11 Replies Latest reply on Dec 9, 2012 3:12 AM by Cornelia-I
    Lost adjustments on originals LR3.6 ?
    dpics2
      I imported and processed CR2s, I then exported as JPGs, no problem.
      Now, 18 months later I went to look at  these original images in LR and they show no adjustments.
      In history they show only import.
      Here and there there is an image that has adjustments maybe 1%
      and I may have adjustmented them at a later point.
      Newer folders show adjustments .
      Any ideas, thoughts ....
      I don't get it
      Images were saved with XMPs
      Images are referenced on internal HD
      thanks
      D
      LR3.6 / Mac OS 10.6.8 /
        • 1. Re: Lost adjustments on originals LR3.6 ?
          dj_paige Level 10
          Sounds like, after you edited the photos and exported a copy, you removed the photos from LR and re-imported them at a later time. Is that what happened?
          • 2. Re: Lost adjustments on originals LR3.6 ?
            dpics2 Level 1
            thanks for replying but
            I shot the images.
            I imported to an Internal HD through LR import function.
            The originals were never moved.
            They stayed on the HD they were imported to.
            D
            • 3. Re: Lost adjustments on originals LR3.6 ?
              John Blair Level 3
              Have you opened a backup catalog by mistake?  Do a search for your catalogs (search for .LRCAT).  Opening a backup catalog would explain what you are seeing.
              John
              John G. Blair Studio
              Occidental, California
              • 4. Re: Lost adjustments on originals LR3.6 ?
                dj_paige Level 10
                With all due respect, this does not answer the question I asked, specifically, did you do the following: "after you edited the photos and exported a copy, you removed the photos from LR and re-imported them at a later time"?
                1 person found this helpful
                • 5. Re: Lost adjustments on originals LR3.6 ?
                  dpics2 Level 1
                  I'll look into that.
                  It seems I have three Lightroom 3 Catalog.lrcat
                  Two are backups.
                  There is also one  Lightroom 3 Catalog-2.lrcat
                  not sure what the -2 indicates
                  I guess I should open each seperately and see what I find ?
                  Can I, should I merge them ?
                  D
                  • 6. Re: Lost adjustments on originals LR3.6 ?
                    dpics2 Level 1
                    This is to Dj paige
                    thanks
                    just to clarify
                    after I edited and exported the photos,
                    I did not remove them from LR
                    and I did not re import them
                    I missed the nuance
                    as I never removed an image from LR unless I  delete the original copies etc
                    'cause it's just  worth keeping the image for whatever reason
                    D
                    • 7. Re: Lost adjustments on originals LR3.6 ?
                      dpics2 Level 1
                      I think you're right I opened a backup and have been adding to it !!??
                      what to do about it ?
                      I don't know
                      but it makes me wonder
                      if it is a backup shouldn't it have the adjustments / edits that were made ?
                      otherwise why is it a backup ?
                      it isn't a backup of the files themselves
                      D
                      • 8. Re: Lost adjustments on originals LR3.6 ?
                        Cornelia-I Level 4
                        No, it is a backup of your catalog, a database called *.lrcta.
                        If you have added to it, you can search for the new images, select all of them and export them as partial catalog ( menu file-export as catalog).
                        This should reflect the delta to your *real* working catalog.
                        Then close this backup catalog. (As a catalog is a database, you can have only 1 open at a time.)
                        Open your working catalog. This one will miss this delta. So you invoke the command File-Import from Another Catalog, point to your exported delta catalog, and merge them thusly.
                        You could do this with your total backup catalog as well, but then you would have to choose during the merge how to avoid redundancies.
                        Good luck, Cornelia
                        • 9. Re: Lost adjustments on originals LR3.6 ?
                          Cornelia-I Level 4
                          Sorry, typo: a catalog is ending on .lrcat.
                          A catalog backup is just the same file as your working catalog at the time the backup has been created
                          So if you have continued afterwards with another catalog, then with the backup version again, you will miss some edits.
                          How often to create a backup?
                          You specify this in the catalog preferences.
                          For an enthusiast photographer who earns his living by some other job than photography, once a week may be enough, depending on how many shoots you create.
                          For a professional at least once a day or every time LR is closed would be more advisable.
                          You can always set it to "when LR next exits", which will do that, but leave your normal schedule untouched.
                          Advisable whenever you did big imports, edit sessions or changes.
                          Or before you feel inclined to do some reorganisation.
                          Save the backup to a different drive, as your main drive may fail... Dito for your photos themselves.
                          Cornelia
                          • 10. Re: Lost adjustments on originals LR3.6 ?
                            dpics2 Level 1
                            Cornelia,
                            Thanks so much for your exlanation.
                            I'm not familiar with the term Delta,
                            it seems to mean the difference between the Catalogs
                            ie what is in one but not in the other ?
                            Also, is there some automated search to determine new images ?
                            or if importing a full backup cataalog is there a no duplicates option ?
                            D
                            • 11. Re: Lost adjustments on originals LR3.6 ?
                              Cornelia-I Level 4
                              Yes, "Delta" means the difference between two catalogs. It is usually used for increments, if one version has the same as the other but then still some more.
                              Determine new images: you could look by capture date.
                              I just tested what happens if you import from another catalog, that is already included in your current catalog:
                              LR checks for duplicates. In the options offered for "Replace" you can choose
                              • to replace Nothing: that means the current catalog wins and the overlap is ignored
                              • to replace metadata and develop settings only
                              • to replace metadata and develop settings and negative files: that means the other catalog wins, the overlap is taken from that one
                              If you are unsecure if you might have worked in both catalogs for develop, you can tick the  box "Preserve old settings as a virtual copy": that means LR will know 2 develop versions afterwards, which you can manually compare and maybe cleanse any time later (or never).
                              So it will just take longer if you "Import from Another catalog" without first looking for the delta, but will give you the same result.
                              How many images do you have in your catalog?
                              With 100'000 or more it might take a while, for example a night.
                              Cornelia
