16 Replies Latest reply: Dec 1, 2012 2:33 AM by Laubender RSS
    "Reset Bounding Box" on rotated items?
    phyllisj9 Community Member
      Is there an InDesign equivalent to "reset bounding box" (an Illustrator option) on rotated items? I'm working on a layout with a bunch of angled text boxes. It'd be helpful if I could change their bounding boxes to straight again, though I couldn't find an option for that. Thought I'd ask in case I've overlooked it.
      Thanks, Phyllis
        • 1. Re: "Reset Bounding Box" on rotated items?
          NitroPress Community Member
          If there is, I've never found it. ID preserves the absolute (total) rotation of the original object unto the end of document life. :)
          • 2. Re: "Reset Bounding Box" on rotated items?
            P Spier CommunityMVP
            In my opinion, that's a good thing. Any rotation angle is recorded and can be used later by the smart guides feature.
            Have you considered rotating graphic content inside the frame instead of rotating the frame? I doubt that's any better, but it would keep the bounding box oriented.
            Peter
            • 3. Re: "Reset Bounding Box" on rotated items?
              (Cris_I) Community Member
              Draw a small box (no fill, no stroke).
              Place on top of the rotated object.
              Select both.
              Chose Pathfinder and press Add icon.
              Cris.
              • 4. Re: "Reset Bounding Box" on rotated items?
                Hey thanks,
                I'm working with text rather than graphics so unfortunately I can't rotate just the content (as far as I can tell -- not even if I convert to outlines). I tried the Pathfinder suggestion although that just turns everything into a single box (eliminates any content of the original) but did give me the idea that just grouping an empty frame with the angled one would work better. So thanks! I'd agree that it's helpful to keep a record of the rotation angle, but sometimes when there are a bunch of these, it's hard to work with angled bounding boxes. But I'll try the grouping technique -- I never thought of that!
                Thanks, Phyllis
                • 5. Re: "Reset Bounding Box" on rotated items?
                  cgfix Community Member
                  You would have to convert the text to paths for the pathfinder to work. You may have to use a different option than Add. Possibly Intersect and refill the shapes. It worked for me.
                  • 6. Re: "Reset Bounding Box" on rotated items?
                    CWDesignCo Community Member
                    Object > Transform > Reset Bounding Box. Boom!
                    • 7. Re: "Reset Bounding Box" on rotated items?
                      You do know that command is not availble in InDesign, right? That was the whole point of this thread.
                      • 8. Re: "Reset Bounding Box" on rotated items?
                        Doh! You caught me Peter. That's what I get for trying do too much at once!
                        For InDesign, reset the bounding box in Illustrator, copy it, paste it into InDesign.
                        • 9. Re: "Reset Bounding Box" on rotated items?
                          Still not quite on point, I'm afraid. Phyllis was working with text frames creted in ID, so Illustrator is out of the loop.
                          This is one of those cases where it just isn't going to happen.
                          • 10. Re: "Reset Bounding Box" on rotated items?
                            Manish-Sharma Employee Hosts
                            Clear Transformation option might help you, you can find the option in the Flyout menu of the Transform panel in InDesign.
                            Th result may vary upon the transformation and the rotation of the text box and the text.
                            • 11. Re: "Reset Bounding Box" on rotated items?
                              Hi Manish.
                              I think maybe you are misunderstanding the question, or I'm misunderstanding your intent in clearing the transformations. Let's go back to Illy for a sec and look at what the reset bounding box command does. If you, for example, draw a rectangle and rotate it, the bounding box, in both Illustrator and ID, rotates along with the rectangle. In illustrator, if you use the rest bounding box command a new, larger, bounding box without rotation is drawn around the original rotated object. That  command is not availble in ID.
                              If, on the other hand, you use the clear transformations command, your rectangle loses the rotation you originally applied. I don't think that was the intent here.
                              • 12. Re: "Reset Bounding Box" on rotated items?
                                Laubender Community Member
                                Hi Peter & Manish!
                                See the left square vs. the right square (both are rotated).
                                Both screen shots are done in InDesign.
                                Btw. the scripting property "geometricBounds" a.k. "BoundingBox" has the same values (70,711 x 70,71 mm) for both objects.
                                I have "faked" the right rotated square: it is a group with only ONE single object, the square.
                                You cannot do that in the UI, but it's perfectly possible by scripting:
                                Just create a group with two objects (the rotated square with a second rectangle),
                                select only the second rectangle inside the group and run the following JavaScript (ExtendScript) code on the selection:
                                app.selection[0].remove();
                                What you get is a group object with only one object inside.
                                The group itself is not rotated, just its only member inside, so the size of the group is your "BoundingBox" (= the geometricBounds of your rotated square) ;-)
                                Illustrator manages to show the values for the right representation of the rotated square, if you reset the bounding box.
                                Uwe
                                • 13. Re: "Reset Bounding Box" on rotated items?
                                  You are right as always, Peter..
                                  When working with Text box in Illustartor then the text doesn't rotate along the text box but re-align itself however in InDesign the text rotate itself with the text box except in the situation when we rotate the box with Direct selection tool. This is a big and basic difference in the funtionality of InDesign and Illustartor. So , there is no option nativly in InDesign like Illustrator to reset bounding box but to clear transformation.
                                  If OP want (not clear to me) the text in the text box also to straighten then Clear tranformation may help however not when the text is needed to remain rotated .
                                  • 14. Re: "Reset Bounding Box" on rotated items?
                                    Thanks Laubender , I knew it could be scripted but was not aware a single line script will make it work.
                                    • 15. Re: "Reset Bounding Box" on rotated items?
                                      Uwe, where weere you six months ago?
                                      I bet Phyllis could really have used this.
                                      • 16. Re: "Reset Bounding Box" on rotated items?
                                        @Peter – this was just a trick to show the geometricBounds with the UI Info palette in InDesign.
                                        I don't think she could have used it (other than seeing the values). What she liked to do and what will be like using the "Reset BoundingBox" feature in Illustrator would be another thing.
                                        I can demonstrate that with a text frame that is rotated. And btw. Cris showed a solution, or at least part of a solution in #3 of this thread. The problem with that is, that the text will be lost.
                                        Here some screen shots to illustrate the problem:
                                        1. A rotated text frame together with a text frame after choosing the Illustrator only "Reset BoundingBox" feature. The screen shot is from Indesign after proceessing and post-processing the solution Cris has introduced:
                                        And here the steps Cris suggested:
                                        1. Draw a small rectangle over the rotated text frame
                                        2. Select the text frame and the small rectangle and choose "Add" from the pathfinder palette
                                        Result: the text frame will loose its contents during the process, because its converted into a path object
                                        And: all graphic properties like fill color etc. are that of the small rectangle
                                        So, you have to:
                                        1. Convert the path object to a text frame
                                        2. Apply all other properties of the original text frame to the converted one (eg. by using a object style)
                                        3. Copy the text of the original text frame to the new one
                                        I would suggest a different thing. Instead of using a rectangle that is added to the text frame, use a small duplicate version of the original text frame, that is NOT rotated.
                                        Then it is a 2-step process and you have not to post-process anything to get the text or the graphical properties of the original back in:
                                        Here the result selected with the Selection Tool:
                                        Here selected with the Direct Selection Tool:
                                        I think this could be scripted as a 1-step process. But I had no time of doing so…
                                        @Manish – and that would be no one line script ;-)
                                        Uwe
