Show 2 replies
1. Re: Wrong date inserted in file properties when using "save as"
Curt Y Dec 18, 2012 1:10 PM (in response to Rafael Aviles)If you modify the file and change extension its date file created will change as well as the date file modified. The Date Created should remain the same. This is usually set by the camera or scanner.
Hope this helps.
2. Re: Wrong date inserted in file properties when using "save as"
Rafael Aviles Dec 18, 2012 1:16 PM (in response to Curt Y)I understand that, thank you. I guess the issue is that the file did not have a Date File Created to begin with. So, I would expect that the Date File Modified entry would reflect when the file was modified/saved, which it does. But why does the Date File Created field now show an arbitrary date (12/31/03)?
