14 Replies Latest reply: Nov 29, 2012 10:41 AM by kglad RSS
    tI
    Ron Colmen Community Member
      I've got 5 text fields in _root.mc1, and 2 text fields in _root.mc2 and 10 text fields on the root. all are sitting in the same frame.
      1. How do I set tabIndex to each of those to cycle in each movieclip or root, depending on where the user starts typing?
      2. How do I add onKeyDown=function() if there is a button in each movie clip and on the root? (Assuming LEFT arrow is assigned for both movieclip buttons and for the button on the root, how can I make only one active at a time)
        • 1. Re: tI
          kglad CommunityMVP
          1.
          var tIndex:Number = 1;
          for(var i:Number=0;i<5;i++){
          _root.mc1["tf_"+i].tabIndex=tIndex++;
          for(i=0;i<2;i++){
          _root.mc2["tf_"+i].tabIndex=tIndex++;
          for(i=0;i<10;i++){
          _root["tf_"+i].tabIndex=tIndex++;
          2.  what's the keydown listener supposed to do?
          • 2. Re: tI
            Thank you Kglad.
            2.  an onRelease();
            • 3. Re: tI
              kglad CommunityMVP
              you want a keydown event to trigger a some object's onRelease?
              if yes, do different keys trigger different object's onRelease?
              • 4. Re: tI
                Thank you Kglad.
                • 5. Re: tI
                  kglad CommunityMVP
                  is your question about keydown answered?
                  • 6. Re: tI
                    like this?
                    keyListenerNew = new Object();
                    keyListenerNew.onKeyDown=function(){
                       if(Key.isDown(Key.LEFT)){
                          _root.submit_btn.onRelease();
                    Key.addListener(keyListenerNew);
                    • 7. Re: tI
                      I tried what you suggested. But still the tabINdex order is moving incorrectely.
                      i.e. if the cursor is in _root.mc1.tf1, 2nd tab moves to _root.mc2.tf2 ?
                      1st in _root.mcvar tIndex:Number = 1;
                      for(i=0;i<2;i++){
                      • 8. Re: tI
                        kglad CommunityMVP
                        6>  yes
                        7>  check the names of your textfields.  if they match, that code will work.
                        • 9. Re: tI
                          var tIndex:Number = 0;
                          var tf1:Array =[_root.tt.a, _root.tt.b, _root.tt.c];
                          for(i=0;i<tf1.length;i++){
                                    //tf1[i].tabIndex.tvas = i;
                          tf1[i].tabIndex=tIndex++;
                          trace (tIndex)
                          var tf2:Array =[_root.ttt.b, _root.ttt.a, _root.ttt.c];
                          for(i=0;i<tf2.length;i++){
                          tf2[i].tabIndex=tIndex++;
                          trace (tIndex)
                          I'm still unable to tab only inside _root.tt or only inside _root.ttt?
                          It index all text fields 1 - 6 and it tabbs in both movieclips. I want to tab only inside one mc at a time?
                          //what I'm expecting is to be able to do this;
                          _root.tt.a.tabIndex = 1
                          _root.tt.b.tabIndex = 2
                          _root.tt.c.tabIndex = 3
                          _root.ttt.b.tabIndex = 1
                          _root.ttt.a.tabIndex = 2
                          _root.ttt.c.tabIndex = 3
                          • 10. Re: tI
                            kglad CommunityMVP
                            you expect tabbing to ignore all the textfields in tt or in ttt?
                            • 11. Re: tI
                              When a user is on typing inside tt - ttt tabIndex should be ignored
                              (when on ttt, tt tabIndex should be ignored)
                              • 12. Re: tI
                                kglad CommunityMVP
                                use:
                                for (i=0; i<tf1.length; i++) {
                                    tf1[i].onChanged = changeF;
                                for (i=0; i<tf2.length; i++) {
                                    tf2[i].onChanged = changeF;
                                function changeF(tf:TextField):Void{
                                    if(memberOf(tf1,tf)){
                                            tf1[i].tabIndex = i;
                                            tf2[i].tabIndex = null;
                                    } else {
                                            tf2[i].tabIndex = i;
                                            tf1[i].tabIndex = null;
                                function memberOf(a,e):Boolean{
                                    for(var i:Number=0;i<a.length;i++){
                                        if(a[i]==e){
                                            return true;
                                    return false;
                                • 13. Re: tI
                                  Thank you Kglad.
                                  • 14. Re: tI
                                    kglad CommunityMVP
                                    you're welcome.
