1. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
JSS1138 Sep 26, 2012 7:51 AM (in response to karanam akhil)This is normal. Not everything translates over to AE.
Do your CC work right in Premiere Pro. It's just a lot easier.
2. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
karanam akhil Sep 26, 2012 8:40 AM (in response to JSS1138)Ya but now that i have done my color correction in After Effects...what do i do?Please give me a solution....
3. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
JSS1138 Sep 26, 2012 12:06 PM (in response to karanam akhil)I did.
Redo the CC in PP.
4. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
Fuzzy Barsik Sep 26, 2012 1:30 PM (in response to karanam akhil)As Jim said, not all effects and transitions are properly translated when you replace a group of clips with dynamically linked AE composition. Actually you should have noticed that your cross-dissolves etc. had been replaced with black solid layers in After Effects, which didn't reflect your PrPro transitions.
Now you can jump back to your AE project and fix broken transitions there.
For your future work you should keep it in mind and decide whether to replace a group of clips (and, therefore, fix broken transitions in After Effects) or a single clip, taking care of its handles.
5. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
DaftlyPunkish Dec 3, 2012 2:41 PM (in response to JSS1138)Why would they add color correction in AE if it doesn't work with their own software?
6. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
JSS1138 Dec 3, 2012 6:09 PM (in response to DaftlyPunkish)Color correction in AE does work. The issue is that not everything from a Premiere Pro sequence will translate to AE.
7. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
DaftlyPunkish Dec 4, 2012 6:32 AM (in response to JSS1138)Hmm. I started with AE for CC and then imported the AE file into premier and I couldn't get any transitions to work. I don't know, maybe it's because I'm on a Mac. They do everything stupid.
8. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
JSS1138 Dec 4, 2012 8:42 AM (in response to DaftlyPunkish)Well...I can't argue with your last statement, but that's probably not the issue on this one.
Describe exactly what you mean by the transitions don't work. Have you the required extra material (handles)?
9. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
DaftlyPunkish Dec 4, 2012 8:47 AM (in response to JSS1138)I imported the AE file to the time line then I went to drag the cross dissolve over the track and it wouldn't let me. It gave me the drag hand with a circle with a line trough it. I eventually just exported the AE file from AE as a quicktime file the opened it up in PP. I'm also new to PP so I'm not sure what handles you're talking about haha.
10. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
JSS1138 Dec 4, 2012 8:47 AM (in response to DaftlyPunkish)That's another good option.
11. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
Fuzzy Barsik Dec 4, 2012 9:06 AM (in response to DaftlyPunkish)It gave me the drag hand with a circle with a line trough it.
That shouldn't happen in general... Could you upload your timeline screenshot?
12. Re: Transitions not working in Premiere CS6.Video was color corrected in AE 6 and sent back to PPro cs6.
DaftlyPunkish Dec 4, 2012 1:00 PM (in response to Fuzzy Barsik)Well now for some stupid reason it works... -_-
