logs to me at fgregor at adobe dot com.
                                              WINDOWS
                                              Go to the Start Menu and type in ‘regedit’
                                              Click regedit.exe from the Programs list
                                              Navigate to Computer\HKEY_CURRENT_USER\Software\Adobe\CSXS.3
                                              Increase the LogLevel to 6
                                              Log Files: C:\Users\<username>\AppData\Local\Temp
                                              For example, if you were running Photoshop CS6 the log file name will be “csxs3-PHSP.log”
                                              Also, please include the log files from these locations:
                                              C:\Users\<UserName>\AppData\Local\Temp\amt3.log
                                              C:\Users\<UserName>\AppData\Local\Temp\PDApp.log
                                              C:\Users\<UserName>\AppData\Roaming\Adobe\Exchange\adobeexchange.log
                                              Kind regards,
                                              Fraser
