Adobe Illustrator CS6 Update (version 16.0.3)
Installation failed. Error Code: U44M1P7
Photoshop update work fined.
Macintosh running Mountain Lion.
Same here! And Illustrator CS6 won't launch anymore!
"Adobe Illustrator cannot be opened because of a problem."
It was properly installed and never changed since..
When will Adobe ever fix their annoying updaters?!
Same problem. Updater came up today, so I tried again same result:
PLEASE adobe get this fixed!
Did the whole uninstall then reinstall thing. Working smoothly now.
Same thing here. I'm running Lion. My Mac Pro is too old to run 10.8. So uninstalled and reinstalled Illustrator from the updated application manager. And now all my panel customizations are gone. And it still won't update. While I love having access to all the Adobe products with my Creative Cloud subscription, I DREAD doing their frequent updates, because invariably at least one update fails, and often more. Then I have to jump through hoops in the hopes that I can fix it so the update works. I also had the issue with Illustrator crashing on launch. I do NOT use Mac Keeper. I do use Clean My Mac.
Same thing here. Have you tried uninstalling Illustrator and reinstalling from Application Manager? If so, any luck?
I hope it's not the same thing these poor folks had to (are) deal with: http://forums.adobe.com/message/4618444
Just reinstalling doesn't work. The app itself doesn't seem to be modified at all, so the updater screwed some files in the System folder I guess.. but which ones..?
Same problem here too.
Exact same problem. Hopefully they will take this one on soon since they just had the "Adobe Create Now Live" event and were pushing people to update the photoshop and illustrator apps!
Exact same issue here. Photoshop updated but Illustrator did not and error log says: U44M1P7.
Running Mac OS 10.8.2
And Illustrator is dead. Crashes on opening. OUCH!
Yes AI was dead here too. But TimeMachine was my friend!
I restored /ApplicationSupport/Adobe and /Applications/Adobe Illustrator CS6 from Time Machine, and now it works again. I'll not be running the update however, since it is obviously *brittle*.
Same problem! Photoshop and Dreamweaver were updated correctly but Illustrator, now i can´t even open it! I need to work!
Step1
Step 2
Step 3
Step 4
Same Here
Adobe Illustrator CS6 Update (version 16.2.0)
iMac
10.7.5
Well, I don´t know how to fixed it. I did a very complicated trip and it worked:
I did it in a MacBook Pro 17 in.
OS X 10.8.2
I don´t know if I did wrong but that way, with that long shot i could did it...
I hope that this could be usefull...
Just uninstalled Illustrator - reinstalled - then updated.
Now Illustraor 16.0.3 on Mac 10.8.2 up and running.
Same here. Hope they fix this soon. Having trouble updating photoshop as well. Don't they test this stuff before release?
Having the same problem on my Mac Pro running 10.8.2!!!!! Whats going on Adobe???!!!
Please update the AAM to the latest version before applying the patch. It could be found at :-
Win - http://www.adobe.com/support/downloads/detail.jsp?ftpID=4773
Mac - http://www.adobe.com/support/downloads/detail.jsp?ftpID=4774
Nishant
Same issue here - I used Time Machine to get the old Version of Illustrator and it works now.
What the hell is going on with this update? I applied it and the first thing it did was turn my full version of Design Standard into a trila version and forced me to re-register; now I discover that all my AI actions PLAY TWICE.
Update: it only appears to make actions play twice if they're invoked from an F-key.
This is completely unacceptable. Will Adobe compensate me for the inefficiency this creates in my workflow? My billable time is based on being able to complete jobs in carefully calculated timescales and this REALLY messes with that.
I only installed this update in hope it would fix the broken window behaviour under Mountain Lion, which I reported with the initial release and which remains unaddressed.
Further update: TIFF export does not embed the specified color profile.
Sorry for tagging this onto an existing thread, BTW, but I'm struggling to make sense of this forum's posting options…
