In the following paragraph, base current is expanding text. Until a couple of weeks ago, moving the pointer over drop-down text, expanding text, and pop-ups, would display a tooltip identifying the type of dhtml or popup. Does anyone know how to fix this?
You can also create new exchange rate sets and delete existing exchange rate sets,
and modify the base currency for any exchange rate set other than the AIR Default
set. You select exchange rate sets when you generate exposure views, run analyses,
and view results.
Thanks.
Carol
Thanks for the idea, Peter. In the end I did not need to do that. When I opened the project this morning, RoboHelp was displaying the tooltips again. I’ll keep an eye on this issue and try to note anything I happen to be doing before the tooltips disappear!
I don't know why that would happen. Try creating a new project with a couple of topics. See if it works there and post back.
I suspect the reboot fixed the issue.
