I have a need to set up a search type box based off a matrix. This is a matrix which shows a list of zip codes down the left column, and a list of products across the top, and the corresponding field from a zip code and a product is the freight rate.
e.g.
Product 1 Product 2 Product 3 Product 4
1234 $10 $12 $14 $16
4567 $11 $11 $13 $17
5678 $55 $54 $27 $35
so the freight rate to 4567 for product 3 is $13.
Then what i want to have is a drop down list for a customer to select the product, then a field to enter their zip code, and the search result will be the cross referenced freight rate.
Is this possible? If so, can someone guide me as to how this would be done?
Throw this open to the community to chip in, but off the top of my head.... thinking of something along lines of:
Create 3 web apps,
Create a web app search form for Web App Freight Rates with:
When you refer to "product" are you looking to link a web app to eCommerce product?
Or are you looking for using only a Web App to store zip codes, product and freight rates?
Thanks for your quick reply!
Sorry I should have made it clearer.
yes - that is what I intend to do.
Create 3 web apps,
Once a visitor has selected their product and zipcode, using javascript concatenate the selected ProductID with selected Zipcode.
This will produce a FreightRateID (e.g. PROD1_4567), which can be loaded into the hidden FreightRateID field.
When submitted, it will perform a web app search for a Freight Rate that matches the chosen product and zipcode, ie. FreightRateID.
To make entry of the freight rates easier, maybe add 2 datasource fields to the Freight Rate web app for Product and Zipcode.
Then create a front end web app add/edit (via a secure zone) to allow entry to be done by:
Select product, select zipcode then enter freight rate. (FreightRateID can be created and populated in same way as search above)
