So I got CF10 installed on my server next to xampp, when I launch the installer and get to this screen:
Then when I click "ADD" and go to xampp conf folder etc. I get this message:
And then click OK, I get the next error message:
Is there any way to resolve this problem, or maybe the download link to Coldfusion 8?
Kind regards,
Lennert
Self-bump!
Not having installed XAMPP myself on Windows, are you sure it's 64-bit on Windows? I suspect it's a 32-bit environment even on 64-bit Windows.
Have you tried checking the 32-bit option on the ColdFusion dialog?
What is the xampp version? 32 bit or 64 bit?
64-bit.
And the version?
...And the steps you have taken to get the 64-bit version working? As we know, Xampp is 32-bit only, so you must have used unofficial binaries, or compiled it yourself.
Fernis wrote:
As we know, Xampp is 32-bit only...
If that be so, then shouldn't LennertLeers check the checkbox ("Configure 32 bit webserver") in the second printscreen (http://puu.sh/1uADv)?
...unless he really has 64-bit Xampp, which is also possible -as I referred - if you use unofficial binaries or compile/install individual packages yourself... in which case, it kind of negates the easiness of a pre-built installation suite anyway, doesn't it?
Did you ever get it to work? I'm getting the same error message. I tried reintalling coldfusion 10 and checked the 32-bit webserver box and still get the same error message
