I was trying to open a video yesterday but was required to install an Adobe Flash Player -- so I did. Now for each item I wish to open I am required to install the Flash again every time. Isn't once enough? I'm very annoyed and don't have time for this. Thanks for answering ASAP.
Terry
same problem here.
isn't an issue with firefox or chrome as far as I can tell. just IE9. After going through all the massive documentation, I un-installed flash and re-installed it. problem went away. until I had to re-install it for Firefox, then problem came back on IE9. I believe there is a problem on Adobe's end for flash 11.5 for IE9 by simple deductive reasoning. Again, IE9 is the only browser this is a problem with. When I came to the first help screen here, it verified I was running the current version of flash player, so, logically, there should be no need to re-install it, don't you agree?
Mark Donaldson
I am having the same issues using IE 11 with windows 7 64 bit
Moved to Installing Flash Player
