I have the search page for user to search the purNO and display resutls in the list. I am tring to do the paging but keep got an error for cf 7 not supported the PAGESIZE,BIND. Please advice with the code below to have it works in colfusion 7.
<!---form--->
<cfparam name="variables.row_per_page_default" default="15">
<cfform name="tableform">
<cfgrid format="html"
name="grid_Tables"
pagesize="#variables.row_per_page_default#"
selectmode="row"
bind="cfc:cfc.query.pur{purNO},{cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdirection})">
<cfgridcolumn name="purNO" display="Purchase No"/>
<cfgridcolumn name="date_modified" header="Date Modified" >
</cfgrid>
</cfform>
<!---cfc--->
<cffunction name="purNo" returntype="query" access="public">
<cfargument name="purNO" required="yes" type="numeric" />
<cfargument name="page" required="yes">
<cfargument name="pageSize" required="yes">
<cfargument name="gridsortcolumn" required="yes">
<cfargument name="gridsortdirection" required="yes">
<cfquery name="qPur" datasource="#variables.dsn#">
SELECT *
FROM tbl_pur
WHERE purNO = <cfqueryparam value="#arguments.purNO#" cfsqltype="cf_sql_integer" />
</cfquery>
<cfreturn queryconvertforgrid(qPur, page, pagesize) />
</cffunction>
Sorry. I do not expect the code to work in Coldfusion MX7. Support for the bind attribute in HTML forms, in particular binding to CFCs, only began with ColdFusion 8.
<cfgrid format="xml"
what's about xml format?, grid is worked but is there the way you can have pagination?
thanks
