2 Replies Latest reply: Dec 17, 2012 2:53 AM by sivacse24rep RSS
    NativeProcess.isSupported always return false
    sivacse24rep Community Member
      when i do this trace(NativeProcess.isSupported) it always retun false. I run the code on flash cs5 AIR 2.0. Then i publish as .air file and it again it gave the 'false' as result. I checked the xml file it have tag "<supportedProfiles>desktop extendedDesktop </supportedProfiles>". Then i tryed the same from flash cs6 AIR 3.2 again the same 'false' result.
      What is the problem? What should i do to get the result as 'true'?
      Here is the xml file generated from flash CS5:
      <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
      <application xmlns="http://ns.adobe.com/air/application/2.0">
        <id>test</id>
        <version>1.0</version>
        <filename>test</filename>
        <description/>
        <name>test</name>
          <copyright/>
         <initialWindow>
          <content>test.swf</content>
          <systemChrome>standard</systemChrome>
          <transparent>false</transparent>
          <visible>true</visible>
          <fullScreen>false</fullScreen>
          <aspectRatio>portrait</aspectRatio>
          <renderMode>auto</renderMode>
        </initialWindow>
        <icon/>
        <customUpdateUI>false</customUpdateUI>
        <allowBrowserInvocation>false</allowBrowserInvocation>
      </application>
      Siva
