export to excel
Dec 19, 2006 Dec 19, 2006
Hi All,
I'm exporting a query to excel file but my code is on the top of the page
after the query. I'm using get method to validate the form with url
variables.
The download works, but at the end of the file also includes all page code.
I try cfabort but doesn't work.
FYI I'm using cf7 with application.cfc
How can I fix this problem?
Thank you in advance.
Johnny
<cfif IsDefined("url.downloadReport")>
<CFHEADER NAME="Content-Disposition" VALUE="inline;
filename=contactsReport.csv">
<CFCONTENT
TYPE="application/unknown">"Company","City","State","Zipcode","SalesRep","Type","First
Name","Last Name","Title","Phone","Ext","Mobile","Fax","Email"
<cfoutput
query="getStruc">"#customer#","#city#","#state#","#Zipcode#","#appearance#","#typeDesc#","#cfirstName#","#clastName#","#ctitle#","#cPhone#","#cExtension#","#cMobile#","#cFax#","#cEmail#"#chr(13)#</cfoutput>
<cfabort>
</cfif>
Advanced techniques
587
Advocate ,
Dec 20, 2006 Dec 20, 2006
Have you tried using <cfsetting enablecfoutputonly="Yes">? You'd have to wrap all the text you want to actually output in <cfoutput> tags, which means changing <cfoutput query="getStruc"> to <cfloop query="getStruc">, but that may fix your problem.
Tks for reply, I just try and it doesn't work.
Maybe I have to setup in different way???
Rgds
Johnny
<CFCONTENT
<cfloop
query="getStruc"><cfoutput>"#customer#","#city#","#state#","#Zipcode#","#appearance#","#typeDesc#","#cfirstName#","#clastName#","#ctitle#","#cPhone#","#cExtension#","#cMobile#","#cFax#","#cEmail#"#chr(13)#</cfoutput></cfloop>
<cfabort>
</cfif>
"insuractive" <webforumsuser@macromedia.com> wrote in message
news:embr4s$9ak$1@forums.macromedia.com...
> wrap
> that may
> fix your problem.
Advocate ,
Make sure you move the <cfsetting> command to the top of the page. I had success using the following code:
Hope that helps!
Tks for you reply and help.
Looks like I have a different issue with <cfabort> and application.cfc
Before I found a site that told me to use the code above to pass <cfabort>
error
<cfif arguments.exception.rootCause eq
"coldfusion.runtime.AbortException">
<cfreturn/>
</cfif>
If I take this code out of the cfc.. works... but give me cfabort error.
coldfusion.runtime.AbortException at
coldfusion.tagext.lang.AbortTag.doStartTag(AbortTag.java:62) at
coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1908) at
cfsearchCustomer2ecfm2064181429._factor13
Do you know anything about this?
I will keep digging...
Rgds
Johnny
news:emca28$qv3$1@forums.macromedia.com...
> <!--- Insert at top --->
> <!--- Building a dummy query to use as an example (you can ignore
> this) --->
> <cfset getStruc =
> QueryNew("customer,city,state,Zipcode,appearance,typeDesc,cfirstName,clastName,c
> title,cPhone,cExtension,cMobile,cFax,cEmail")>
> <cfset temp = QueryAddRow(getStruc, 1)>
> <cfset QuerySetCell(getStruc, "customer", "1", 1)>
> <cfset QuerySetCell(getStruc, "city", "testville", 1)>
> <cfset QuerySetCell(getStruc, "state", "tx", 1)>
> <cfset QuerySetCell(getStruc, "Zipcode", "55555", 1)>
> <cfset QuerySetCell(getStruc, "appearance", "1", 1)>
> <cfset QuerySetCell(getStruc, "typeDesc", "1", 1)>
> <cfset QuerySetCell(getStruc, "cfirstName", "Test", 1)>
> <cfset QuerySetCell(getStruc, "clastName", "User", 1)>
> <cfset QuerySetCell(getStruc, "ctitle", "Mr", 1)>
> <cfset QuerySetCell(getStruc, "cPhone", "555-5555", 1)>
> <cfset QuerySetCell(getStruc, "cExtension", "123", 1)>
> <cfset QuerySetCell(getStruc, "cMobile", "555-5556", 1)>
> <cfset QuerySetCell(getStruc, "cFax", "555-5557", 1)>
> <cfset QuerySetCell(getStruc, "cEmail", "testuser@somewhere.com", 1)>
> <!--- End Dummy data section --->
> <!--- Make the <CFHEADER> tag is all on 1 line --->
> <!--- Notice the use of <cfoutput>'s below --->
> <CFCONTENT
> TYPE="application/unknown"><cfoutput>"Company","City","State","Zipcode","SalesRe
> p","Type","First
> Name","Last
> Name","Title","Phone","Ext","Mobile","Fax","Email"#chr(13)#</cfoutput>
> <cfloop
> Hope that helps!
Contributor ,
Exporting to Excel works best if you just generate standard html tables and then let excel convert it for you.
The following code should give you what you're after:
Thanks for you reply...
These works finally, I just have to put the code at the end of the page,
otherwise it will include the page result inside the excel sheet.
Really appreciate you help.
Tks
Johnny
"efecto747" <webforumsuser@macromedia.com> wrote in message
news:emcqdc$fcd$1@forums.macromedia.com...
> Hi,
> and
> <cfheader name="Content-Disposition" value="inline;
> filename=acmesalesQ1.xls">
> <cfcontent type="application/vnd.msexcel">
> <table>
> <tr>
> <td>Company</td>
> <td>City</td>
> <td>State</td>
> <td>Zipcode</td>
> <td>SalesRep</td>
> <td>Type</td>
> <td>First Name</td>
> <td>Last Name</td>
> <td>Title</td>
> <td>Phone</td>
> <td>Ext</td>
> <td>Mobile</td>
> <td>Fax</td>
> <td>Email</td>
> </tr>
> <tr>
> <td>#customer#</td>
> <td>#city#</td>
> <td>#state#</td>
> <td>#Zipcode#</td>
> <td>#appearance#</td>
> <td>#typeDesc#</td>
> <td>#cfirstName#</td>
> <td>#clastName#</td>
> <td>#ctitle#</td>
> <td>#cPhone#</td>
> <td>#cExtension#</td>
> <td>#cMobile#</td>
> <td>#cFax#</td>
> <td>#cEmail#</td>
> </tr>
> </cfoutput>
> </table>
> </cfif>
Dec 22, 2006 Dec 22, 2006
I'm trying to download a report into Excel for the first time and this thread has been helpful (I think?). The code seems to run just fine, but I'm not getting the window that pops up that would allow me to open/save the excel file. I used the last code set supplied by efecto747 to create the document. Any help would be appreciated.
David
Never mind - had an epiphany and figured it out as soon as I sent the message.
Documentation
