I'm using Flash Builder 4.6 Premium. There I installed Subversive from SVN Team Provider.
If I build an AIR-application, it would be nice if the application is able to display which revision number is built from.
I looked around in internet, but there are only solution for ANT. Can this be done without ant (so I could just press "export release")? I think we could get information from subversive, but how?
Thank you in advance.
cu Floh
Best guess is to set a dynamic compiler argument. I've done it with Date, I presume there is a way to access other stuff. But, most reliable is to use a script for release compile... I know a lot of p,aces use maven etc.
G
