A person in another branch of our company was provided a copy of RH 10 to update an existing WebHelp project that was originally done in RH 9. For various reasons, we need to revise that project (now in RH 10) by another person in the company that only has RH 9. However, we are getting an incomaptiblity error when we try to reopen it in RH 9 (see figure below).
I was under the impression you could go "both ways" between the two versions. Is there a work-around for this? We want to keep development in the RH 9 environment and can't afford to upgrade at this time.
You can reliably downgrade back to RH9 as long as you didn't use any RoboHelp 10 specific functions. (You can even downgrade to RH8.)
See http://www.wvanweelden.eu/articles/downgrade-robohelp-project for an overview for a how to.
Greet,
Willam
Hi there
Normally the process is a one way street. Once you open the project in the newer version there isn't an easy way to go backward. I'm not saying it can't happen or be done, just that RoboHelp expects that once you touch it and upgrade it to 10, it will refuse to open in 9 because the project now has version 10 identifiers.
Try deleting the CPD file and see if version 9 will open it up.
Cheers... Rick
As Rick says, you are down a one way street. Once you use any new features provided in RH10 then (as with most software) opening the project in an earlier version is likely to cause problems. It's a bit like asking your wife to cook chrismas dinner the same way your ex-wife did it all those years ago - things won't turn out well.
You can indeed remove the .cpd and at least look at the project - that worked in RH9 to RH8.
Would I work with it confidently in a production enviroment?
NO, never.
Would I happily switch between the two version when sharing projects?
NO, never.
More of a project planning (and by the looks of it a project costing) issue than software issue, sorry.
Good luck
Craig
Greet,
Willam
Willam , because I didn't use any RoboHelp 10 specific functions, I tried your steps from your website and I was able to open and save my project in RH 9. Thank you!
