I had changed the name of my start (default) topic on an existing project (done in RH9). When I published it, I noticed there was no new startupxxxx_csh.htm or new startupxxxx_rch.htm files produced that are associated with the regular startupxxx.htm file. In addition, I still had the old startupxxx.htm file, old startupxxxx_csh.htm and old startupxxxx_rch.htm files. Several questions come to mind:
I did some more investigation and found the following:
- These files are start files used in two legacy CSH calls. See: http://www.wvanweelden.eu/articles/part/methods-calling-webhelp
- Good question. Did you make any changes to the SSL? Are the files chsdat_robohelp.htm and cshdat_webhelp.htm generated? Or do you have the old version of those files too?
- Unless you use a legacy method to call the CSH, there is no harm. As far as I’ve found out, these files are only used to start the project and are not used once the project is loaded.
Greet,
Willam
The help works well now, so I'm not going to delete any of these "legacy" files just to be on the safe side.
