Which is a more recent version of FlexUnit: flexunit-4.1.0-8 or flexunit-4.1.0_RC2 ??
RC2 stands for release candidate 2
So, any version of 4.1 will be newer than a 4.1 release candidate.
Mike
flexunit-4.1.0_RC2 supports the 'url' attribute for flexunit ant task but flexunit-4.1.0-8 does not support the 'url' attribute. Is this correct?
When I am using flexunit-4.1.0-8 to run my flexunit test case on an application running in server I am getting following error, which is not comming when I am using flexunit-4.1.0_RC2:
flexunit doesn't support the "url" attribute
my ant task is as follows:
<flexunit
url="https://localhost/admin"
command="${launch.app}"
toDir="${report.dir}"
haltonfailure="false"
verbose="true"
localtrusted="false"/>
So far as I know, that should not be true. The 4.1.0 RC2 or 4.1.0-8 refers to the FlexUnit framework version. The ant tasks are separate from that framework version.
Where did you get the code from that no longer has the url attribute? Download from the site? Maven?
Let me know so I can look further,
Mike
I only yesterday downloaded it from the flexunit.org website, http://www.flexunit.org/?page_id=14 (4.1 sdk). Just when I replaced the flexUnitTasks-4.1.0_RC2-28.jar with flexUnitTasks-4.1.0-8.jar, I started getting the error: flexunit doesn't support the "url" attribute.
Also, is it that the url attribute does not support url starting with 'https'. Our application is running on secured server and when I try to give url value as "https://localhost/admin", I get the error: The 'url' property must begin with 'http://' or 'file://'.
The error doesnot come with url value "http://localhost/admin":
