I’m looking for is an advanced action/variables that can allow you to:
Aggregate the results of four text-entry boxes on the same slide (this is not a quiz slide).
4 correct entries = brings up a success caption & allows the user to advance to the next part of the course.
3 correct entries = brings up a hint caption and gives the user two options – 1) allows the user to advance 2) takes the user to a review section.
2 or less correct entries = brings up a failure caption and takes the user to a review section.
Hello,
Here is the link to the blog post:
http://lilybiri.posterous.com/aggregating-results-tebs-in-captivate
You can literally use the same advanced actions in Captivate 5. You'll have a normal Next and Review button (instead of a shape button), and perhaps you do not need the 'actor' I added. Let me know if you have issues or questions.
Lilybiri
Do you want to report as well or only do the actions you were explaining?
Are you using the Submit button for each TEB? Can the sequence be imposed or not? If you explain that, I'll try to work out a scenario tomorrow, now it is almost midnight here.
Lilybiri
No need to report, only execute the actions that were explained
Yes, the submit buttons are being used for each TEB – you could impose a sequence, but would prefer not to if possible.
And you do not want an extra button to 'check' but whatever is the last submit button should cause the actions to be executed I suppose...
Lilybiri
Whatever works and is simplest to execute…
Hello,
As promised, I have a functional example. Even two versions:
Think it will be better if I explain the solution in a blog post... if you agree. I used a variable v_total to store the total number of answers (for both scenarios) and for the second one I also have a toggle variable for each TEB to store if its Submit button has been clicked. I attached a score to each TEB to be able to use the system variable cpQuizInfoPointsscored for the conditions as well. It will take a lot of text to post the explanation here. Let me know about the check for empty entries in the TEB's: will you allow a blank entry if the user clicks on a Submit button or not.
I worked it out in Captivate 6, if you are using that version, send me a private message with your email address and I could send you the example with the advanced actions.
Lilybiri
I am using Captivate 5.5. You can blog it, let me know the URL please.
Bummer, should have asked it. Because I used some aspects that do not exist in CP5.5 as object groups and smart shapes. However the advanced actions can be used in CP5.5 if you take care to change statements referring to object groups into statements for each object.
What about the 'check' if the user did input something into the TEB when clicking the Submit button?
Lilybiri
I understand the check to mean that it the user doesn’t enter something in the TEB, and then clicks the submit button it will mark the answer as wrong, rather than prompting the user to enter something.
If this is correct, then I don’t think the check is necessary.
OK, just wanted to verify.This means that the user can choose to give a 'blank' answer.
Lilybiri
Yup, that’s what I thought… I guess they could miss the answer by accident, but in general I guess they would do if this if they didn’t know the answer. That’s fine.
Hello,
Lilybiri
