2 Replies Latest reply: Nov 27, 2012 9:35 PM by D3S user RSS
    Missing effects and title frame, on 3 of 12 sequences, solutions?
    D3S user Community Member
      Hi Adobists,
      I checked the history and Adobe's site generally but nada.
      I've built 12 frame grabs as a leader to 12 songs in order to show up in the menu buttons. Same background, different text in title overlay, frame grab saved as image.
      3 of the 12 songs do not import correctly with color corrections and the leader still (frame grab) is missing.
      I tried rebuilding the entire Encore project from scratch, with the same result.
      Also, if I start a new project using one of the suspect sequences the files show up intact but subsequent adds of the other two performances load with the missing results. The other 9 songs are fine BTW.
      So, the files work if loaded from the PP drop down under (open with dynamic link) but only on an single timeline, initial new project.
      I tried eliminating the frame grabs and rebuilt the slides with the same results.
      Anyone have a suggestion?
      I'm all ears, with a deadline.
      1) Is it possible to load the stills in Encore, and add it ahead of the timelines (4 seconds long)? I suppose It's possible to add the button with the still and pick whip from there to the sequence but as noted the content issues are unresolved.
      2) Is there a way to copy and paste from one Encore project to another without using PP?
      3) I'm using a title template from the first song, perhaps I should start fresh, as it's obvious DL is seeing an unfinished timeline and perhaps the template has been corrupted?
      Any help is welcomed, I will cruise the tutorial videos as well once again.
      Rob
