We purchased an E book with the title of Adobe After eEffects CS6 Visual Efects and Colmpusition Studio Techniques from Adobe Press and downloaded the file as an EPUB file onto a PC running Windows XP. The final destination for this file is onto an iPad. We realise that to do this we have to transfer the file via i Tunes on the PC. The problem is that this type of file will not transfer into i Tunes for the transfer. It would have been a lot easier if we could have called up the download on the i Pad and made a direct transfer but to our knowledge this can't be done. Please advise.
I checked through all of the points that you mentioned should be inplace and found that I failed to authorise Bluefire to my Adobe even though I was shure I did. Low and behold the file opened.
Thank you so much for your patience and assistance.
Moving this discussion to the Adobe Digital Editions forum. Are you opening the ePub in Adobe Digital Editions or another application on your computer?
You may also want to reference View e-books | iOS, Android devices - http://helpx.adobe.com/digital-editions/kb/view-e-books-ios-android.html.
You need to install Bluefire reader or similar on the iPad, and register it with your AdobeID.
I understand you can transfer via iTunes and the read with Bluefire.
I know that you can transfer with Dropbox.
Dropbox will say it doesn't know how to open the file,
but if you go to the top right widget in Dropbox you will get a dropdown of programs that Dropbox thinks can open the file,
and that should include Bluefire.
You can also use the Application tab within iTunes to transfer books over. The doc I referenced above refers you to the manufacturers website for instructions because the process could be different depending upon the application which you choose to use.
The file loaded from the PC via the Dropbox but when the download to i-pad was completed a note came up advising this type of file unable to be viewed. When selecting the widget at the top right of the screen the note states that no installed apps support the opening of this file even though a Bluefire reader has been installed which is supposed to do the job.
If you still want to try the Dropbox route here are some questions/suggestions.
Always difficult to diagnose for someone else when it is working here. Some suggestions a bit silly, clutching at straws.
I haven't seen any other comments on the web of the Dropbox/Bluefire reader combination failing to work.
Just double checking.
I just did another experiment and found that transferring the .acsm file via Dropbox works as well (for me).
When the .acsm file is displayed in Dropbox on the iPad it displays the xml content of the file, but still has the dropdown for 'Open in Bluefire Reader'.
Opening this caused Bluefire to re-dowload the .epub file direct to the iPad.
Another suuggestion I have seen ( http://www.pldminfo.org/search/digitaldownloads/iPadBluefire.pdf ) to avoid the need for iTunes
is to mail the file to yourself. I've just tested that with both .acsm and .epub files and it works for me.
It probably uses the same 'cross-application' mechanism that Dropbox uses to open files,
but maybe for some reason it will work for you where Dropbox failed.
