I've installed photoshop and elements 10 but there is no startup icon and I can't find an executable.
What is your operating system?
Windows 7 64bit
Have you checked to see if it is visible in Start>All Programs?
Yes, but it's not there either
What happens when you try installing again? Does it ask to remove the software?
Same thing, appears to complete the install process correctly but no startup
icon or any other startup file can be found, I've tried it 4 times.
If you have tried checking both the Program Files and Program Files (x86) folder and you can't find any indications of the Photoshop Elements installation then please contact our support team.
I've contacted them 3 times and each time, after a lengthy chat, they refered me
to an 800 number that charges for assistance.
Notterfamily do you have a case number from your interactions with our support team which I can reference?
No, my bad, after the lengthy chats with the same results I was quite frustrated
and just quit. I should have saved the chats, again, my bad. I did notice after
my last attempt that the install seem to be successful but at the very end a
message "Below mentioned application has failed to install: Shared
Technologies" and then a brie message "backing out of the install process
appears" then the Adobe Photoshop icon on my desktop also disappears. It is
frustrating, I use this program at work and like it, hence my purchasing it for
home.
Notterfamily can you please private message me with your Adobe ID. I will see if I can track down your interaction through that route.
<Removed by Moderator>
I have Premiere Elements also but I haven't brought that up in any of the chats,
I'd be happy just to get Photoshop working.
I am sorry Notterfamily I tried looking up your account but it does not appear your serial number is registerd. I have since removed your serial number as this is a public forum.
I will send you a private message if you can please reply to that with your contact details I will attempt to review your interaction with our support team.
