Hi
First of all, I am not sure if it is a good idea to create one post for two queries. But I have these two requirements for my project.
1. I need a Expand all/ Collapse all button(s) on the toolbar, which will open and close all books in the ToC. Is it possible to have one? How?
2. Is it possible to have a different color for the visited topics on the ToC? How?
Sreekanth
1. See http://www.wvanweelden.eu/product/webhelp-toolbar-scripts for an easy solution.
2. If I'm not mistaken, you can set this in the Skin Editor.
Greet,
Willam
Hi William
1. The link provides scripts to expand/collapse dropdowns within a topic. However, I need to expand/collapse all books and all topics in the Navigation panel at the click of a button. Any thoughts on that?
2. The skin editor allows us to choose colors for active topics (the topic whose content is displayed in the content area), and not the visited links.
For example, if I have completed topics 1 and 2 and am currently on topic 3, skin editor takes background color for the topics 1 and 2, and displays Highlight color for topic 3. However, I need a different color for topics 1 and 2.
Sreekanth
Your requirements are
Not something I have ever seen.
Same answer.
Sorry.
Hi there
Just thinking out loud here. When WebHelp loads up, all books are typically closed. So theoretically, one could insert a button or link somewhere that would, when clicked, simply point to the start page of WebHelp. That would "collapse" all books by reloading the WebHelp.
When you create "Section 508" output, all books are expanded. Again, theoretically, one could create a second WebHelp using the Section 508 output that would have all Books expanded.
The problem with this is that there wouldn't be an easy way back to the normal WebHelp. And with either use, the Default Topic would then replace whatever topic was open in the Topic Pane.
Cheers... Rick
1. Perhaps Rick's suggestion will work. As far as I know the working of the WebHelp TOC, there is no way to make this work. Not without freezing the browser for ten seconds.
2. I thought you could set this from the editor too. But you can easily add styling for visited TOC links in the file whthost.js. On line 654 (RH9) you can add any styling you want. Just make sure to save your changes and paste your modified whthost.js into the output every time you generate.
Greet,
Willam
Rick/ Willam -- Thanks for your inputs.
I will try these methods and get back with my results.
