update failed
Engaged ,
Dec 07, 2012 Dec 07, 2012
I got an update message from ColdFusion 10.
I got failed error message to download
"failed signature  verification"
Can you please advise where to check it?
Your help and information is great appreciated,
Iccsi,
2.1K
Adobe Employee , Dec 08, 2012 Dec 08, 2012
How about using java -jar option from the command prompt to run? For example, C:\ColdFusion10\jre\bin>java -jar c:\cf10_mdt_updt.jar.
Adobe Employee ,
Have you applied the mandatory update? You can get it from here - http://www.adobe.com/support/coldfusion/downloads_updates.html
Engaged ,
Thanks for the message and help,
I need admin rights to run the mandatory update.
I do not have run as admin when i right click on the jar file.
Can you please advise how to run mandatory as administrator?
Thanks again for helping,
regards,
Iccsi,
Adobe Employee ,
What is your platform?
Engaged ,
Win 7
Adobe Employee ,
Does it prevent you from installing the update if you were to proceed without "Run As Admin" rights? It might still install but you would need to restart the server yourself. Give it a try and let us know if it works.
Engaged ,
There is no run as administrator option when I right click on the icon on the desktop for some reason.
I tried to use ctrl-shift-return to run as administrator for mandatory update, but still get error message that I need admin rights to run the application.
I tried to do update, I still get error message when do the update 1.
Thanks again for helping and informaiton,
Iccsi,
Adobe Employee ,
Engaged ,
it works,
Thanks for the infrormation and helping,
Iccsi,
Adobe Employee ,
Glad it worked. Cheers!
Engaged ,
Thanks a million again for helping,
regards,
Iccsi,
If you don't have admin rights, forward the information to someone that does.
Nov 04, 2014 Nov 04, 2014
I had the same problem "failed signature verification" even after I successfully installed the mandatory update.  The problem was with my cacerts file.  (C:\ColdFusion10\jre\lib\security\cacerts ) We use a customized cacarts file.  I restored the cacerts file back to the original version that came with the CF install. Restarted the ColdFusion service and the update worked!  Then I put my custom cacerts file back and restarted CF.
v/r
Curt
Documentation
